Old 03-06-2018, 01:26 AM   #1
jtull22
jtull22 is an unknown quantity at this point
KA KA24DE cranking but not starting
So I own a 1995 240sx. I was driving and all of a sudden I started losing power until it died. Ever since it will crank but not start. So it’s cranking but not starting “turning over.” It’s getting fuel because it will shoot a mist of gas out when the spark plug is removed. It’s getting spark because the plugs arc when grounded to the bay or block. It sucks in air through the intake so it’s getting air. It just won’t fire. The timing is at least close to being right because it will spark as soon as the most of fuel comes out. It will even ignite it. Just will not when everything is buttoned up. I have read all other posts about this and nothings seeming to work. Even thought maybe it was flooded so we've ran it without the pump to clear it out and nothing we have done has made a difference. I've gotten a new distributer cap and spark plugs as well. Ideas?
jtull22 is offline   Reply With Quote
Old 03-06-2018, 05:52 AM   #2
Shaker.Est.84
Shaker.Est.84 is an unknown quantity at this point
Did your alternator die?
Sent from my SM-G930W8 using Tapatalk
Shaker.Est.84 is offline   Reply With Quote
Old 03-06-2018, 09:00 AM   #3
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
When is the last time you replaced your ignition coil
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Old 03-06-2018, 10:52 AM   #4
jtull22
I haven’t replaced it. Also now that we check I am currently not getting spark. Could a bad distributor produced spark but not let the car start but then completely not work?
Old 03-06-2018, 08:49 PM   #5
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Start with a coil before you go to the distributor.
You can also check your cap and rotor too.
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 03-07-2018, 07:23 AM   #6
CrispKouki
CrispKouki's Avatar
CrispKouki will become famous soon enoughCrispKouki will become famous soon enoughCrispKouki will become famous soon enough
Sounds like a bad distributor or bad wiring, had that problem on mine.
CrispKouki is offline   Reply With Quote
240sx 240, ka24de 5 speed manual, zenki 240sx 1995
