Old 11-24-2015, 04:57 PM   #1
sentradude
sentradude is an unknown quantity at this point
Make your own custom A/C Hardlines
I want to make my own hard lines (existing look like ...., is this possible? If so:
1. Where can I get the material (Aluminum tubing??)
2. Can it be soldered or does it have to be welded (fittings)
3. Any other suggestions
sentradude is offline   Reply With Quote
Old 11-24-2015, 08:08 PM   #2
ultimateirving
ultimateirving's Avatar
Get some hardliners that are used and in good shape. Then take to Jon at future fab and tell him what you need. He can weld them and did mine
Z32 with lq4 swap
Old 11-24-2015, 08:09 PM   #3
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
The better question is, what are you trying to make do? Custom in general or custom because an option doesnt' exist?
For SR swaps, I make conversion brakcets that work with stock lines: www.sr20acbrackets.com
For LSX and RB there is a custom line guy as well. Let me know and we'll get ya sorted out!
Old 12-08-2015, 07:55 PM   #4
sentradude
Basically the line high pressure hot line looks crappy as it took me a few different approaches before figuring out how to run the line so now it looks bad. I would like to bend the new line to what the shape should be.
Old 12-08-2015, 08:35 PM   #5
JAStirrett
JAStirrett's Avatar
JAStirrett is an unknown quantity at this point
The lines have to be welded and welding A/C aluminum is not easy. It is very porous and with no experience I wouldn't waste the time. Do what ultimateirving said and go to a shop and tell them what you need.
I have a custom A/C line and what I had done was the large low pressure line going behind the block to the compressor comes out in 3 pieces. I had my guy use the elbow on the firewall and the fitting/reservoir that goes in to the compressor. He welded fittings on both ends and I have compatible A/C hose in between. Flexible enough not to piss you off when rerouting the line.
Good luck.
Oh and to add one more thing, I also use CodyAce's SR conversion brackets. Good stuff.
The addiction is real...
JAStirrett is offline   Reply With Quote
