Old 06-09-2016, 11:53 AM   #1
richmond82
richmond82's Avatar
Trader Rating: (30)
richmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura about
Feedback Score: 30 reviews
Haltech Platinum Pro ECU SR20DET,Jun SR Flywheel, Navan 3 piece S14 wing Cusco 2 WAY
JUN S13/S14 Ultralightweight flywheel
$100 + Shipping or Trade for Wideband Gauge and Sensor.
8.5/10 condition $100 + Shipping or trade for Wideband Gauge and Sensor
Cusco RS 2 Way in S15 Case with 3.63 Ring and Pinion
Came directly from Blue 808 former FD driver Luke Lonberger. RS has 2,000 miles on it since new. Only using Kaaz LSD fluid. Cusco RS is a 3 way adjustable diff by changing the locking pin. You can have a 1 way, 1.5 way and full 2 way. Currently set to 2 way with 100% accel and decel lock set $700
Bought brand new through Haltech. Link Engine Management sponsor will be replacing the Haltech for 2016 and beyond. The unit works flawlessly. If i had 2 s15 motorsets I would keep it. The unit has about 2,000 miles of use. Would like to sell for $1,000
Features:
• Direct plug and play replacement of the OEM ECU, no re-wiring necessary.
• Uses the cars factory sensors
• Supports Sequential Injection (peak and hold) and Direct fire ignition
• Windows 2000, XP, Vista, Windows 7 compatible software
• Real time programming, instant hesitation free adjustment while engine is running
• Fully user definable 32 x 32 mapping
• Tuning via Volumetric Efficiency (VE), Injection time or Lambda Correction (MAF)
• Diagnostic trouble code storing & Check engine light control (Access through laptop only )
• Selectable onboard internal MAP sensor rated to 150kPa (up to 1.5 Bar or 22psi boost)
• Wideband “auto tuning” using user definable target AFR table
• USB and CAN Communication Port
Factory Outputs:
• 4 x Fuel Injector outputs
• 4 x Ignition outputs
• N-VCT ( Nissan Variable CAM Timing Control)
• Tacho, Boost Control, AC Clutch Relay, Idle Control
• Thermo Fan, Check Engine Light, Fuel Pump,
Factory Inputs:
• MAF sensor, Throttle Position Sensor, Knock Detection Sensor,
• Coolant Temperature sensor, Vehicle Speed Sensor,
• Oxygen Sensor
Expansion I/O*:
• 2 x Analogue Voltage inputs
• 2 x Analogue Temperature inputs
• 4 x Digital outputs
*Optional auxiliary harness required to be purchased Haltech Part # HT040003
Functions:
• Closed Loop O2 Control
• Decel Cut Over Boost Rev Limiter
• Closed & Open Loop Boost Control
• Gear Setup
• ACF On Base Tables
• Transient Throttle Enhance
Correction Tables: Fuel Ignition Boost:
• Cranking
• Air Temp Target Correction
• Zero Throttle Gear Correction
• Cylinder Trim
• TPS Correction
• Generic Correction 1
• Generic Correction 2
• Gear Correction
• Post Start
• Air Temp Duty Correction
• Post Start
Miscellaneous:
• Data Logging: 448Kb of onboard data logging, Storage for approx 40 minutes at 10 logs per seconds,
6 channels of data
• Max 20 channels logging capability
• Tune can be password protected in software
• Rugged anodized aluminum casing
Power Requirements:
Source: 8.6 to 16.5 Volts DC
Consumption: 530mA @ 12Volts DC
Physical Dimensions:
ECU Dimensions Length: 154mm (174mm with MAP nipple)
Width: 158mm Height: 42mm Weight: 680g (1.5 lb)
Applications:
Nissan Silvia S15
Transmission:
Manual only (Automatic not supported)
The Kit includes:
Pro Plug-in ECU, USB Cable, Programming Software CD, Quick Start Guide, Instruction Manual (on CD)
Drake: 95 Swapped S15SR Z32 Swapped TT 1991Vert
Last edited by richmond82; 06-23-2016 at 01:33 PM.. Reason: adding more parts and info to ad
richmond82 is offline   Reply With Quote
Old 06-09-2016, 01:41 PM   #2
slow92
slow92's Avatar
slow92 is an unknown quantity at this point
pm sent
msg
Sr22 in the works
slow92 is offline   Reply With Quote
Old 06-15-2016, 07:23 AM   #3
richmond82
richmond82's Avatar
Trader Rating: (30)
bump all still available. looking for Wideband and Sensor in trade for flywheel or navan 3 piece wing
Old 06-23-2016, 01:33 PM   #4
richmond82
richmond82's Avatar
Trader Rating: (30)
Price lowered on navan wing, Cusco 2 Way and Jun flywheel
Old 01-12-2017, 07:48 PM   #5
herroTruong
herroTruong is an unknown quantity at this point
paypal ready for Jun flywheel
herroTruong is offline   Reply With Quote
Old 01-13-2017, 05:46 AM   #6
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Can you clear your inbox OP.
Old 11-04-2017, 12:10 PM   #7
richmond82
richmond82's Avatar
Trader Rating: (30)
All Sold please lock up
240sx, aem, drift, haltech
