Old 01-22-2016, 11:13 AM   #1
240si
240si is an unknown quantity at this point
s13 Need Rust Advice
Im very close to buying this 91 hatch Sr Black top swapped, but the issue is this rocker panel rust.. In PA it needs to be inspected within 10 days of registration and I'm not sure how serious this will be to fix any thoughts are appreciated thanks
File Type: jpg 12549042_10154470171434307_8534717251640255185_n.jpg (71.1 KB, 50 views)
240si is offline   Reply With Quote
Old 01-22-2016, 11:16 AM   #2
iJDM
iJDM's Avatar
iJDM is an unknown quantity at this point
A lot of these cars have that same rust problem.
Personally, I think it would be a pain in the butt to fix, properly. Keyword properly...
You may want to try to source some aftermarket side skirts and slap those on. Or at least see if that will be enough to cover your inspection
1990 s13 hatch sr20det
2001 Lexus is300
iJDM is offline   Reply With Quote
Old 01-22-2016, 11:18 AM   #3
240si
Would this be a structural issue being unibody?
Old 01-22-2016, 11:57 AM   #4
timandytimandy
timandytimandy is an unknown quantity at this point
Thats not bad at all. If you don't want to get it fixed correctly (welded) you could just bondo it for inspection or just wait to register the car. If you plan on running side skirts it won't matter how pretty any repair it and I'd be more concerned with how the frame rails look.
timandytimandy is offline   Reply With Quote
Old 01-22-2016, 12:25 PM   #5
zenkicpe
zenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud of
In PA you have 10 days to inspect the car and drive it legally. You can wait longer than 10 days but you will risk getting pulled over on the way to the inpsection station. Its not like the cops are going to come take your car if you dont have it inspected in 10 days.
As for the rust, Cut that shit out with a cut off wheel or sawzall or plasma cutter depending on how baller you are. Make sure its all nice and clean, wipe down with wax and grease remover. Then you could either have it welded, or bondoed and that will get you past inspection. I wouldnt let a rust spot like that stop me from scooping it up. Good luck.
zenkicpe is offline   Reply With Quote
Old 01-22-2016, 12:36 PM   #6
OBEEWON
OBEEWON's Avatar
Sell it.
char
Old 01-22-2016, 12:36 PM   #7
KAT-PWR
KAT-PWR's Avatar
You can not bondo that. Patching is a must
MRP Manufacturing
Old 01-22-2016, 12:39 PM   #8
zenkicpe
If we are talking regular meduim weight body filler then I agree.
Have you ever used long strand bondo? I have, it may not be pretty but it will cover that hole with some metal mesh backing it up. Pass inspection and then do it right while fixing all the other little things that need to be done.
Old 01-22-2016, 12:51 PM   #9
240si
So that 10 days is basically a grace period to drive the car and get it fixed? I can still register it now and fix it in the spring and inspect it?
Old 01-22-2016, 01:07 PM   #10
240si
Seems to be clean for PA besides that one spot
Old 01-22-2016, 01:11 PM   #11
zenkicpe
Correct, you can drive it/have it parked on road legally uninspected for 10 days. If its in your garage or off the street you can have it inspected anytime.
For example I bought my zenki in early march 2015, didnt have it back on the road until the end of august 2015. Got it inspected in the beginning of October 2015.
Old 01-22-2016, 01:40 PM   #12
yacubkep
yacubkep is an unknown quantity at this point
That is a easy repair compared to what i found under some side skirts on my 240.
Someone with a nice welder could fix it in a couple hours.
yacubkep is offline   Reply With Quote
Old 01-22-2016, 01:57 PM   #13
EnnEssEnnKAT
EnnEssEnnKAT's Avatar
EnnEssEnnKAT can only hope to improve
I don't know if it's the same there, but in NH you get that same 10 days. If you go for inspection, and fail, they give you a partial inspection sticker that covers you for the time being and you have 60 days to return and pass the inspection. If PA has that, then you have 70 days total. good luck.
EnnEssEnnKAT is offline   Reply With Quote
Old 01-22-2016, 05:49 PM   #14
vincent_gibson
vincent_gibson's Avatar
vincent_gibson is an unknown quantity at this point
Pull the rust off, sand blast, spray it with etching primer (a few good coats) then if you can cut a peace of body seat metal out and spot weld a patch grind smooth them paint
vincent_gibson is offline   Reply With Quote
Old 01-22-2016, 07:27 PM   #15
KAT-PWR
KAT-PWR's Avatar
That is an entirely different fiberglass product all together.
MRP Manufacturing
Old 01-23-2016, 01:23 PM   #16
zurud
zurud is an unknown quantity at this point
I don't think body rust issue affect inspection. Inspection mostly deal with safety and emission.
zurud is offline   Reply With Quote
Old 01-24-2016, 01:30 AM   #17
Cortius017
Cortius017 is an unknown quantity at this point
+1 for patching instead of just filling it with bondo. If you plan on getting skirts to cover that up i say at least stop the rust one way or another. or just do what the truck guys do and fill it with expanding foam
Cortius017 is offline   Reply With Quote
Old 01-24-2016, 07:41 AM   #18
timandytimandy
Yes, a hole like that will fail a safety inspection. You guys really are making a big deal about this bondo vs patch thing. Anyone with half a brain knows you don't stuff a hole with bondo. Also expanding foam is a horrible idea, it holds water.
Don't ask questions, just go watch some videos and read some threads to find the best solution for you.
Old 01-25-2016, 12:12 PM   #19
zenkicpe
Guys the bondo suggestion was only to get him past inspection if he needed to within 10 days, correct way to fix, cut/clean/treat/weld. There is a time and place for quick fixes to get you by.
Old 01-25-2016, 12:22 PM   #20
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
Why are you making a big deal out of this?
Before you buy a swapped car, know that you will need to download the FSM and do a lot of research into maintaining a Sr swapped car.
That rust is a joke. If that is the only spot on the car then you are lucky. I doubt it. Jack the car up and look everywhere, in every nook and cranny.
That shouldnt cost you more than $600 from a decent shop.
collegekid is offline   Reply With Quote
help a kid out, rust, rust repair
