Old 10-26-2015, 12:56 AM   #1
jvtec95
jvtec95 is an unknown quantity at this point
s14 1998 Nissan 240SX Kouki KA24DET Black/Black
For Sale 1998 Nissan 240SX SE KA24DE-T - Black/Black original paint
Manual, Moonroof, 5 lug, power everything
125,700 miles on car
Engine fully rebuilt at 115,000 miles (spun rod bearing) in summer of 2010 by previous owner, details below.
Car is sold!
I do still have the wheel/tire setup in the pics below, if interested PM me about them!
I bought this car and drove it to Madison WI from Grand Rapids MI in 2012, daily drove it for a summer and then bought an SUV for the winter. Since then I've driven it very little and have mostly been working on upgrading things on the car, as I intended to keep it. This was the cleanest kouki I could find in the midwest area, and I really hate to sell it but I really don't have the time to enjoy it. I'd rather someone who will appreciate and drive it, work on it, etc. would own it. I'm not desperate to sell and won't take low-ball offers, criticism, or advice. Not interested in parting out, selling the motor or shell, or removing components to change the price. Sorry, no trades, I'd rather have a garage with an open bay to work on some other projects I've got going on. Shipping is a possibility, but buyer has to arrange everything and all payment has to be verified/completed before picking up.
History:
Car was originally sold in Arizona, then spent some time in Ohio. Since going to Michigan in 2006 the car has only had about 30,000 miles put on it (less than 3,000 miles per year). Previous owner said he drove it some during 2 winters, but that's about it. I've put about 5,000 miles on the car and its been garaged the whole time, no winters at all.
The previous owner bought the car with the turbo kit (JGS kit) installed and drove it until spinning a bearing. He had the engine rebuilt completely with forged internals and a lot of upgraded parts. I bought it in winter 2012 and drove it that summer, parked it in the garage that fall and have been working on it ever since here and there, driving it minimally.
Body:
Original paint, no accidents, factory black. Paint is in great condition, I clay-barred and polished the whole car and have washed/waxed it religiously since. That being said, it is an 18 year old car and it does have minor flaws. There's a few dings here and there, a couple scratches that are visible, and some wear. I'm very picky, but honestly most of the "flaws" are very minor, especially considering what some people claim as a "clean" car. Most dents could be taken out with paintless dent removal, I planned on doing this but didn't get around to it. There is a scratch on the driver door that is through the paint, and both door handles show some chipping. The driver side skirt must have been replaced at some point, as it has some red paint showing through at the front by the wheel. I replaced the passenger fender because the original one was dented by the wheel well, was replaced with OEM steel part painted factory color professionally. Fenders have never been rolled or stretched.
Frame is clean and straight, very little rust, frame rails are solid. I was going to undercoat the car, but figured its better to be able to show people the actual condition (otherwise they'll assume the worst). I honestly believe the car only saw a few winters, most all rust is surface rust and could probably be knocked off with a wire brush (I've already done that in a few places while working on it). The pinch welds underneath do show some wear, I think previous owner used them as the primary jack stand points and didn't protect them.
Overall people are really impressed with the car and can't believe it's as old as it is.
Engine:
Previous owner spun a bearing on the motor and had it rebuilt in 2010, engine removed from the car, components hot tanked, block bored 0.040" over, and reassembled with new bearings, new crank, forged rods and pistons, head studs, head gasket, the whole works. Rebuild also included new timing set, oil pump, water pump, seals, distributor, etc. Head was cleaned/refreshed, valve job, and JWT cams installed.
Since I bought it I've changed out the intercooler piping to polished aluminum with black silicon couplings and new t-bolt clamps (ISIS kit), cleaned the intercooler out and sprayed it flat black on the front, and had the turbo rebuilt with upgraded bearings and seals (was burning oil, seal had went out on it). I've also simplified the wiring and vacuum lines (vibrant vacuum manifold block) and painted the valve cover wrinkle black. I put in a new Z32 MAF (OEM, not a cheap aftermarket one), which improved driveability immensely.
Oil changed with Royal Purple and Bosch filter, trans fluid changed last year.
A/C is not working, but all components and electronics are there and turbo kit is A/C compatible. It needs a custom line to the compressor, a compressor belt, and a recharge to work. Power steering is still hooked up and works fine. Alternator is new, roughly last year.
Interior:
Clean interior, pretty much stock, has a pillar cluster with the AEM Tru-boost and AFR gauge in it, also a nismo shift knob, black drift button on the e-brake, and nismo floor mats. Has an alpine deck and aftermarket speakers all around, the TEIN EDFC unit is located in the ashtray compartment and is hidden when closed.
Modifications List:
Engine
Eagle H-Beams
Mahle Forged Pistons 9.0:1
ACL Bearings
New Crank
ARP Head Studs
Cometic Head Gasket
OEM Timing Set
Oil Pump
Water Pump
Distributor
JGS turbo kit
T3/T04E 50trim 60a/r Garrett turbo
JGS Manifold
JGS downpipe
Trust downpipe (setup uses 2 downpipes)
Megan racing test pipe
JGS wastegate
JGS wastegate dump pipe
JGS oil feed/return lines
JGS EGR plug
27x12.5x3 x02 racing intercooler
HKS BOV
AEM TruBoost Boost Controller
550cc Deutchwerk injectors
Walbro Fuel Pump
JWT Cams
Chipped ECU (there's actually 2 ECUs, I've only ever used one)
Unorthodox Racing aluminum underdrive pulley
Fidanza flywheel
Spec Stage 2 Clutch
Enjuku Racing aluminum driveshaft
Tein tie rods
Battery relocated to trunk
B&M short throw
HID Headlights
Alpine CD deck
Alpine type-R rear 6.5" speakers
Upgraded 6.5" up front
Hookups in trunk for sub/amps
Alarm with keyless entry
Parts I've added:
Tein Super Street Coilovers
Tein EDFC controller
Aeromotive FPR
ISIS intercooler piping
Rebuilt Turbo (G-Pop Shop) with Bearing Upgrade <500 miles ago
Vibrant Vacuum Manifold
Z32 MAF
Apex'i Noir Exhaust
SPC Front Lower Arms
SPC Rear Toe Links
SPC Rear Camber Arms
NISMO Front Lip
NISMO Shift knob
E-brake Drift Knob
NISMO Floormats
Rare Infiniti Optional Wheels (18x8)
H&R wheel spacers (20 mm front, 25 mm rear)
Tires
S14 Silvia Emblem
Oil Changed - Royal Purple
Transmission Fluid Changed
Optima Battery
Alternator
Paint - Clay bar, 2x polish, wax
Parts not installed yet:
If I get around to installing these I'll update this ad, if someone is interested in the car and the offer is good I'll include these parts if wanted. Otherwise I'll sell them after the car is sold and recoup a little of the cost.
Fluidyne Radiator
Altima Dual Electric Fans
Z32 Fuel Filter
AEM Wideband O2 Gauge/Sensor (installed, just not hooked up)
Rear S15 Seats
Silvia S14 Key (Uncut)
TL,DR:
Good:
Clean 98 kouki (around 2000 made in 98), original paint/body with relatively low miles, no accidents/history
Paint shines like new, religiously waxed and babied
Rebuilt engine and turbo, ~10,000 miles on this setup, turbo just rebuilt
Stock bodied, never drifted, kitted, or abused
Quality parts used, no shortcuts or ebay parts. Tasteful modifications, most all parts new.
Bad:
A few dents and scratches in the body, not many and not bad
Short shifter rattles (may take apart and fix)
Sway bar hits exhaust occasionally
Rough ride with coilovers, not too bad at full soft
Cold idle hunts a little, runs great once warmed up
jvtec95 is offline   Reply With Quote
Old 10-26-2015, 08:52 AM   #2
Koukiii
Koukiii is an unknown quantity at this point
Wow, what a beautiful example of a clean kouki that sounds like it was built correctly. GL OP.
Koukiii is offline   Reply With Quote
Old 10-26-2015, 08:53 AM   #3
Hatemy7
Hatemy7's Avatar
Hatemy7 is an unknown quantity at this point
freaking clean dude!! GLWTS
Hatemy7 is offline   Reply With Quote
Old 10-26-2015, 10:00 PM   #4
Toomuchboost12
Toomuchboost12's Avatar
Toomuchboost12 can only hope to improve
Love a Clean Real Kouki . GLWS
Toomuchboost12 is offline   Reply With Quote
Old 10-27-2015, 11:18 AM   #5
jvtec95
Thanks for the comments!
I updated some things, will take pictures of underhood and interior for those that asked.
This car is a turbo and a tune away from some serious HP, the engine can handle it!
Old 10-27-2015, 11:43 AM   #6
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Thats odd...the original post disappeared.
2muchboost is offline   Reply With Quote
Old 10-27-2015, 11:57 AM   #7
jvtec95
That's weird, I just edited the thread and it disappeared.
Old 10-27-2015, 12:32 PM   #8
skysilvias13
skysilvias13's Avatar
skysilvias13 is an unknown quantity at this point
LMAO I thought I had PC issues... Kept refreshing like DafuQ?
skysilvias13 is offline   Reply With Quote
Old 10-27-2015, 07:07 PM   #9
Visionshift
Visionshift is an unknown quantity at this point
Repost it J!
Visionshift is offline   Reply With Quote
Old 10-28-2015, 12:11 PM   #10
jvtec95
Removed double post
Old 10-28-2015, 04:17 PM   #11
NickS14
NickS14 is an unknown quantity at this point
GLWS man!! FREE BUMP!! Any engine bay shots? VERY VERY CLEAN - looking to go KOUKI and I have KH3 almost same stuff - KAT - G35 7 spokes - would love that Kouki face lift !! Good Luck man, nice car!
NickS14 is offline   Reply With Quote
Old 10-28-2015, 04:32 PM   #12
vinnyjdm
vinnyjdm's Avatar
vinnyjdm has a spectacular aura aboutvinnyjdm has a spectacular aura aboutvinnyjdm has a spectacular aura aboutvinnyjdm has a spectacular aura aboutvinnyjdm has a spectacular aura aboutvinnyjdm has a spectacular aura about
lets see the engine!
S13 Hatch Drift Build: http://zilvia.net/f/showthread.php?t=608621
vinnyjdm is offline   Reply With Quote
Old 10-29-2015, 07:44 PM   #13
DGKALLDAY
DGKALLDAY's Avatar
DGKALLDAY is an unknown quantity at this point
Pm sent sir
DGKALLDAY is offline   Reply With Quote
Old 11-01-2015, 09:52 PM   #14
jvtec95
Bump back up. I haven't taken interior and engine pics yet, but will soon and add them.
I did finally swap out the Nissan hood emblem for the red S14 Silvia one I had laying around! Productive weekend
Old 11-02-2015, 09:14 PM   #15
jvtec95
Quick cell phone pic of engine bay, it may not look too flashy but it's built right!
It was too dark to take pictures of the interior, I'll get some good pics of both the engine and interior soon.
Old 11-03-2015, 08:27 AM   #16
gostrider
gostrider is an unknown quantity at this point
very nice!! glws
240 with illegal engine mod.
gostrider is offline   Reply With Quote
Old 11-10-2015, 11:42 AM   #17
jvtec95
Back from SEMA bump! Walked 40 miles in 4 days, tons of amazing cars!
I'll have to clean up this thread and remove the double posts, add some better pics of engine/interior and get back to people who've sent me PMs.
Let me know if you have questions or want to see anything else.
I'll likely have insurance taken out on the car until it snows, then will only put it back on if someone shows serious interest.
Old 11-10-2015, 01:00 PM   #18
CubanS14
CubanS14 is an unknown quantity at this point
Hey there brother I'm interested pm me your email or phone number and I'll hit you up
CubanS14 is offline   Reply With Quote
Old 11-11-2015, 06:41 PM   #19
jvtec95
PMed you back!
Bump, few people asking, no one bringing the $$$!
Old 11-11-2015, 09:39 PM   #20
turboshoebox
turboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymore
by the looks of the car i was expecting ur mod list to say:
lowering springs
some american looking car type wheel
not a 30 page mod list LOL
turboshoebox is offline   Reply With Quote
Old 11-12-2015, 11:10 AM   #21
jvtec95
What can I say, I like the clean sleeper look. Hell, even the intercooler is blacked out!
Old 11-13-2015, 11:22 AM   #22
jvtec95
Bump! Would like to sell before the snow flies if possible!
Old 11-13-2015, 11:45 AM   #23
CubanS14
I can come up with 8k and drive up to you ?
Old 11-14-2015, 09:59 AM   #24
jvtec95
Appreciate the offer, but clean stock koukis are going for about that now.
I am open to offers, but please consider what 97-98's are going for and what's into the car. This is a full engine rebuild, not a tired sr20 swap or a stock KA with a million miles and a turbo.
Old 11-14-2015, 11:28 AM   #25
CubanS14
Texted you brother
Old 11-14-2015, 10:08 PM   #26
RB180sxChris
RB180sxChris's Avatar
RB180sxChris is an unknown quantity at this point
beautiful car besides those wheels lol GLWS!
TOO LEGIT TO QUIT.....
RB180sxChris is offline   Reply With Quote
Old 11-15-2015, 10:59 AM   #27
jvtec95
Haha, thanks I guess? I like them, but I think they do look nicer in person than in the pics, kind of like a simplified Works VS-KF but OEM Nissan.
I'm talking to quite a few people out of state looking to pick it up, offers have been coming in. Planning on taking some additional pictures today for those who have asked.
Old 11-15-2015, 10:11 PM   #28
jvtec95
Took her for a drive today and took some pics for those who have been asking.
First off, here's some nice pics in the sun:
Then cleaned up the interior:
Old 11-17-2015, 07:14 AM   #29
jvtec95
Bump, for those interested I do have a recent autocheck report available, just ask and I can send it to you. Clean title, no accidents in history.
Old 11-18-2015, 11:43 AM   #30
jvtec95
Bump, back up to the top. Lots of interest, no one's arranged anything yet though.
1998, 240sx, black, kouki, s14
