Old 02-02-2016, 12:54 AM   #1
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
12mm lift cams too aggressive for stock valve terrain?
I'm curious on if 260 tomei pon cams with at 12mm lift is too aggressive for stock valve springs?
If so, would this be the best option for springs?
http://www.mazworx.com/store/ShopCart.aspx
Drift team page
www.facebook.com/savageimpression
Options13 is offline   Reply With Quote
Old 02-02-2016, 01:00 AM   #2
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Tomei tells you as much when they sell you procams
Originally Posted by FRSport
We only carry Poncam as a 256 IN / 256 EX combo. Anything other duration is considered as the Procams, which requires valve spring changes for higher lifts.
Old 02-02-2016, 01:08 AM   #3
Options13
Options13's Avatar
Trader Rating: (43)
i called mazworx today, and they said it would be fine to run stock springs, as long as i'm on hydraulic lifters.
Just trying to get second opinions.
I wish i could score a deal on some JWT's
Drift team page
Old 02-02-2016, 04:29 AM   #4
cotbu
cotbu's Avatar
I like 10.5 to 11.2~5 for stock valve train. That would mostly be used with 256 to 264 duration cams.
Sent from my SM-N910T3 using Tapatalk
Old 02-02-2016, 05:53 PM   #5
Kingtal0n
Kingtal0n's Avatar
These days you have to attach a number when you say "stock springs"
i.e. "brand new stock springs"
or
"stock springs with 150,000 miles"
If you have worn out stock springs with high mileage, then at least change them for some new unit. As you dig deeper into a head, you "might as well do things while you are in there" like change the guides, do a valve job, etc.. so a recommendation to change springs must be coupled with an existing engine state (mileage is a factor)
Old 02-02-2016, 07:08 PM   #6
Options13
Options13's Avatar
Trader Rating: (43)
At this rate I'm either going to upgrade my springs to super tech double springs or jwt s3 cams.
The mileage on my stock springs are unknown. I had BC springs on the head but I'm gonna get rid of those, I think they are too stiff, I threw a rocker arm so I wanna prevent that from happening, so maybe a less aggressive cam, or good quality springs.
Drift team page
