Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 12-09-2017, 11:08 AM   #1
RodRodRacing
RodRodRacing is an unknown quantity at this point
Pro-Series Fabrication Dual Caliper Bracket Fitment Issue
Hello there,
My car is a Basic 2003 Z.
I'm using OEM calipers for both pairs on the rear.
After putting everything back together the extra calipers don´t fit right.
The calipers there were already in the car work fine after the dual caliper brackets were installed. I used the 35mm bolts and the spacers to install them.
The problem are the extra calipers. They lock the rotors. The bracket of each caliper touches the rotor and it get stuck.
The extra calipers came from a 2006 350z. They look slightly different in design but the same in dimensions.
I´m also using OEM brake pads.
Even without the pads the extra calipers lock the rotors.
The weirdest thing is that everything is aligned.
2003 OEM Caliper using spacers > Dual Caliper Bracket > 2006 OEM Caliper
Have anybody faced the same problem? Or could give me some help?
Thanks.
RodRodRacing is offline   Reply With Quote
