Old 02-01-2016, 05:18 PM   #1
daoby
daoby is an unknown quantity at this point
Ka24de s14 ***needing base map for or help answer some questions.****
Okay so I have a mildly built ka24det that's wired to an aem v1. My question was what did your map bar's engine load read when the car was off but the ignition is on and how did you wire up the map bar? I did the 49 power, 50 ground, and 66 signal. Sooo far its reading -4.53ish and has the same reading when the car is idling. (3.5 map bar)
Any help would be greatly appreciated and I will pay for a base map just to start my car. I have already called aem and they don't have anymore support for the v1.
daoby is offline   Reply With Quote
Old 02-04-2016, 07:18 AM   #2
Gorman240
Gorman240's Avatar
Gorman240 is an unknown quantity at this point
Let me know what kind of Map sensor you are using. Is it an AEM 3.5 P/N 30-2130-XXX style? I can also help you out with a base map just to get the car started, what kind of injectors are you running?
Gorman240 is offline   Reply With Quote
Old 02-04-2016, 11:39 PM   #3
daoby
Its a 50psi 3.5 aem map bar with bosch 1000cc top feed
Old 03-01-2016, 05:30 PM   #4
daoby
Bump anyone??
aem ems, aem map bar, base map, ka24de, ka24det
