Old 05-25-2017, 01:36 AM   #1
Eoken
Eoken is an unknown quantity at this point
S13 DOHC Digital Cluster + Harness and projector
SOLD SOLD SOLD!
Working condition. The plastic cover has been polished but has slight scratches. the cluster was repaired by super wow factory about 2 years ago and worked fine for me all this time.
there is a strange thing about this cluster that I noticed... The back lights will flicker if you do not make sure that the harness is facing right when you install the unit into the car. It sounds weird but I was able to get it to not flicker at all by doing this. I think one of the contacts for the harness that plugs into the back of the digital speedo is bent or not clean or something. anyways when you install it turn on the back lights and wiggle the plug so you know what position it likes then install it so the nearness points that way. Pretty simple and it worked like a charm.
like I said it is just a contact issue, the unit has been tested. I used it for a long time without any issues.
If you are interested I can also put the pictured yellow needle tach in the cluster if you prefer it over the white.
*NOTE* the actual mileage will be 255661
$200 +shipping
text me at 51 two 9 one 3 nine 762
Eoken is offline   Reply With Quote
Old 06-07-2017, 10:37 AM   #2
Eoken
bump back up for sale!! whole set up for $200 only
Old 06-10-2017, 03:53 AM   #3
faiz100
faiz100 is an unknown quantity at this point
Hey u still got it
faiz100 is offline   Reply With Quote
Old 06-10-2017, 11:55 PM   #4
mrdrift408
mrdrift408 is an unknown quantity at this point
will this work on a dualcam motor?
mrdrift408 is offline   Reply With Quote
Old 06-11-2017, 09:11 AM   #5
jduke
jduke is an unknown quantity at this point
lol yes, that's why he stated it's a dohc cluster
jduke is offline   Reply With Quote
Old 06-11-2017, 10:38 AM   #6
Eoken
sold, thanks for viewing guys!
240sx, digital cluster, heads up display, hud, s13
