Old 06-01-2018, 08:32 PM   #1
BigChance
BigChance is an unknown quantity at this point
Cool FS: Seattle, WA S chassis Packrat/hoarder garage sale blowout!
Please text for quickest response 206.658.36 seven eight
Suspension/Brakes
BNIB S13 Control Arms - $60/pair
Used S13 Control arms -$30/pair
S13 LCA with Villains 40mm Extensions - $ 60/pair
Driver side S13 LCA - $10
S13 Knuckles without calipers - $60
S13 Knuckles with calipers - $80
S13 Tension Rod Brackets - $60
RHD S13 Steering Rack w/pump - SOLD
RHD S13 steering Rack - SOLD
LHD S13 Steering Rack (needs new hard lines) - $60
S13 Solid steering spacer - $10
S13 Rear Calipers w/e brake cables - $80
S13 Front calipers - $60/pair
S13 Passenger Side Front caliper - $20
S13 Rear Calipers (no provisions for stock e brake) - $40/pair
S13/S14 rear caliper parts box - $20
S13 handbrake cables - $40/pr
S13 handbrake handle - $20
S13 welded diff (whines a bit) - $40
S13 diff cover (pictured on S14 diff) - $10
Z33 (350z) Handbrake cables - $40
S14 Control arms - $80/pair
Passenger side S14 control arm - $20
S14 New Single front 5 lug hub - $60
S14 Single rear 5 lug hub - $60
S14 Knuckles - $100
S14 Tension Rod Brackets - $80
S14 Front Crossmember - $80
S14 5 Speed Non-ABS Driveshaft - $60
S14 Brake Booster with master cylinder - $60
S14/S13 rear caliper parts box - $20
S14 handbrake cables w/mounting brackets - $60
S14 welded diff - SOLD
S14 handbrake handle -$20
Interior
S13 dash with all underdash parts, dashbox and bezels (non A/C) - $180
RHD S13 dash (also have all underdash parts with A/C stuff) - $180
S13 window amp - $20
S13 hatch trunk release w/cable - $40
Complete S13 hatch chassis harness (underdash and interior) - $200
S14 Dash - $80
S14 driver side window switch w/bezel - $40
S14 passenger side door handle (no window switch) - $free
S14 underdash harness (not sure if kouki or zenki)- $60
Kouki S14 wiper/light switch - $20
Engine
S13 SR20DET coil pack harness w/coils - $80
S13 throttle cable - $20
S13 KA24DE distributor - $60
S13 alternator bracket (not sure if KA or SR) - $20/ea
S13 SR water neck - $20 (can weld fitting on for addl $20)
KA/SR throwout bearing w/sleeve- $20
KA/SR clutch fork - $20
SR coil pack - $5ea
S13 SR stock flywheel - $20
S13 SOHC power steering reservoir- $5
S13 DOHC power steering reservoir -$10
Apexi BOV - $10
S13 DOHC KA engine harness - $40
S14 throttle cable - $20
S14 KA24DE distributor - $60
S14 KA valve cover - $20
S14 SR oil pan with rear main seal plate - $60
S14 SR rust free Turbo manifold w/heatshield - SOLD
S14 fuel pump w/sender - $20
S14 SR (no rods/pistons,no valve cover, no turbo- head is toast-comes with many extras) -$200
STI 550cc injectors w/adapter harness - SOLD
Exterior
S13 Door hinges - $20
S13 hood latch - $20
S13 hatch trunk latch (chassis side)- $20
S14 Driver side Door w/glass (no window regulator) - $60
S14 door glass - $40/pair
S14 trunk latch (chassis side) - $20
18x9 +40 SSR Type C (very light!) *5x120* - $200/pr
20180514_195136 by BigChance, on
Flickr
20180514_195133 by BigChance, on Flickr
20180514_195131 by BigChance, on Flickr
20180514_195126 by BigChance, on Flickr
20180514_195120 by BigChance, on Flickr
20160920_212456 by BigChance, on Flickr
20180522_182057 by BigChance, on Flickr
20180522_182053 by BigChance, on Flickr
20180522_182002 by BigChance, on
Flickr
20180522_181651 by BigChance, on
Flickr
20180522_181647 by BigChance, on Flickr
20180522_181643 by BigChance, on Flickr
20180522_181634 by BigChance, on Flickr
20180522_180917 by BigChance, on Flickr
20180522_180908 by BigChance, on Flickr
20180522_180850 by BigChance, on Flickr
20180522_180844 by BigChance, on Flickr
20180522_180841 by BigChance, on Flickr
20180522_180837 by BigChance, on
Flickr
20180522_180833 by BigChance, on Flickr
20180522_180817 by BigChance, on Flickr
20180522_180808 by BigChance, on
Flickr
20180522_180757 by BigChance, on
Flickr
20180522_180751 by BigChance, on
Flickr
20180522_180747 by BigChance, on
Flickr
20180522_180720 by BigChance, on
Flickr
20180522_180715 by BigChance, on
Flickr
20180522_180711 by BigChance, on
Flickr
20180522_180702 by BigChance, on
Flickr
20180522_180658 by BigChance, on
Flickr
20180522_180654 by BigChance, on
Flickr
20180522_180651 by BigChance, on
Flickr
20180522_180646 by BigChance, on
Flickr
20180522_180642 by BigChance, on
Flickr
20180522_180632 by BigChance, on Flickr
20180522_180601 by BigChance, on
Flickr
20180522_180556 by BigChance, on Flickr
20180522_180535 by BigChance, on
Flickr
20180522_180532 by BigChance, on
Flickr
20180522_180529 by BigChance, on
Flickr
20180522_180525 by BigChance, on Flickr
20180514_195216 by BigChance, on
Flickr
20180514_195210 by BigChance, on
Flickr
20180514_195206 by BigChance, on
Flickr
20180514_195204 by BigChance, on
Flickr
20180514_195158 by BigChance, on
Flickr
20180514_195154 by BigChance, on Flickr
20180514_195144 by BigChance, on Flickr
BigChance is offline   Reply With Quote
Old 06-01-2018, 08:36 PM   #2
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
Is the throttle cable a DOHC or SOHC? And how far are you from Covington?
nisileighty is offline   Reply With Quote
Old 06-01-2018, 08:40 PM   #3
2jzgte240sx
2jzgte240sx is an unknown quantity at this point
Just text you about the s14 window switch
2jzgte240sx is offline   Reply With Quote
Old 06-02-2018, 05:34 AM   #4
PDavis40
PDavis40 is an unknown quantity at this point
I suppose shipping would be crazy expensive on that RHD dash
PDavis40 is offline   Reply With Quote
Old 06-02-2018, 07:10 AM   #5
johnnypvrk
johnnypvrk's Avatar
johnnypvrk is on the path to ruinjohnnypvrk is on the path to ruin
S13 rhd racks non hicas?
If no issues I’ll take them
johnnypvrk is offline   Reply With Quote
Old 06-02-2018, 09:12 AM   #6
BigChance
Bump. PM'd you all about the rhd stuffs.
Old 06-02-2018, 10:07 AM   #7
signal240sx
signal240sx is an unknown quantity at this point
Sent text on s13 diff
Sent from my VS501 using Tapatalk
signal240sx is offline   Reply With Quote
Old 06-03-2018, 02:48 PM   #8
BigChance
Up to the top
Old 06-04-2018, 12:39 AM   #9
KevinEdgar
KevinEdgar's Avatar
KevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to all
Subscribing for that RHD dash Incase I ship my Silvia home. Noncracked? Can’t tell too well from pics. Thank you.
http://milktea-man.com
KevinEdgar is offline   Reply With Quote
Old 06-04-2018, 10:08 PM   #10
BigChance
KevinEdgar yes it is uncracked
Old 06-04-2018, 11:01 PM   #11
Sk33zy
Sk33zy is an unknown quantity at this point
Still have the s14 driver side window switch? Price shipped to 90744 please
Sk33zy is offline   Reply With Quote
Old 06-08-2018, 10:01 AM   #12
BigChance
Bump to the top, some parts sold
Old 06-12-2018, 08:30 AM   #13
BigChance
bump to the top
Old 07-03-2018, 07:06 AM   #14
BigChance
Bump some parts sold
ka24de, s13, s14, sr20det, z33
