Old 09-16-2016, 12:53 PM   #1
reflexdb
reflexdb's Avatar
reflexdb is making a name for him/her selfreflexdb is making a name for him/her selfreflexdb is making a name for him/her self
Send a message via AIM to reflexdb
1995 Nissan 240SX S14 Kouki SR20DET Slicktop
I am ready to part ways with my 1995 Nissan 240SX, which has passed Colorado emissions testing and has a clean title. It is ready to take to the track as-is for high performance driving events. Optionally have a roll cage fitted for wheel-to-wheel racing, or re-install interior and HVAC for a daily driver. Has been owned (since 2003) and built by a mechanical engineer and Nissan enthusiast. Only 111,500 miles on the chassis, which is quite low for a 21 year old vehicle.
This S14 starting life as a manual transmission, base model Zenki slicktop, without sunroof, which makes it essentially the lightest and stiffest S14 chassis available. After the front driver's side fender was hit while the vehicle was parked, I swapped the fenders, hood, lighting, and headlight supports over to the OEM JDM Kouki (1997-1998 style) parts. After daily driving it through 2007, I started building it into the track-ready car it is today. I removed the KA24DE engine and fitted the period-correct S14 SR20DET engine and transmission. I upgraded the fuel pump with an OEM Z32 (300ZX twin-turbo) part, not a typical Walbro part. Has only been run at 12psi (fitted with an HKS wastegate actuator) with is well within the stock turbo limit. The engine is running on the OEM ECU, which is to say that it runs perfectly at any altitude. I eliminated all unnecessary interior components and sound-deadening material to minimize weight. HVAC and power steering systems have been deleted.
Stance Al+Pro coilovers allow height and dampening adjustment (as well as spring rates by swapping springs). Car has been corner weighted with driver, with a total wet vehicle weight of 2,375lb and 52.4%/47.6% front/rear weight distribution. Wheels and tires have been sized to maximize grip while maintaining OEM steel fenders. They are...
5Zigen FN01R-C 17x8 +25 w/ Dunlop Direzza Z1 Star Spec 235/40R17 (front)
5Zigen FN01R-C 17x9 +35 w/ Dunlop Direzza Z1 Star Spec 255/40R17 (rear)
This car has been a blast to build and drive, but I simply don't have the time to enjoy it anymore. I'd love to see it go to another enthusiast who will take good care of it, as I have.
I have a complete parts list on Google docs and a folder full of receipts which will be given to the new owner.
Drivetrain
S14 SR20DET and 5-speed manual transmission
Nismo Engine/Transmission Mounts
Greddy Aluminum High-Capacity Oil Pan
Xcessive Front Steel Skidplate
HKS Manual Wastegate Actuator
Z32 Twin Turbo OEM Fuel Pump
Intake
Blitz SUS Power Intake
GReddy Hotpipe
GReddy R-SPL Frontmount Intercooler (24R-HG Core)
Exhaust
Tomei Stainless Turbo Elbow w/ SO2 bung
Blitz Stainless 3" Downpipe
Catco 3" High Flow Cat (will also include DME Stainless 3'' Test Pipe)
Blitz Realize TT-R Full Stainless Cat-Back Exhaust
Cooling
Koyo Aluminum Radiator
New OEM Fan, Fan Clutch and Fan Shroud
SAMCO Radiator Hose Set (Black)
Brakes
Wilwood Forged Superlite Calipers/Pads and 2-piece Rotors (Front)
Cross-Drilled Rotors and Hawk Performance Pads (Rear)
Stainless Steel Lines
Tokico Z32 17/16'' Brake MC
Suspension/Wheels
Stance Al+Pro Coilovers (9/7 kg/mm front/rear spring rates)
SPL PRO v2 Tension Rods (Black)
OEM 5-Lug Hubs
ARP +15mm/+20mm front/rear Wheel Studs
Muteki SR48 Black Open End Lug Nuts
Nismo Power Brace
GReddy Front Strut Tower Brace
Solid aluminum Rear Subframe Mounts/Bushings
Steering
OEM Rack, Modified for Power Steering Deletion
SPL Polyurethane Rack Bushings
OEM Z32 Inner Tie Rods
SPL V5 Outer Tie Rods
Body/Aero
Repainted in original Blue Emerald (FN2) by True Performance in Plain City, Ohio, May 2009 (includes limited lifetime warranty)
JDM Front and Rear Bumpers/Valences
Drift Armor Front Bash Bar (powdercoated semi-gloss black)
OEM Kouki Headlights and Taillights
VIS Carbon OEM-Style Hood
Aerocatch Plus-Flush Hood Latches
Interior
2 x Status Ring FRP Cloth Racing Seat on Nagisa/Nams Auto Super Low Seat Rails
2 x Sabelt Steel Pro 6 Point Harness
Mazworx S14 Harness Bar (Wrinkle Black)
Nardi Classic Deep Corn 350mm Wheel
NRG Version 2.5 Quick Release and Short Hub
Kognition Design Carbon Radio Delete Panel
Electrical
Braille B2015 Lightweight AGM Battery (mounted behind passenger seat)
Functional Kill Switch
Stack Pro Stepper Motor Boost Gauge
Please PM me if you are interested and have any questions.
Current (as well as some older) photos can be viewed on Google photos album here:
https://goo.gl/photos/gLgGBVF3faxBuaFF8
Asking price: $11.5K (Or Best Offer)
reflexdb is offline   Reply With Quote
Old 09-17-2016, 09:26 PM   #2
reflexdb
reflexdb's Avatar
I may also be interested in trading for a 350Z...
Old 09-17-2016, 11:10 PM   #3
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Car looks like a great build!
However, can we get a readout of the actual vehicle weight?? Last I checked, a full interior SR S14 weighs about 2700-2800 lbs without driver (wet weight). Last I weighed mine with SR and all accessories, with me in it it weighed in right at 3100 lbs (I am 205). I am having a hard time seeing this weighing 500-700 lbs less without some serious lightweight parts ( I still see the stock glass for instance). That is NC miata territory!
Also, can you publish the full parts list for the public to view. May save you some headache in the end.
GLWS!
Old 09-19-2016, 10:56 AM   #4
reflexdb
reflexdb's Avatar
Thanks for the questions RalliartRsX. I've updated my original post with the full list of parts. I've got the corner weighting sheet at home, I'll scan it and add it to the Google Photos album later tonight or tomorrow. Regarding the weight, I agree that a stock 1995 240sx should weigh in around 2800 lbs without driver. This is a non-sunroof base model car though, so I'd expect it started off a bit lower. All of the interior and sound deadening material has been removed, besides the dash, center console and door panels. All of the HVAC and power steering components have been removed. Even the wire harness has been minimized to save weight. Since corner weighting, I've only added the front bash bar and skidplate, which maybe weigh 50lbs total. I'd imagine that this is one of the lightest S14's out there today.
Old 09-19-2016, 08:10 PM   #5
reflexdb
reflexdb's Avatar
Corner weight readout (weight includes me in car, 170lbs), alignment details, and paint warranty info added to Google Photos album.
Old 09-19-2016, 09:42 PM   #6
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
I have a Z for trade
text me 9792366891
Old 09-20-2016, 11:16 AM   #7
reflexdb
reflexdb's Avatar
PM and text sent, rawgarage.
Old 09-27-2016, 12:39 PM   #8
reflexdb
reflexdb's Avatar
Price has been lowered! Accepting offers.
Old 10-03-2016, 09:23 AM   #9
reflexdb
reflexdb's Avatar
Throw me some offers, otherwise I'll end up parting it out.
Old 10-03-2016, 06:08 PM   #10
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
it would be a sad day if this gets parted
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 10-15-2016, 07:42 AM   #11
reflexdb
reflexdb's Avatar
I agree! Weekend bump! Also interested in S2000's.
Old 10-15-2016, 03:56 PM   #12
cjsjodin
cjsjodin is an unknown quantity at this point
What's the new price?
cjsjodin is offline   Reply With Quote
Old 10-16-2016, 08:54 AM   #13
reflexdb
reflexdb's Avatar
$11.5k OBO
Old 10-17-2016, 08:28 PM   #14
corbin
corbin is a well-known jackass
Would love to autocross this a few times - wish more S14s were built like this. They are really, really good grip platforms.
corbin is offline   Reply With Quote
Old 10-18-2016, 12:03 PM   #15
reflexdb
reflexdb's Avatar
Thanks for the positive comment corbin! I think so too.
Old 10-22-2016, 08:22 AM   #16
reflexdb
reflexdb's Avatar
Weekend bump!
Old 10-27-2016, 11:06 AM   #17
silents1ick
silents1ick is an unknown quantity at this point
Super nice.... intersted in trades by any chance?
http://zilvia.net/f/showthread.php?p...09#post6128809
silents1ick is offline   Reply With Quote
Old 10-27-2016, 11:09 PM   #18
slamn240
slamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the rough
I got a z for trade
slamn240 is offline   Reply With Quote
Old 10-28-2016, 10:07 AM   #19
reflexdb
reflexdb's Avatar
I appreciate the offer, and it looks like a very well-done Z. But, I'm looking for essentially a stock one. Thanks anyways and GLWS!
Old 10-28-2016, 10:07 AM   #20
reflexdb
reflexdb's Avatar
Originally Posted by slamn240 View Post
I got a z for trade
PM sent...
Old 10-30-2016, 10:36 AM   #21
TheLastLatin
TheLastLatin is an unknown quantity at this point
if only I wasn't married. GLWYS. Bump
TheLastLatin is offline   Reply With Quote
Old 10-31-2016, 09:01 AM   #22
reflexdb
reflexdb's Avatar
FYI...I have a set of OEM Kouki seats that match the door panels. I can swap those in if the buyer would prefer instead of the bucket seats.
Old 11-05-2016, 11:50 AM   #23
ino20
ino20's Avatar
ino20 is an unknown quantity at this point
SO nice, I wish you wanted a turbo miata instead of a Z :P
Racingl
ino20 is offline   Reply With Quote
Old 11-05-2016, 12:29 PM   #24
Austinyang86
Austinyang86 is an unknown quantity at this point
only if u live in california ill buy it
Austinyang86 is offline   Reply With Quote
Old 11-08-2016, 02:56 PM   #25
Jeffjansen19
Jeffjansen19 is an unknown quantity at this point
Pm sent, i have an ls swapped rx8 up for trade.
Jeffjansen19 is offline   Reply With Quote
Old 11-24-2016, 12:14 PM   #26
reflexdb
reflexdb's Avatar
Turkey Day BUMP
Old 12-21-2016, 09:09 AM   #27
reflexdb
reflexdb's Avatar
Sold! Thanks for all the interest everyone!
Old 12-21-2016, 02:37 PM   #28
golfer17
golfer17's Avatar
golfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nice
Send a message via AIM to golfer17
Nice build. Very similar to mine. Congrats on the sale!
golfer17 is offline   Reply With Quote
kouki, manual transmission, s14, slicktop, sr20det
