Old 02-06-2017, 08:25 PM   #1
Kingtal0n
Kingtal0n's Avatar
help me finish my fuel system because I am newb
Hello fellow zilvians,
I need some experienced advice.
The last thing on my list for the new car is fuel system. I've never seen or used "posh loc" style hose before and I need to know more about how to use it correctly.
1. I want to know if I can use this hose
http://www.ebay.com/itm/3-8-Syntheti...ZXjsy5&vxp=mtr
and clamp it directly onto the factory feed and return lines, and if not, how to go about doing that.
2. Next, I want to know if this barb fitting
http://www.ebay.com/itm/BLUE-3-8-bar...FUwSi3&vxp=mtr
which just says "barb" can be used somehow, and if the push loc line wont clamp to the factory feed/return, then I can use basic rubber fuel hose with these barb fittings in an aeromotive regulator to fuel the engine.
And finally ,
I want to use this regulator
http://www.ebay.com/itm/Aeromotive-1...torefresh=true
With some 6-an fittings, either push loc, or basic barb, unless you experienced have another regulator in mind (I've never bought a regulator before, always used OEM stuff). This is for LSx application 600~bhp.
tinyurl.com/4l80er
Old 02-07-2017, 08:04 AM   #2
tuzzio
tuzzio's Avatar
Buy the regulator from an authorized dealer...replicas exist.
Old 02-07-2017, 11:43 AM   #3
Kingtal0n
Kingtal0n's Avatar
Good advice, what do you think of it here
http://www.ebay.com/itm/401228408594
Many sold good feedback, usually ok
I bought some barb fittings for the time being, and I bought a couple feet of pushloc hose to play with. The barbs will help me fuel the engine with regular rubber hose for now; when I figure out how the pushloc stuff works I will switch over to it. I've never had to setup an aftermarket regulator, well, almost. One time about 13 years ago I setup an aftermarket regulator on an EFI V8 setup in my backyard. I used braided hose though. I wanted to avoid hose ends because the real deal are very expensive, and I dont trust the chinese hose ends with fuel.
Seller responded:
"yes sir, we are 100% direct warehouse for Aeromotive.
I'd just call them up www.aeromotive.com and verify with
them. "
Old 02-07-2017, 02:18 PM   #4
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
You mean AN fittings? Take a look at summit's own fittings, they're made in America and reasonably priced. I'm not one to like running shiny silver/blue/red hoses and fittings everywhere but I used their stuff for my oil cooler lines and turbo lines for the past 4 years with no issues. They also come in black
pacotaco345 is offline   Reply With Quote
