Old 10-13-2015, 09:58 PM   #1
zainracer
zainracer is an unknown quantity at this point
Tein tire rods, SPL outers, lug nuts, injectors, ruca
BEST CONTACT METHOD: PM
PAYMENT OPTIONS: Cash or Paypal
SHIPPING: At Buyers expense
ITEM: SPL S13/S14 outer tie rods
DESCRIPTION: only used for about 8K miles, switched to a different inner/outer tie rod setup for knuckles
PRICE: $165($175 shipped) SOLD
ITEM: Inner Tie Rods
DESCRIPTION: Z33 Tein inner tie rods, only used for about 8k miles, needed longer tie rods because I got different knuckles. In very good condition.
PRICE:$60 ($70 shipped) SOLD
ITEM: OEM S15 480cc injectors, with S15 fuel rail and FPR
DESCRIPTION: Good condition, working injectors pulled from a S15 SR20
PRICE: $100 ($115 shipped)
ITEM: OEM S14 SR20 370cc injectors
DESCRIPTION:working injectors pulled from a S14 SR20, some of the tips on the end are cracked/ missing the little tabs. Connectors pictured but not included.
PRICE: $80 ($90 shipped)
ITEM: 2.5" I.D. springs
2x Eibach 7" long 275lb (0700.250.0275)
2x GC/Eibach 5" long, ~430 lbs (GC125.64.75)
2x GC/Eibach 8" long, ~380lbs (GC200.64.67)
PRICE: $70 shipped per pair
ITEM: S13 Rear Upper control arms
DESCRIPTION: Used, old RUCA. Will need new rod ends.
PRICE: $10 ($20 shipped)
ITEM: Lug nuts
DESCRIPTION: Muteki Lug nuts, Neo chrome, being used for a while and the coating is chipping off but threads are perfect. Only have 17 so it would only work for 4 lug cars
PRICE:$20 ($30 shipped) SOLD
ITEM: FLCA
DESCRIPTION: Godspeed FLCA. I started modifying these for roll center correction based on this write up: http://www.nissanroadracing.com/showthread.php?t=1407
I have already reamed out the bearing hole and pressed in the ABI-12T bearings. Will also include the 3/4" bolt, lock nuts, and the godspeed rod ends. I don't have the misalignment spacers for the rod ends. ( the bearings and hardware cost ~$50.
PRICE:$100 ($120 shipped)
ITEM: Stock S13 front spindles
Price: $60 ($80 shipped)
zainracer is offline   Reply With Quote
Old 10-14-2015, 01:18 AM   #2
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
To bad on the lug nuts
Looking for that finish
GLWS
andisan is offline   Reply With Quote
Old 10-14-2015, 10:38 AM   #3
shephurd
shephurd's Avatar
shephurd is an unknown quantity at this point
will the inner/outer tie rods work with +25mm flca s13
shephurd is offline   Reply With Quote
Old 10-14-2015, 11:15 PM   #4
zainracer
I believe that the Z33 tie rods are a little shorter than the stock S13. The SPL outers give you extra length but I think the Z33 inner+ SPL outer might not give you a safe amount of thread engagement if you are adding 25mm to the flca. Using S14 inners with SPL outers would probably be a better option.
Old 10-22-2015, 09:27 PM   #5
zainracer
Bump! Lug nuts sold, price lowered on everything else!
Old 11-05-2015, 09:42 AM   #6
zainracer
SPL outer and Tein inner tie rods sold!
lug nuts, s13, spl, tein, tie rods
