Old 11-12-2018, 05:34 PM   #1
gary556
gary556 is an unknown quantity at this point
Question Need help! fuel pump not working?
My fuel pump went bad so I replaced it with a Walbro fuel pump. I followed this guide to find my problems.
http://zilvia.net/f/showthread.php?t=108545
This is my problem now:
I followed this part of the guide:
"Check your fuse pump relay. Remove the relay. When you look at the pins of the relay, each pin is labeled with a number. Use a paper clip and jumper the 1 and 3 terminal on the wiring. If your fuel pump comes on with ignition, you have a bad relay."
I own a 1993 240sx that is manual swapped
Now that I have a working fuel pump, it won't get power. When I jumped terminal 1 and 3 with some alligator clips, it now gets power. I checked my relays and they are all working perfectly. But if jumping it with a clip gets it power, it couldn't be a wiring issue, could it?
I have no idea what the problem could be now, all opinions, input, or questions will help.
EDIT: Just checked the Voltage of the relays and all of them are getting 12.0+ volts while the one giving me problems is getting only 11.5V. Do the relays absolutely need 12V to trigger?
gary556 is offline   Reply With Quote
Old 11-12-2018, 06:58 PM   #2
anthony_240
anthony_240's Avatar
anthony_240 is an unknown quantity at this point
You also won’t get power to your pump and distributor if you have a bad eccs relay which on the s14 is right by the ecu, not sure about s13 and also there should be an efi fuse that will also affect power. Good luck
anthony_240 is offline   Reply With Quote
Old 11-18-2018, 08:59 AM   #3
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
How did you test the relays?
The Game
you lose haha
kyral is offline   Reply With Quote
Old 11-18-2018, 09:54 PM   #4
anthony_240
Test light. Or if you don’t have one, switch it with a known working relay
Old 11-20-2018, 04:31 PM   #5
apex
apex's Avatar
Trader Rating: (44)
apex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfection
Feedback Score: 44 reviews
Had the same problem
Mine ended up being the wire on top of the pump
Came off
I think there 3or 4 wires top of the fuel pump
Assembly
Red Rocket
apex is offline   Reply With Quote
Old 11-20-2018, 05:17 PM   #6
240KA
240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice
my fuel pump wouldn't prime when i would key on
come to find out, one of the wires on the underside of the fuel pump hanger was loose. the 3 or 4 wires under there look like they're riveted on from factory (i only glanced at them while the homie soldered the connection), but they resemble a rivet. solder the loose connection and fuel pump would prime again.
240KA is offline   Reply With Quote
Old 07-05-2020, 05:02 PM   #7
gue399108
gue399108 is an unknown quantity at this point
I have this issue. The wires on top of the fuel pump sending unit, the black one came off but I went to go ground it to the screw of the cap and pump won’t turn on. Any suggestions?
gue399108 is offline   Reply With Quote
Old 07-05-2020, 05:51 PM   #8
S14rebuild
The black one needs to be connected to the pump that is the ground.
fuel pump, s13, wiring
