Old 11-04-2015, 02:41 PM   #1
Aftermarke7
Aftermarke7's Avatar
Aftermarke7 is an unknown quantity at this point
Arrow Welded diff issue. Did this shop mess up ?!?! Videos and pics included ! Please help
Whats good every1.
I just had a local shop weld my diff.
I also just installed a 4.3 pinion and gear from an r32.
The problem is that I can't install the axle splines. I look down the spline well and I see weld that I am m guessing shouldn't be there? Seems like its causing the issue.
Is this the case. Did the welder fuck up or am I fucking something up here?
VIDEOS AND PICTURES BELOW !
The FIRST 4 Pictures show what I would assume are some pretty through welds. However the last 4 pictures show where I think the problem lies.
Let me know what you guys think, preferably from those individuals who have installed and/or properly welded diffs in the past.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
VIDEO ==> https://youtu.be/cxCv054HOeE
Aftermarke7 is offline   Reply With Quote
Old 11-04-2015, 02:59 PM   #2
bmxer882x
bmxer882x is an unknown quantity at this point
The shop messed up. The axle shafts go to about 1mm away from where that shaft with the gears is. It looks like they welded the plate to far in. I've never used those plates I just connect the gears.
Edit, cant get pics to load but look at how close the axle shafts are to the shaft with the gears is.
http://www.240-sx.com/welding-your-differential/
bmxer882x is offline   Reply With Quote
Old 11-04-2015, 03:07 PM   #3
TougeSR20Kid
TougeSR20Kid's Avatar
TougeSR20Kid has a little shameless behavior in the past
Edit: Nevermind, thanks to this guys pictorial ^^^^ I see what they did there. I'd take it back
Originally Posted by mantas View Post
One more thing - i hate your prius.
Namaste mother f**ker
TougeSR20Kid is offline   Reply With Quote
Old 11-04-2015, 03:42 PM   #4
Aftermarke7
You da man. Thankyou for the insight !
Tomorrow shall be a fun visit to the welder !,... ()
Old 11-05-2015, 01:42 PM   #5
Aftermarke7
Thumbs up
The shop is fixing their mistake, no questions asked.
LET THIS BE A WARNING TO ALL THOSE WHO CHOOSE TO HAVE THEIR DIFFS WELDED!
-MAKE SURE, if you use metal plates, THEY DON'T SIT TOO DEEP.
-MAKE SURE, NO WELD SEEPS PAST THE PLATES OR GEARS INTO THE CENTER OF THE DIFF.
That's all, have fun sliding !
240sx, diff, differential, drifting, welded
