Old 04-06-2017, 09:29 AM   #1
clydesfstbk
clydesfstbk is an unknown quantity at this point
KA TDC # 1 cylinder
Hello people I sent a question on the position of #1 cylinder as it looks without head, doing a head gasket now on KA24E and turned crankshaft couple of times to clean cylinders and oil cylinder walls. I just want to confirm that # 1 cylinder should be at vert top of engine block
:2f2f
clydesfstbk is offline   Reply With Quote
Old 04-06-2017, 11:36 AM   #2
gaz_moose
gaz_moose is an unknown quantity at this point
TDC = #1 cylinder at the top of the cylinder on the inlet stroke.
gaz_moose is offline   Reply With Quote
Old 04-06-2017, 01:46 PM   #3
clydesfstbk
s13 TDC # cylinder
Is that the same as # 1 cylinder at very top of block or engine
:2f2f
Old 04-10-2017, 07:56 PM   #4
p00t
p00t's Avatar
p00t is an unknown quantity at this point
Every cylinder has a "TDC". Piston at the top of it's stroke, as high as it can go.
TDC#1 is just that... on the first cylinder...
Current Crazy: KA with SR56 and meth injection for HDPE and steet duty
p00t is offline   Reply With Quote
Old 04-11-2017, 10:00 AM   #5
clydesfstbk
s13 Top Dead Center
Thank you so much that makes total sense, very easy in those terms I've had to pull my top end off ( water issue) so we did head gasket checked everything, oil not grey or foamy hopefully it's not my front cover ! You can still get those new if you want on a KA24E SOHC THANKS AGAIN
:2f2f
please help
