Old 04-22-2020, 09:11 PM   #1
zainracer
zainracer is an unknown quantity at this point
550cc injectors, Aeromotive FPR with harness, fittings and mounting bracket.
Subaru STI 550 CC side feed injectors with modified SR20 harness to make this plug and play for SR20. Injectors will come with rail shown that has a fitting to adapt this to the Automotive fuel pressure regulator.
Automotive fuel pressure regulator will come with the gauge shown. There is a plug on top of the gauge to hold the liquid in the gauge in, I put tape over it to ensure it doesn't leak. Fuel pressure regulator will also come with fittings shown that are the same size as the stock hard lines. I will also include the bracket shown that mounts this on the shock tower as shown which makes this a simple bolt on!
NOTE: the little harness clip tab on one of the injectors snapped off, will still work fine but you would want to add a zip tie on that injector to make sure the connector doesn't come off. (4th pictures shows this clearly)
This has been used for ~20k miles on my sr20 with zero issues, selling to upgrade to larger injectors/different rail.
$300 shipped/paypaled
zainracer is offline   Reply With Quote
Old 05-07-2020, 10:07 PM   #2
zainracer
BUMP! Price dropped to $260 Shipped/PayPaled.
Old 05-22-2020, 05:09 PM   #3
zainracer
Memorial Day Weekend bump!
Old 08-20-2020, 03:47 PM   #4
zainracer
Bump!
$250 shipped!
Or: $180 shipped for everything EXCEPT fuel pressure regulator/fittings.
550cc, aeromotive, fpr, harness, injectors
