Old 12-13-2015, 09:27 AM   #1
Turb
Turb's Avatar
Turb is an unknown quantity at this point
Wheel Shakes like a MOFO
So I just recently got another s13 coupe, and it drives perfectly straight right until I hit 50 mph then the wheel shakes like a MOFO, like I'm talking whole car shakes! Then right as I pass 57ish mph wheel doesn't move at all! I assume its an Alignment but thought I'd see if anyone has had any experience with this
Turb is offline   Reply With Quote
Old 12-13-2015, 09:50 AM   #2
pinkyrang
pinkyrang is an unknown quantity at this point
Your wheels may need to be balanced, I had a similar, but less severe issue. it went away after I got new tires and balance. Also do a visual inspection of your suspension arms and make sure nothing looks like totally out of whack
pinkyrang is offline   Reply With Quote
Old 12-13-2015, 06:49 PM   #3
jedi03
The rule of thumb I was given was below 60 is aligbment, above 60 is balance...random vibrations at constant speed is the tire coming apart internally
Old 12-13-2015, 07:24 PM   #4
Gingersmurf
Gingersmurf is an unknown quantity at this point
balance the wheels and get an alignment off the bat. chances are its a bit of both
KAs are like Frank's RedHot, Nissan put that shit in everything
Gingersmurf is offline   Reply With Quote
Old 12-13-2015, 07:24 PM   #5
beems240sx
beems240sx's Avatar
beems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant future
Usually low speed vibration is a separated tire. I had a similar issue with my s13 and it was the tension rod bushings.
beems240sx is offline   Reply With Quote
Old 12-13-2015, 09:24 PM   #6
Turb
Turb's Avatar
Thanks guys, lot of help! I just wanted to make sure I didn't have bad tie rods
Old 12-13-2015, 09:28 PM   #7
fatduece
fatduece is an unknown quantity at this point
Do you have wheel spacers? My front, left spacer started slowly getting loose and that sh8t was making my wheel wobble.
fatduece is offline   Reply With Quote
Old 12-13-2015, 10:06 PM   #8
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Tie rods
Steering rack bushings
Ball joints
Old 12-13-2015, 10:07 PM   #9
jedi03
That's scary! Look at your tie rods if they're torn up they are bad and get some tiens with inner spacers, it's an amazing drive after that!
Old 12-14-2015, 12:08 AM   #10
NismoDriverS13
NismoDriverS13 is an unknown quantity at this point
I would agree with previous post on the unbalanced wheels or tires. I had same issue before, drove to a shop, had wheels balanced and alignment and no problems after.
NismoDriverS13 is offline   Reply With Quote
Old 12-15-2015, 10:48 AM   #11
sleeper108
sleeper108 is an unknown quantity at this point
for shits and giggles, also take a look at your diff. I had the half shaft on one side start separating and it did the same thing. The vibration was so sudden and violent I couldn't tell if it started from the front or back
sleeper108 is offline   Reply With Quote
