Old 03-17-2019, 01:36 PM   #1
David B S12
David B S12 is an unknown quantity at this point
s14 Beams 3SGE Swap 240sx 2019 - UPDATED / RECOVERED - David B
its March 2019 and forums still exist
** Redoing this original post - i used facebook links of the pictures and they died. im sorry
I own 3 240's and this is my daily driver , ive daily driven well over half a million miles or more in S chassis's since i got my permit. No savior honda civic, or weekend meets lol, all of it. I have only had some form of a S chassis as means for primary transportation no matter what, thats what I do, ride or die mothaflocka.
The other two S14's being 1j's the beams seemed like a great alternative choice, a couple months research and ordering parts the original swap was completed in 3 days 2 years ago and met my "experimental" budget at about 3000$, it probably costs a but more today or less depending on the market and options for swap parts . I like the iron block, timing belt, high compression dual vvti & 6 speed trans for the price. They are picky with fuel / intake / speed sensor and other quirky things although the Altezza link / ITbs or supercharger is a common options (auto motor is lower compression for turbo and boost )
Ka's are expensive now, I can't get over it. I hate looking at them and working on them, sure they spin the tires but really they are not a very fun motor to enjoy driving with, maybe I have just grown out of them. Sr20s are all crusty and expensive, etc, they can't handle accidents like overheating and also like the KA, timing chain which makes repair a pita, I hate removing front covers with a passion especially nissan stuff. I wanted AC and enough power to pass people on the highway. Then maintain good fuel mileage and have some good times on a back road or two headed out of state. Then drive to work every day all days of the year.. Thats what led me in this direction plus being a unique swap and documenting for the community is always a +1 similar to my original 1jz swapped S12 about a decade ago
A/C works and power steering bolts up, the mounts are modified excessive mounts. The engine has a natural tilt i have removed so the shifter sits at a slight 5 degree angle. Barely noticeable, the shifter location fits well and the oil pan clears the stock swaybar. No subframe issues at all or hood issues. I did install a slim profile water neck on the back of the engine and cleaned up the bypass hose for optimal clearance to set the engine as far back as possible. Fuel is converted from single feed to the 240s return lines but flared to AN. Then aermotive 340 pump & Tomei regulator
The most complex part of the swap is modifying the headers to clear the column but thays common on most swaps anyways. Wiring is not complicated and I use Torque pro to scan codes and view more data. Stock ecu
The engine is so far back and the top end is incredible, it packs a nice healthy punch from 6 to 8k revs (vtak baby), it really shines on back roads and if your good with rev matching and cornering. Tons of extra control with the engine and the revs. The flywheel is an 11 lb toda flywheel , which is a dramatic loss over the original dual mass 32 lb'r. The intake is SO loud. The motor sounds awesome. Consider two resonators and a muffler to dampen the exhaust so you can hear that intake sing and keep the cops off your back
Flip a Ka's power band upside down and throw 50 horsepower at it and this is generally where your at with the beams on stock form. Although my intentions are just to drive from A to B I wasn't necessarily trying to have a 3rd 1jz swap car and did not want an NA sr20 given the nicer quality of the Toyota unit which is superior in my own opinion
Bottom line is this. Rather then complain or deal with stuff you don't like about the market these days, pave your own way and write down some notes for the next guy. If yall want these cars to stay around then finding lil 4 bangers that fit and run nice sometimes is better then a money pit that can't get you down the road 100k without just oil changes brakes and tires. Not all cars should be intended to be drift cars (coming from a well seasoned veteran) so consider restoring and dailying the car you like so you can enjoy it every day rather then keep it locked up in a garage to be sold because its so valuable. Some day there will be no more Ka's and Sr's that are affordable for the regular enthusiast.
anyways heres a quick brush from what i can remember before i forget. sorry if its not as Buildish as it was before. now all my photos are on flickr
i Paid 900$ for the beams swap - nobody wanted them early 2019 - i always be peepin them 4 cylinder JZ's hiding in the corner of the importer my whole car life, begging for a home
52993357_10157000446584556_7360219690615963648_o by david bellomo, on Flickr
heres the excessive motor mounts, they did not fit , i had to modify the brackets and the mounts to actually even bolt the engine up. i provided information to xcessive and got a pat on the back. thanks guys
46443416_10156767308719556_8208841057199194112_o by david bellomo, on Flickr
46458088_10156767308604556_8449863347561562112_o by david bellomo, on Flickr
brackets slotted and dropped the drivers side down like an inch, the trans mount was a slotted 1jz trans bracket
53050751_10157004602439556_31272442861191168_o by david bellomo, on Flickr
ebay celica intake is a good start for the intake
41033322_10156594654579556_497156955731656704_n by david bellomo, on Flickr
40818570_10156594654484556_7280373443969679360_o by david bellomo, on Flickr
various tid bits about parts - ur welcome
battle garage is your friend , they are on ebay too
if your missing a brain box, gs300 is the same. EBayyyyy
50491055_10156918835109556_195797637650186240_o by david bellomo, on Flickr
40406658_10156579485769556_4696233437491625984_o by david bellomo, on Flickr
41111500_10156594653984556_310321325690322944_o by david bellomo, on Flickr
31126 BOOT, CLUTCH RELEASE FORK
31126-14010 1 $16.45
31204 FORK SUB-ASSY, CLUTCH RELEASE
31204-43010 1 $106.83
31210 COVER ASSY, CLUTCH
31210-22150 1 $183.55
31230 BEARING ASSY, CLUTCH RELEASE
31230-53010 1 $50.42
31232A CLIP, RELEASE BEARING HUB
31232-36030 TYPE A:イラストサンシヨウ 1 $2.17
31236B SUPPORT, RELEASE FORK
31236-14010 1 $24.91
31250 DISC ASSY, CLUTCH
31250-53012 1 $164.54
33311W BEARING (FOR INPUT SHAFT)
90363-12004 1 $40.72
90119-08026 *** STD. PART $0.71
16361A BELT, V(FOR FAN & ALTERNATOR)
99364-30780 1 $33.41
44310A BELT, V(FOR VANE PUMP)
Not applicable
88310A BELT, V (COOLER COMPRESSOR TO CRANKSHAFT PULLEY), NO.1
99364-31220 長さ=1220 1 $54.84
11115 GASKET, CYLINDER HEAD
11115-88570
some wire stuff and info
DOWNLOAD THIS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
https://drive.google.com/file/d/1zhd...nGis8F1IS7FJyw
40513321_10156579485529556_4807179404889292800_o by david bellomo, on Flickr
40417726_10156579486234556_8605977020700033024_o by david bellomo, on Flickr
40466568_10156579486354556_3794332318701715456_o by david bellomo, on Flickr
https://www.dorikaze.net/showthread....y_OiyDkpcdanCM
E1, constant power, fused
E8, E10, E16, A6, switched power.
D26, tach, need tach adapter for accuracy/function
B3 and A28 will go to the oxygen sensor (will run without it) but let me know when you get to this. It’ll probably be the very last part of your swap.
All switched wires should be able to run off of your old coil power wire, but I’d recommend using a relay to avoid voltage drop
49525724_10156876181684556_1057875179721457664_o by david bellomo, on Flickr
Maf on the right. Injectors and coils on the left. Ontop of powering the ECU and throttle body that's what was left. The maf power plug also has a alternator plug not pictured. It's on the second row down and the second to last pin from left to right . Needs 12 volts as well. *still needs revision to see if the injector and coils need direct power. This worked for me but I read otherwise the ECU powers them
i used a pickup 22r disk and have the part number (there are two part #'s but this one is IT, go to your local toyota and order. yay)
45193706_10156725751629556_6147545896612528128_o by david bellomo, on Flickr
45221568_10156725751309556_5004779421270278144_o by david bellomo, on Flickr
wix single feed fuel setup - this got me rolling for a year - i switched it up but to stay timeline correct ill still advise this is the cheapest way to get running, the beams asks for 62 psi and this wa s58 - it worked.
50234180_10156907854189556_2898316692381761536_o by david bellomo, on Flickr
UM YEA, they make a radiator for a beams swap, well it is for a hachi roku but who cares, its got to fit
40461148_10156579486484556_3389560311370481664_o by david bellomo, on Flickr
50775365_10156918795769556_8956741347587391488_o by david bellomo, on Flickr
yes , just slot the mounts and then bore out the bushings with a drill bit, i bent the top mounts to secure it in place
53287700_10157011151259556_610949167891611648_o by david bellomo, on Flickr
i used the mishimoto hachi fans and included a mishi fan controller that threads into the radiator
53701942_10157011151154556_4011723475663192064_o by david bellomo, on Flickr
i had 3 days off at work and couple months research and parts ordering, this was the weekend where i tossed it all in and ended up making it happen despite discovering the engine mount issues which set me back a solid 6 hours
BYE KA - NEVER AGAIN
53364393_10157004602759556_1316843917915717632_o by david bellomo, on Flickr
yea thats a plastic roll cart
52977657_10157004602644556_3016517293334069248_o by david bellomo, on Flickr
that moment when you know its gonna work ( i had already pre wired and ran the engine on the stand)
53501965_10157004601859556_4071379420353396736_o by david bellomo, on Flickr
53320720_10157004602074556_5695634041932349440_o by david bellomo, on Flickr
w58 yoke should work on the J160 6 speed- shaftmasters online set me right
53146083_10157011151429556_4117591348607975424_o by david bellomo, on Flickr
53150291_10157011151509556_2857591013617172480_o by david bellomo, on Flickr
so i found this automatic beams altezza down pipe on europe ebay for 50$, shipping was 100$ but i really liked the dual pipes they were easy to weld and configure to get around the steering shaft. this seems to be a popular problem with the beams swap, ur gonna need a welder lol
53077634_10157004604259556_5398663527592361984_o by david bellomo, on Flickr
Maybe i worked @ a muffler shop in my previous life? just kidding but i was really happy with this exaust, dual resonaters highly reccomended to guys that like to hear the engine and not just the exhaust
56786223_10157082161314556_2451049982271160320_o by david bellomo, on Flickr
56922716_10157082161344556_3831874924188794880_o by david bellomo, on Flickr
yea it fits pretty well. i did get the motor further back a tiny bit after this pic.
53018051_10157004601754556_5310702867953221632_o by david bellomo, on Flickr
p0500 speed sensor code removal - convert your 3 wire signal to 2 wire, output to cluster, then cluster to ecu so ecu gets signal. p0500 effects the timing
82159153_10157830064174556_5135727747150118912_o by david bellomo, on Flickr
use any "dead" wires to your advantage, aka the original toyota engine harness on the beams to throw power to the engine bay
82198406_10157830047094556_7906024611333013504_n by david bellomo, on Flickr
tigg'd the a/c lines - wiring is quite simple. screw all that nonsense, run that bish through the triple pressure sensor and cycle the clutch off of that, the beams is eletric throttle so dont forget to power your a/c clutch signal to the power steering pin on the ecu to get some RPM bump, along with triggering your a/c fans if your using the same fan controller as me
67299935_10157363872059556_1558577648135831552_o by david bellomo, on Flickr
67387195_10157363871999556_2297935484795486208_o by david bellomo, on Flickr
67406698_10157363871954556_2586219071297028096_o by david bellomo, on Flickr
AIR FLOW STRAIGHTENER critical, must straighten airflow. use HKS pod or get a straightener. i rivited this in my pipe. guess where i got it "honeycomb"
54520879_10157035970394556_354534676813053952_o by david bellomo, on Flickr
torque pro
Obd2 port install / using Torque App
- here are the pins you need off the ob2 port plug itself - pins -4, 7, 9 ,13 , 16
Pins off obd2 port to Ecu pins
-Pin 4 is ground ( I just used chassis ground )
-7 goes to pin E11 on the Ecu
-9 goes to pin D26 on Ecu
-13 goes to pin D24 on Ecu
-16 goes to pin E16 or E8 (B+)
Bought this obd2 scanner
https://www.amazon.com/gp/aw/d/B011NSX27A/ref=yo_ii_img...
Picked up one of these obd2 ports off eBay https://www.amazon.com/gp/aw/d/B01KF0ZQVC/ref=yo_ii_img...
Then. I downloaded torque app
Note - need to change protocol for the beams Ecu to be recognized
Create a profile and scroll all the way to the bottom were it says "very advanced-elm327"
ATTENTION ATTENTION ATTENTION ATTENTION ATTENTION ATTENTION ATTENTION ATTENTION ATTENTION ATTENTION ATTENTION BELOW IS IMPORTANT
Type in - ATIB 96 \n ATIIA 13 \n ATSH8213F0 \n ATSP4 \n 0100 - exactly how it's typed and spaced then save the profile and your all set should link up to Ecu with no issues
55698651_10157065726544556_7879858562464219136_o by david bellomo, on Flickr
55788320_10157065726579556_7285388136115339264_o by david bellomo, on Flickr
startup video
http://www.youtube.com/watch?v=MEo90QxIOGk
https://www.youtube.com/watch?v=MEo90QxIOGk
checked fuel pressure
http://www.youtube.com/watch?v=KJZFCuVSqv0
https://www.youtube.com/watch?v=KJZFCuVSqv0
YAY! happily ever after - close curtains.
53778714_10157018299579556_1380397807420047360_o by david bellomo, on Flickr
ok, now a year goes by. the beams swap i got was a bad egg. it was consuming a shit load of oil. eventually it started knocking and it threw a bearing on my 3 mile commute home,wow, gay. i have drifted for 10 years beating on cars and never thrown a bearing. i tossed this up as a neglected motor and decided to continue on and source a newer gen beams motor (g3)
i coasted down my street into the driveway where she died
91505287_10158068222079556_4872631137362509824_o by david bellomo, on Flickr
91508609_10158068221544556_4753035019931353088_o by david bellomo, on Flickr
of course i organized everything and collected all the parts for the future since i am a long term car enthusiast, i dont really give up and expect to need these parts later, i did trade that stupid block for a blow off valve. yea boi i got ALL major sensors in the trunk.
91753567_10158068221894556_4848838392932204544_o by david bellomo, on Flickr
my other bitches side to side
91545440_10158068221749556_5709356136025554944_o by david bellomo, on Flickr
got a new engine, blah blah, thanks market. now they cost 1400$
DO YOURSELF A MASSIVE FAVOR AND DITCH THE STOCK DUAL MASS FLYWHEEL, what a load of garbage, it was so looose and you could feel it driving, this toda 11 lb is freaking great!! the original wheel was 32 lbs
peep the slimline bypass, get it if you want to squeeze the engine back like i did, so you dont rub coolant lines on the firewall and give your self headaches later
93770289_10158127522454556_88273672560705536_o by david bellomo, on Flickr
DO YOURSELF A FAVOR AND UPGRADE THE FUEL PUMP, the stock pump sucked!! this aeromnotive 340 made my shit feel way better, i was def running a bit low pressure for a year
94073899_10158138921119556_5549292673522728960_o by david bellomo, on Flickr
with the new engine at work and my car in the driveway i did some matrix shit and managed to get everything lined up. i bought a 37 degree flare tool (not 45 degree brake line) and flared the stock lines to AN, utilizing a tube nut this is a quality way to ditch all rubber hoses and is safe and secure.
i always remove the pan - engine right side up, and replace main seals and thermostat when putting any motor of mine in
i replace the timing belt but not the timing components or water pump.. its a toyota dude. im just a tech of 10+ years whatever dont listen. plus its a hella easy to work on later and check for other actual problems.
92912212_10158101493224556_42579180491112448_o by david bellomo, on Flickr
92755407_10158101493139556_8017581658087620608_o by david bellomo, on Flickr
return style now, much better. i love how i got the K&N adapter and the stock lines 37 degreed flare. that filter is like 10 bucks to change later, GM power steering an adapters are what i used to convert the filter to AN
92572794_10158101492994556_7437629269171240960_o by david bellomo, on Flickr
new motor going in, i had to drive my 7.5 liter f250 for like 2 freagin weeks getting 1mpg
93473302_10158127522519556_8284326348671942656_o by david bellomo, on Flickr
started a Facebook 240sx beams swap page find it for more info or others interested if u want
-David Bellomo
David B S12 is offline   Reply With Quote
Old 03-17-2019, 02:47 PM   #2
[240sx]
[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute
Holy hell this is awesome. Running/driving vids PLEASE!! I wanna see a 9k pull.!!
[240sx] is offline   Reply With Quote
Old 03-17-2019, 04:43 PM   #3
David B S12
No no no. Its shy of 8k rpms. Typo
I will get a video soon!! I just have been babying it since startup no major pulls but maybe once or thrice so far. Need to finish torque pro and checking a few other things out. It's got a pretty nasty idle when warm and sprung a coolant leak on the back of the head from install maybe. Work in progress but yes once its concluded and the new muffler is on I'll be posting some videos !!
Old 03-18-2019, 08:42 AM   #4
[240sx]
Originally Posted by David B S12 View Post
No no no. Its shy of 8k rpms. Typo..
Oh... well then nevermind. *unsubscribed*
kidding.
Old 03-18-2019, 04:27 PM   #5
David B S12
Loool.
Today I fixed the coolant leak. The stock muffler is so hideous it sounds like a Honda. Stay tuned for street pulls on my way to work sometime soon
Old 05-18-2019, 08:16 PM   #6
Jacob Butler
Jacob Butler is an unknown quantity at this point
Do you have an Instagram?
Jacob Butler is offline   Reply With Quote
Old 05-19-2019, 07:27 PM   #7
kanyedian
kanyedian's Avatar
kanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nice
Nice intake sound! Cool swap
kanyedian is offline   Reply With Quote
Old 05-19-2019, 07:28 PM   #8
kanyedian
kanyedian's Avatar
Loool.
Some Hondas sound nice!
Old 05-23-2019, 02:56 PM   #9
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
IIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfection
Feedback Score: 22 reviews
Very, very interesting!
There are two BEANS powered S-chassis builds on Zilvia now!
IIIXziuR is offline   Reply With Quote
Old 05-26-2019, 09:48 PM   #10
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
The startup video was hilarious. I couldn’t even tell it was on until you twisted the throttle body.
collegekid is offline   Reply With Quote
Old 05-27-2019, 12:27 PM   #11
kanyedian
kanyedian's Avatar
Haha. #SixMufflersGang
Old 06-06-2019, 06:53 AM   #12
David B S12
So I've been busy getting ready for US Drift with one of my 1jz cars. This is still my daily but work on it as sort of halted. I have probably put 3k miles on it so far who knows. I drive this almost every day. In the next 2 months or so I will get back on it and start putting some more parts on the car and start the body work once the comp is over.
Old 06-06-2019, 06:54 AM   #13
David B S12
Originally Posted by jacob butler View Post
do you have an instagram?
@bellomotorsports
Old 07-21-2019, 04:30 AM   #14
jr_
jr_ is an unknown quantity at this point
Ok this build is going to be epic. When do you expect it to be fitted/on the road?
jr_ is offline   Reply With Quote
Old 08-06-2019, 10:44 PM   #15
David B S12
It's been on the road for months. But idk what happened to the pictures.
Old 12-22-2019, 02:18 PM   #16
rgnhd
rgnhd is an unknown quantity at this point
Any chance you could repost the pictures? I'd love to see the build
rgnhd is offline   Reply With Quote
Old 01-02-2020, 02:22 AM   #17
Wykydtron
Wykydtron's Avatar
Wykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really nice
images are all broken...
@schassis.eddi
Wykydtron is offline   Reply With Quote
Old 11-23-2020, 10:23 PM   #18
David B S12
IM BACK - to fix this stupid shit. im sorry lol, i am going to upload whatever pictures i find and redo the whole first post
did some arms awhile back, the ebay ones were eroding and threatening my life
67570382_10157358495659556_332342739708411904_o by david bellomo, on Flickr
i recently finally painted her, after 5 years of procrastination i took roughly 120 hours to get the body straight (to my standards) and painted 1G3 Toyota Magnetic Gray, the most common and my favorite daily driving color
122029044_10158653402899556_2499523798719947373_o by david bellomo, on Flickr
122015044_10158653402939556_2901867058274321650_o by david bellomo, on Flickr
122147412_10158653403334556_5555714902837384271_o by david bellomo, on Flickr
122025087_10158653403374556_1688558474401826840_o by david bellomo, on Flickr
122129725_10158653403199556_5423206402610783262_o by david bellomo, on Flickr
121784089_10158653403159556_6993821280844533493_o by david bellomo, on Flickr
121777957_10158653403274556_5247818082783947914_o by david bellomo, on Flickr
121807449_10158653403779556_8091601173544015898_o by david bellomo, on Flickr
122094625_10158653403879556_3401244362363196298_o by david bellomo, on Flickr
122064481_10158653404744556_8351540250409910146_o by david bellomo, on Flickr
so many photos, where am i
121672763_10158653404374556_76469508727194625_o by david bellomo, on Flickr
122003785_10158653404444556_8958072179155249561_o by david bellomo, on Flickr
121782175_10158653404004556_3761122865182084305_o by david bellomo, on Flickr
121648285_10158653404614556_144633253303312239_o by david bellomo, on Flickr
122131781_10158653404069556_4913284671811360460_o by david bellomo, on Flickr
122141770_10158653405584556_1371855513816904519_o by david bellomo, on Flickr
121705447_10158653405074556_4741712971655805297_o by david bellomo, on Flickr
121703593_10158653405154556_7661412692763508453_o by david bellomo, on Flickr
122048666_10158653405654556_7162388801108869758_o by david bellomo, on Flickr
custom 3d print
122143972_10158653404829556_4866686453904266131_o by david bellomo, on Flickr
122043503_10158653404969556_2203407669812340502_o by david bellomo, on Flickr
121775698_10158653405464556_1448164461077919310_o by david bellomo, on Flickr
121963064_10158653407169556_2554455745340572807_o by david bellomo, on Flickr
121822937_10158653405289556_3635471810825316562_o by david bellomo, on Flickr
121736036_10158653405979556_487400493026493019_o by david bellomo, on Flickr
[img]https://live.staticflickr.com/65535/50640578236_62b65f6376_b.jpg[/img
121625259_10158653406084556_2553655156811713768_o by david bellomo, on Flickr
121697976_10158653405714556_3241499135425556860_o by david bellomo, on Flickr
my neighbors got to taste the car
122061662_10158653406214556_6032659983169135177_o by david bellomo, on Flickr
121820851_10158653406699556_397822977998379618_o by david bellomo, on Flickr
122138800_10158653407214556_1776116481968670087_o by david bellomo, on Flickr
R & I Bitchessss
121778547_10158653407259556_6969694513105704142_o by david bellomo, on Flickr
121793793_10158653407584556_3308381614328338228_o by david bellomo, on Flickr
cutt and buff - 3m perfect it line
received_347298936378532 by david bellomo, on Flickr
received_2710800255809227 by david bellomo, on Flickr
20201028_184359 by david bellomo, on Flickr
received_360528592038806 by david bellomo, on Flickr
received_652358675669585 by david bellomo, on Flickr
cleaned the bay up a bit, and then i dyed the headliner while it was out for dent removal ( i dropped the sunroof)
IMG_20201024_171728_938 by david bellomo, on Flickr
20201027_194636 by david bellomo, on Flickr
Old 11-24-2020, 01:17 AM   #19
David B S12
finally closing the door on the body but still got some small things like a new sunroof seal and whatever the F i feel like doing, got a photoshoot done last weekend randomly after cars and coffee.
new motors been good all year, doesnt leak a drop, and feels alot better then the old G1
Thanks @photosby_jtb
IMG_1423 by david bellomo, on Flickr
IMG_1420 by david bellomo, on Flickr
IMG_1414 by david bellomo, on Flickr
IMG_1435 by david bellomo, on Flickr
IMG_1443 by david bellomo, on Flickr
IMG_1475 by david bellomo, on Flickr
IMG_1472 by david bellomo, on Flickr
IMG_1474 by david bellomo, on Flickr
IMG_1471 by david bellomo, on Flickr
IMG_1465 by david bellomo, on Flickr
IMG_1506 by david bellomo, on Flickr
IMG_1492 by david bellomo, on Flickr
IMG_1489 by david bellomo, on Flickr
IMG_1490 by david bellomo, on Flickr
IMG_1488 by david bellomo, on Flickr
Old 11-24-2020, 02:35 PM   #20
PoorMans180SX
PoorMans180SX's Avatar
We need more videos!
3sge, beams, hell, yea
