Old 04-29-2017, 08:44 AM   #1
Billcriss
Billcriss is an unknown quantity at this point
RB25 Squeak
I have a completely stock RB25. Motor is used in my drift car only, that being said when I purchased it I installed a new timing belt. Greddy one, I made sure I could twist the belt 45 degrees so I wasn't too tight or too loose. Car runs fantastic BUT at low idle it will have this squeak coming from the belt area? Any idea what this is? Or if I should worry? When I get the RPMs up it goes away. Just wanting to know what's going on before I push more power. Thanks for the help.
Billcriss is offline   Reply With Quote
Old 04-29-2017, 09:03 AM   #2
RB25GUY
RB25GUY's Avatar
RB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to all
too tight maybe!
Originally Posted by smellslikecurry View Post
Its not like you're putting a safc in a fucking Tesla.
RB25GUY is offline   Reply With Quote
Old 04-29-2017, 09:28 AM   #3
tb13
tb13's Avatar
tb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to behold
Did you replace the tensioner and idler pulleys?
tb13 is offline   Reply With Quote
Old 04-29-2017, 09:29 AM   #4
Billcriss
Originally Posted by RB25GUY View Post
too tight maybe!
That was my original thought so I checked again and unless it needs to be more than 45 degrees than it's good
Old 04-29-2017, 09:30 AM   #5
Billcriss
No I did not. Would this cause it to squeak at low idle only ?
Old 04-29-2017, 09:51 AM   #6
tb13
tb13's Avatar
Very possible, If the bearing was failing it could make noise. If you pull the belt back off, spin both idlers, they should give some resistance when you spin them, if they spin freely like a skateboard wheel would or you can feel more resistance at a certain point you need to replace both. I'd also suggest you replace the bolt that holds the stationary idler in place, they are known to snap.
Old 04-29-2017, 03:00 PM   #7
Billcriss
Is it possible to check without pulling the belt? Or do you know of an easier way to do it except pulling the harmonic pulley
Old 04-29-2017, 03:05 PM   #8
tb13
tb13's Avatar
Put the motor at TDC, remove tension from the belt, pull the belt off the cam gears, spin both idlers. You'll need both front timing covers off to do it. Make sure that you realign the belt before you put it back on too.
Old 04-29-2017, 03:14 PM   #9
Billcriss
Alright man I'll get on that. Any idea how far you should be able to turn the belt?
Old 04-29-2017, 03:21 PM   #10
tb13
tb13's Avatar
Usually I make sure I can't twist it completely parallel to the front of the motor, but there is a find line between too tight and too loose, its hard to explain typing. Really don't think it is an issue with the belt being too tight, usually a super tight belt will whine at all rpm
Old 04-30-2017, 11:39 PM   #11
Sileighty_85
Sileighty_85's Avatar
cant go wrong with OEM
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-30-2017, 11:58 PM   #12
bfellini
bfellini is an unknown quantity at this point
This!
bfellini is offline   Reply With Quote
Old 05-02-2017, 05:52 PM   #13
Billcriss
Old 05-02-2017, 05:53 PM   #14
Billcriss
This was absolutely as much as I could turn it. Is this too right ?
