Old 01-26-2017, 05:57 PM   #1
PNW_S13
PNW_S13 is an unknown quantity at this point
Unhappy Wiring help
I just put all new 6.5 inch speakers in my 1991 240sx and it was all fine and they all worked until i turned the volume past 20 then the sound cut and i cant hear sound anymore like everything is on and the speaker like pop when i turn the car on so i think they still work fine and the head unit still turns on and works fine just no sound. The first thing i did is get a new head unit and i installed it but but still no sound now i'm stuck and have no idea what to do please help. P.S I looked for factory amp because i believed that is was just blown but i couldn't find it so i'm very lost
PNW_S13 is offline   Reply With Quote
Old 01-26-2017, 08:01 PM   #2
jedi03
http://zilvia.net/f/showthread.php?t=66156 start there maybe?
Old 01-27-2017, 07:28 AM   #3
S-Verteen
S-Verteen is an unknown quantity at this point
Maybe check to see if the wires in the speaker are grounding to the basket. Had that happen to me before and i just bent them a little.
S-Verteen is offline   Reply With Quote
Old 02-08-2017, 03:50 AM   #4
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Did you use the factory speaker wire connections/? or did you wire the speakers directly up from the head unit?
radio, wiring
