Old 03-28-2016, 02:02 PM   #1
salemmotorsports
salemmotorsports is an unknown quantity at this point
s14 1996 240sx S14 SR20DET $8K
•Clean title
•S14 sr20 swap done right (by previous owner): Replaced all gaskets and seals, intake manifold, Tomei exhaust manifold, etc. No leaks At all.
•New Cometic metal head gasket, new ARP head studs, resurfaced head, new oil pump and oil pressure sensor, and Circuit Sports rocker arm stoppers
•T28 Turbo
•Wiring harness by wiring specialties
•Greddy FMIC and piping with new HKS SSQV
•SPEC stage 2 clutch
•New clutch master cylinder ss clutch line and slave cylinder
•DriveShaft Shop aluminum driveshaft
•Koyo aluminum radiator
•Altima dual e-fans
•Full 3" turbo back Exhaust
•Crimestopper alarm
•Kyb Shocks and Tein springs and rear window bar
•New oil pan, transmission cross member and clutch pedal from Nissan
•B&M short shifter
•New Enkei rims
•Q45 front brakes with SS brake lines and new stock rear calipers, brembo front rotors
•Boost, water temp, and A/F gauges
•5 lug hub conversion all around
•HID headlights
•Registration just paid
Has a clean smog check history. Smog check for transfer will be responsibility of the buyer (we will sign paperwork documenting this). Everything on the car works only thing that could use work is the paint. If the post is still up then the car is still available. $8000 obo
salemmotorsports is offline   Reply With Quote
240sx, clean, manual, s14, sr20det
