Old 08-11-2018, 07:18 PM   #1
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
0 oil pressure at idle
So my oil pressure at idle drops to 0 once the engines warmed up.
im thinking its the sending unit for my gauge though cause the engine seems very happy and I beat the shit out of it. I cant hear any knocking or any noises youd hear with no oil pressure. you can let it idle for an hour no problems
just wondering if anyone else has experience a sending unit failure like that before and if they are common
The Game
you lose haha
kyral is offline   Reply With Quote
Old 08-13-2018, 08:04 AM   #2
tuzzio
tuzzio's Avatar
Its cheap insurance to replace it. I wouldn't risk it.
Old 08-13-2018, 09:19 AM   #3
Standard
Standard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud of
I had the same thing happen on another car. Once warmed up if I came to a stop the pressure would drop to 0, replaced the oil pressure switch/sending unit and the problem went away.
Standard is offline   Reply With Quote
Old 08-14-2018, 08:15 AM   #4
jedi03
+1 on bad sending unit...I looked at my cams to see oil flowing...it was frustrating as mine also had a beep when it fell below 1 PSI...
Old 08-21-2018, 06:20 PM   #5
kyral
kyral's Avatar
sounds like sending unit failure for oil pressure gauges is fairly common.
I also noticed the gauge needle seemed to kind of stick a little shortly before it failed
like I said I didn't hear anything out of the ordinary so I can say with confidence its an oil sending unit failure
The Game
you lose haha
