Old 07-16-2015, 10:16 PM   #1
Nazdog247
Nazdog247 is an unknown quantity at this point
Sr20 voltage loss! Help!
So My sr starts up at around 12 volts then as you rev it it lowers to around 11 and so on an so on. Once you drive the car it sputters and will eventually stall out without the car even moving . I replaced the alternator with the ka alternator and put new cool packs and igniter chip (it was previously not starting) so if someone could help me out here that'd be great I've been fighting this problem for a week or 2 now. It's a red top in a s14 im pretty sure all the grounds are good on it
Nazdog247 is offline   Reply With Quote
Old 07-17-2015, 10:36 AM   #2
KoukiMonsta
KoukiMonsta's Avatar
http://zilvia.net/f/showthread.php?t=605934
Get a multi meter...and check things...
what is voltage at battery
what is voltage output from ALT while running
what is voltage at fuse box when running and off
etc...track that shit down.
also make sure you correctly wired the ALT. you need both the sense and dummy wires.
make sure you dont ask how to do that, because its all over the mother fucking internet
@UpshiftEngineering
Old 07-21-2015, 09:35 PM   #3
ZenkiDeven19
ZenkiDeven19 is an unknown quantity at this point
Make sure you get this FIXED! You can lose an engine with voltage fluctuating like that.
Sent from my SM-N900V using Tapatalk
ZenkiDeven19 is offline   Reply With Quote
black top, red top, sr20, wiring
