Old 11-02-2017, 05:34 AM   #1
DieselTime
DieselTime is an unknown quantity at this point
R34 LS1 swap question
Hey all,
I'm looking to swap an LS1 into my R34. Before anybody gets up in arms, it's a non-turbo RWD model, so don't stress about me "ruining a perfectly good RB" etc. My issue is, there's no kits out there that I know of to help with installation. Therefore I'm thinking of using an S14 engine crossmember in order to use the SIKKY or similar mount kit, which should accommodate the oil pan, engine mounts etc. Was just curious as to whether anybody knew whether or not the engine crossmember is a straight swap between the R34 GT and S14 models.
Thanks in advance
DieselTime is offline   Reply With Quote
Old 11-02-2017, 07:07 AM   #2
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
I feel like Ryan Gordner would know the answer to this since he LS swapped his R32. Atleast find out what crossmember will bolt in or what mounts to use. Facebook messaged him to check this thread out.
onehundredoctane is offline   Reply With Quote
Old 11-02-2017, 10:58 AM   #3
Knuckshaft
Knuckshaft is an unknown quantity at this point
I’ve swapped 3 r32s with Ls motors. Check out my Facebook or Instagram. Both @ryangordner
Knuckshaft is offline   Reply With Quote
Old 11-03-2017, 08:40 PM   #4
DieselTime
Thanks boys.
Thought it'd be worth putting out there, I got in contact with Fueled Racing over in the US who are pretty popular for their S-chassis LS swap kits. The guy there says that due to pretty rubbish oil pan clearance in the R34 it's a solid plan to use the engine crossmember from an S14 as they actually make a kit to suit R-chassis cars using the S-chassis k frame. They also offer over 60 transmission options that you can special order, meaning they've pretty much got everything you'd realistically need for a straight engine swap. I'll be looking to purchase from them by hopefully January so I'll keep yall posted on how that turns out.
Old 11-03-2017, 10:55 PM   #5
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
How is ruining a perfectly good rb not "ruining a perfectly good RB"?
This LS bs has gotten too far...
Tuners are big bullies
feito is offline   Reply With Quote
Old 11-04-2017, 02:55 AM   #6
DieselTime
I mean it's an NA version making maybe 150hp and is an absolute pain to turbo, so you know, I'd say it's a reasonable idea.
ls1, r34, s14, sikky, swap
