Old 04-07-2020, 11:17 AM   #1
BorgWarner
BorgWarner is an unknown quantity at this point
SR 95 240sx - SR20det - Need help with clutch info!
Hey guys, any constructive input would be greatly appreciated!
I recently purchased my first 240sx after years of searching. First time posting on this forum, been reading for a long time. I have a few questions about a clutch replacement:
1) I have an SR20det that needs a new clutch. Stage 1 up to 350hp should be perfect. Is there anything I should check on my 5 speed trans / bell housing to ensure I do not waste money on an incompatible flywheel / clutch?
2) Any recommendations for the best / cheapest place to order a clutch to Ontario? Exedy, Enjuku Racing?
3) Please let me know if I need to provide you wizards with any additional information / pictures - I would be happy to do so.
4) If you are interested in pics of what I picked up, my insta is: zenki_240
Thank you very much guys!
BorgWarner is offline   Reply With Quote
Old 04-07-2020, 04:03 PM   #2
Kingtal0n
Kingtal0n's Avatar
If you've got 300~hp I would go with stage-1 Spec clutch + stock flywheel (not resurfaced; just use emery cloth on a stock flywheel)
After 300hp I don't fuck around. Get an Ogura single or twin plate.
Old 04-07-2020, 04:42 PM   #3
BorgWarner
Thanks for the input, it is very much appreciated.
I like your first suggestion. You think something like this should be okay?:
Option 1 (No rear main seal or flywheel): https://www.enjukuracing.com/product...n-sr20det.html
Option 2 (No rear main seal or flywheel): https://www.enjukuracing.com/product...t-sr20det.html
Option 3: Are there any all - in - one kits for the above 2x options? Similar to: https://www.enjukuracing.com/product...eel-bolts.html
Thank you, sorry for the rookie questions!
Old 04-08-2020, 12:00 PM   #4
Kingtal0n
Kingtal0n's Avatar
I would only use a SPEC clutch, stage-1, stock flywheel, the first link
stock flywheel + emery cloth, do NOT resurface
The clutch when new should stick to the flywheel surface very easily
also make sure you read the FSM there are places to pack grease, and spread grease,
input shaft greased,
pack the tob greased,
Only use Molybdenum disulfide grease, not just random grease from the store
please read these pages carefully
Old 04-08-2020, 12:23 PM   #5
BorgWarner
You are a GOD! Thank you sooooo much for taking the time to help me out!
I have a plan of attack now thanks to you. I will be sure to look over FSM very carefully, watch some videos first & pack / spread grease where needed, using only Molybdenum disulfide grease. I am going to be ordering the SPEC Stage 1 clutch that I mentioned above (Option 1).
Thank you again my G, you were beyond helpful!
clutch
