Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Intake & Exhaust
Old 01-25-2016, 04:05 AM   #1
phase2
phase2's Avatar
phase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of light
P2m proprietary aluminum hose clamps now available in red finish!
Please visit our web page for product details
Business Hours: Mon-Fri 10am-6pm (Pacific)
email: [email protected]
http://www.phase2motortrend.com
phase2 is offline   Reply With Quote
Old 01-25-2016, 10:24 AM   #2
fatduece
fatduece is an unknown quantity at this point
Very nice!
fatduece is offline   Reply With Quote
Old 01-27-2016, 06:53 AM   #3
TheRealSy90
TheRealSy90's Avatar
I found out that these cannot be used on cast aluminum elbows that are commonly welded to compressor housings and intercoolers. They have a larger outer diameter. :'(
Such a good signature.
Old 01-27-2016, 09:06 PM   #4
phase2
phase2's Avatar
What is the size of the cast aluminum elbow? Even then, shouldn't the elbow be connected to silicone hose coupler?
Old 01-27-2016, 09:13 PM   #5
TheRealSy90
It didn't work on a 3" id, 2.5" id or a 2" id elbows that I have welded to my intercooler tanks (3" cold side, 2.5" hot side), and compressor housing (2"). With the P2M black couplers on the elbows, I had to squeeze the clamp to get the bolt to reach the other side, and then the little aluminum piece that one side of the clamp is supposed to slide over wouldn't work correctly because of the pressure on it already.
These were cast elbows from China. The clamps still work where my couplers are on regular aluminum piping though. Maybe using a larger clamp would work but I haven't tried? But there isn't one larger than 3".
A quarter inch over sized would probably work. But the 3" wouldn't tighten enough on the 2.5" cast elbow+coupler. The larger outer diameter of the cast elbows kinda messed up my plans
Old 01-27-2016, 10:04 PM   #6
phase2
phase2's Avatar
I see what you mean now, the cast elbow pushes the silicone hose out of range. That's very possible now that you mentioned this. For instance, a 2.5" ID elbow maybe a 2.75" clamp will work?
Btw, we are wrapping up releasing the 3.25" clamp as we speak, so that will probably work on your cast elbow setup on the 3" ID side.
Keep the clamps on your hand, if needed we can exchange the clamps out for you but we need to find out what size range work for your aluminum cast elbow.
Old 01-28-2016, 02:50 AM   #7
TheRealSy90
That's exactly what I was thinking, stepping up the size on the three clamps that are on cast elbows. I THINK a 2.75 would work on the 2.5, 3.25 on the 3", 2.25 on the 2" etc.
I didn't think I would be able to exchange the ones I can't use since I opened them and I don't have the plastic packaging anymore :/
Aside from everything the clamps that did fit are awesome and I love how it makes the piping look. I like to tuck the bolt on the bottom so the black on black looks like I don't even have clamps at first!
Old 01-28-2016, 03:25 AM   #8
phase2
phase2's Avatar
No problem, let us know the clamps you need wr will prepare for your testing and exchange, no worries on the packaging
Sent from my SM-G928T using Tapatalk
Old 01-28-2016, 05:11 AM   #9
TheRealSy90
Awesome thank you! I'm in Hawaii for work right now but I should be back home in a week or so. Should I message you through here when it comes time, or through email?
Old 01-28-2016, 05:43 AM   #10
phase2
phase2's Avatar
Either ways are fine with us!
