Old 01-05-2017, 05:11 PM   #1
MR_GUTTI
MR_GUTTI's Avatar
MR_GUTTI is an unknown quantity at this point
RB neo timing ignition is driving me CRAZY!!!
Im finishing my RB25det NEO and I'm stuck trying to set up the ignition timing. First the mods.
Freddy plenum
Fmic
Stock turbo
Stock Maf
Iacv
Boost solenoid
Stock throttle body
Walbro fuel pump
Fuel regulator set to 36psi idle 42psi wot
Stock injectors
Wiring specialist harness
I already test the tps,cas, Maf, temp sensor and everything is ok. I double checked the mechanical timing and is onpoint.
So I let the engine warm up (idle around 700rpm) turn it off, I disconnect the tps, start again rpms jump to 900 at idle. With my timing light connected and moving my cas I can retard it all the way (counterclockwise) and get 25*. I can't reach the 15*.
The vacuum is almost 20 inhg at idle so I believe I don't have a leak, my fuel ratio is at 14.7
On my Nissan data scan show 5* timing. If I try to rev the engine fast it bogs and if I do it slow is ok. On my data scan I can run the base idle adjustments setting which automatically set the timing to 15* and revs perfect. After that the timing goes back to 5*.
Any help will be appreciated
Thanks!!
Timing marks:
Setup:
MR_GUTTI is offline   Reply With Quote
Old 01-05-2017, 09:42 PM   #2
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
Is the plate on the cas on backwards?
GO DUCKS!!!!!!!!!
Juantwo3 is offline   Reply With Quote
Old 01-07-2017, 06:36 PM   #3
MR_GUTTI
MR_GUTTI's Avatar
Can you please explaining further. Thanks!
Old 01-07-2017, 10:02 PM   #4
Juantwo3
Juantwo3's Avatar
If you take the cas cover off it has that disc looking thing with slots on it, it has like a half moon shape slot it can be put on backwards accidently
GO DUCKS!!!!!!!!!
Old 02-08-2017, 06:16 PM   #5
MR_GUTTI
MR_GUTTI's Avatar
Updated!!! I was able to set the cas to 15* but the Ecu keep making adjustments all the way to 5*. I'd try connecting the neutral sensor to the ecu but I was worse. I tested the knock sensors and are ok.
Old 02-08-2017, 06:19 PM   #6
MR_GUTTI
MR_GUTTI's Avatar
Help please!!!!!!!
Old 02-11-2017, 06:05 PM   #7
240sxfriendly
240sxfriendly's Avatar
240sxfriendly is an unknown quantity at this point
had a issue like this, turned out to be the knock sensor harness. worth taking a look.
240sxfriendly is offline   Reply With Quote
Old 02-12-2017, 12:18 PM   #8
Juantwo3
Juantwo3's Avatar
Did it woirk ou for you?
GO DUCKS!!!!!!!!!
Old 02-15-2017, 01:12 PM   #9
MR_GUTTI
MR_GUTTI's Avatar
I already check the cas and is property install, also I check the wiring for the knock sensor and is fine as well.
Thanks for the help guys!! Keep the ideas coming please!
Old 02-15-2017, 01:14 PM   #10
MR_GUTTI
MR_GUTTI's Avatar
I just test the VVT solenoid and is opening and closing with 12v
Old 02-15-2017, 01:19 PM   #11
MR_GUTTI
MR_GUTTI's Avatar
It have to be a sensor or the ecu itself that is messing me up. When I use my consult (datascan) and run the base Idle it runs perfect!!!! Can a bad iacv mess my timing?
Old 02-19-2017, 09:36 AM   #12
MR_GUTTI
MR_GUTTI's Avatar
Does anyone has a r34 gtt ecu for sale?
neo, rb25, rb25 cas, timing
