01-28-2017, 08:58 AM | #1 |
How much can I increase the fuel pressure?
rb25de(t) swapped s13 (10:1comp)
Factory injectors, factory rail, AEM universal fpr, precision 3431 turbo factory ecr33 ECU (afaik) I'm running in the red at NOT on the wideband. If I blip the throttle afr'a dip down to 16 the back to red. It has a misfire- coil pack harness is on the way. There's only a 4 lb spring in the gate and I'm just trying to drive this thing to a dyno. How much can I increase my fuel pressure at the rail to hep bring down my afr before I start risking damage to the injectors? They were flow tested and are a healthy consistent set. I also don't plan on using these injectors I have another set of DW's |
01-28-2017, 11:11 AM | #2 |
Your misfire could be a lean misfire and have zero to do with actual wiring.
Increase to 4bar(59psi) on your pressure regulator if your pump can do it.
01-28-2017, 03:26 PM | #3 |
haha, if you saw the harness it came with you would want it gone regardless. The rest of the harness is brand new and I'm not about to skimp on the coil harness. Got a WS one for 29$ anyway.
The harness showed up today, so on Monday I'm gonna go out and put the AEM universal fpr on with the new harness and I'll crank it no higher than 4 bar. What is the reasoning behind the 4 bar suggestion? |
01-28-2017, 03:55 PM | #4 | |
01-28-2017, 04:33 PM | #5 |
The wideband has hardly seen any use. Spent a lot of time in the box until it was Installed. I never thought to check its calibration being brand new. It's 12 inches back from the turbine. I have a set of 740cc deatchwerks but I thought that might be overkill. I guess I could always run the pressure lower?
01-29-2017, 12:05 PM | #7 | |
I would bin the redrilled injectors for a better set. DW injectors for the SR/KA do not have the best track record. Running lower fuel pressure won't compensate for the added increase in fuel flow you'll add by installing the 740's. They are double the size as factory. You'll go from "full lean" to "full rich". Calibrate the wideband and go from there.
01-29-2017, 05:46 PM | #8 |
It's an AEM UEGO - doesn't need calibration. I'll double check the one in there with one of my others. Hopefully it's actually running fine and that sensor is what's wrong.
