02-19-2017, 02:32 PM | #1 |
Sr20det piston rings on ca18det
I was wondering if sr piston rings would work on a ca. I just need one set of rings and I don't find it necessary to buy a whole set of rings if i can just use some old ones i have laying around. Sorry if this is a stupid question but i just need to know. Thank you
Sent from my SM-G550T1 using Tapatalk |
02-20-2017, 08:44 AM | #4 |
if you force a 87mm bore piston ring into an 83mm bore it will have massive excess ring pressure on the bore,
it will get super hot from the pressure/drag/friction from being over stressed into a smaller bore it will soon crack/break the ring likely break piston ring lands and ruin the bore just get a set of piston rings for a CA18,at $50/60? and chance it will last a lot longer |
02-20-2017, 08:54 AM | #5 | |
02-20-2017, 12:37 PM | #6 |
http://www.perfectengine.com/Hasting...has-2c4221.htm
I was $9 short,Hastings are made in US so probs get them direct for less? I got a set for a toyota 4 banger delivered in UK for £55 japan made NPR rings are cheaper slightly,but hastings has a better oil control ring design |
