Old 06-21-2016, 01:09 PM   #1
sherlockhomeboy
sherlockhomeboy's Avatar
sherlockhomeboy is an unknown quantity at this point
RB Running a compression test without the Intercooler fully hooked up
Sorry if this is a stupid question, but I've been searching around and haven't really found a direct answer.
I'm looking to buy an rb20det from this guy and am going to run a compression test on it today, however at this moment the intercooler piping isn't all fully connected. Would this throw off the compression test at all?
Definitely willing to connect all the piping as it's not much work at all but just curious if having the intercooler not fully hooked up would it lead to an inaccurate compression test?
Thanks
sherlockhomeboy is offline   Reply With Quote
Old 06-21-2016, 01:51 PM   #2
greenwood
greenwood's Avatar
greenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymore
not needed for compression test.
Have him do with throttle open.
greenwood is offline   Reply With Quote
Old 06-21-2016, 01:52 PM   #3
Kingtal0n
Kingtal0n's Avatar
No it will not have any affect.
When you compression test, make sure you WRITE DOWN THE NUMBER. Make it as EXACT as possible like this: 132.5, 137.0, 134.0, 135.5
Each cylinder should be very close in reading, very little variation. ALL Of them need to be close together within a few psi of each other.
tinyurl.com/4l80er
Old 06-21-2016, 07:23 PM   #4
sherlockhomeboy
Awesome thanks guys
Old 06-21-2016, 11:37 PM   #5
heychris
heychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura about
OP......Google is your friend....
Ch
sent from knee deep in snow
heychris is offline   Reply With Quote
Old 06-22-2016, 10:04 AM   #6
cotbu
cotbu's Avatar
Take all the spark plugs out and crank it freely first, you want to be able to listen.
unless you are going to buy the engine based on compression numbers alone.
compression testing, intercooler, rb20det, turbo
