06-19-2015, 12:50 AM | #1 |
Trader Rating: (18)
Feedback Score: 18 reviews
WAYYYYY TO MANY AWESOME PARTS TO SELL! (350z, sr20, universal, ect!)
Well, as some of you know I have been building a track car for the past 4+ years. Now that it is finished, all the extra parts must go. These parts either didn't fit, were replaced, extra, or came with the car. I'm sure some of you may want some of these amazing parts. I can get more detailed photos upon request. It was just way to many photos to fit in one post, without exceeding the photo limit. Let me know what you need!
Stance XR Coilovers 350z - Only Used during the build process and then ended up switching to Stance Pro Comp custom valved coilovers. - Perfect Condition! - $1,800 Whiteline Swaybar Endlinks 350z - Still in the packaging...never used - Perfect Condition - $250 Tarox Big Brake Kit 350z - Only Complete front/rear brake setup in the United States. Only used during the build process and ended up getting a deal with APRacing. - Includes: 10-pot front brake calipers with 14" two piece rotors, lines, and brackets 12-pot rear brake calipers with 14" one piece rotors, lines, and brackets 6-pot hydro brake calipers (needs custom bracket and lines) - $7,200 (Cost roughly $9,000 new) Davies & Craig Electronic Waterpump - This is BRAND NEW and easily one of the best things I did to my race car. - Perfect Condition - $150 Naprec Power Steering Braket SR20DET - When I went dry oil sump, it made using this impossible and thus is has never been used. - It lowers the power steering pump away from the manifold, which helps keep it cool. - Perfect Condition - $225 Spa Technique Dual Intercooler Temp in/Temp out gauge - This is a great gauge to see when your intercooler gets heat soaked and you need to calm it down or rethink your intercooler setup for better cooling. Ended up not using, because I ran out of dash space...Brand New - Perfect Condition - $450 HKS EVC VI Boost Controller - Ended up not using, because I went ProEFI everything. BRAND NEW IN BOX! - $550 (Retail: ~$700) Borg Warner EFR 8374 Turbo - 1.05 A/R Turbine Housing (Externally Wastegated) - Turbine Silver Ceramic Coating - Full-Race Metal EFR BOV Cover - BRAND NEW IN BOX! - $1,950 (Cost over $2,500+shipping from Full-Race) Votion Liquid to Air Intercooler Setup (Custom order...not sold as a kit) - Capable of supporting up to 1000+hp - BRAND NEW IN BOX! - Kit includes: 26X7X3.5 Heat Exchanger, Fill Cap, Ice Box, Bosch pump, Dual 7" fans, 15X6.5X6 Long Flow Intercooler - $650 (RETAIL = $850+) NEO VVL Plug Cover - I have an extra plug cover that I definitely don't need. - $125 Hydro Handbrake with Wilwood Master - BRAND NEW IN BOX! - Res. not included - $125 HKS Style Turbo Funnel - Bought this awhile back fro the BW turbo that I ended up not using. - Brand New - $50 Braided Clutch Lines - New Braided Clutch Lines - $35 Differential Cover 350z - Replaced mine with a Nismo Cover - Perfect Condition - $30 Front Lower Control Arms 350z - Replaced mine with Billet Fantana Nissan arms - Perfect Condition - $50 Axles 350z - Replaced mine with Driveshaft shop axles - Perfect Condition - $150 WedsSport SA55M - 18x9 + 20 and 18x10 +18 (5x114.3) with Center Caps - BRAND NEW IN BOX! - $1,700 350z Gauge Cluster - Perfect Condition - $125 Race Air 4' Heavy Duty Hose - New In Box - $18 VVVVV ITEMS NOT IN FIRST PICTURE VVVVV SR Timing Chain Tensioner - ~3k miles - Perfect Shape - $50 SR20 Extended Oil Pickup - NEVER USED! - $50 SR20 Oil Pump Gear and Rear Pump Cover - NEVER USED! - $50 Cam Angle Sensor Gasket and O-ring - Perfect Shape - $5 Intake and Exhaust Cam Gear Bolts - PERFECT SHAPE! - $3 each SR Upper Oil Pan - SOLD! SR Oil Pump - SOLD! SR Oil Screens - 2 sets SR Rear Crank Case Cover - 4 SR Oil Block Galley w/ Sensor (2) SR Main Cap Girdle - PERFECT SHAPE - $20 SR Coolant Tubes - $20 SR Short Tubes - $5 SR Temp. Sensor Housing - $10 SR Thermostat Housing - $10 SR Coolant Inlet - $10 SR Coolant Complete Setup w/ Sensors - $45 OEM SR20VE P11 Valvetrain (IN+EX Valves, Springs, Cams, Gears) - 15,000 Miles - PERFECT! - Valves - SOLD! Springs - $25 Retainers - $15 Camshafts - $50 Gears - SOLD! SR20DET AAC Valve - PERFECT SHAPE - $50 stock KA24de airbox intake system and Filter is still clean (came from a 98' kouki) - PERFECT SHAPE - $75 S13 Non-ABS Driveshaft - Pick up only - Used - $90 S13 SR Bell Housing - No cracks - $50 S13 SR Valve Cover Baffeling - Great Shape - $10 SR20 Coilpack Gaskets - NEW - $2 each S13 SR20 Intake Gasket - PERFECT SHAPE - $5 S13 SR20 Valve Cover Gasket - Perfect Shape - $15 Injector Gasket O-rings - Perfect Shape - $2 each SR20 Rear Main Seal - New In Box - $18 (8) SR20 Hydraulic Lifters - Perfect Shape - $5 each SR OEM Exhaust Manifold - Perfect Shape - $60 SR20det Exhaust Gaskets (t3, T4, Exhaust mani) (Copper one SOLD) - Perfect Shape - $15 Crank Pulley Bolts (2) -Perfect Shape -$3 Transmission Mount Bracket and exhaust to transmission brackets - Perfect Shape - $10 each Alternator Brackets - Perfect Shape - $15 each SR Clutch Fork - Perfect Shape - $10 Timing Chain Guide - Perfect Shape - $5 Knock Sensor (4)...one doesn't have a sub-harness - Perfect Shape -$20 each (15 for the one without the sub-harness) Godspeed Arm - SOLD S13 Rear Links - $10 each S13 Front Lower Control Arm - $20 Factory CD009 350z Transmission Gear set - Replaced mine with an OS Giken gear set - Perfect Condition - $250 350z doors - Perfect Condition - $200 350z Master Cylinder - Perfect Condition - $50 350z Booster - Perfect Condition - $75 350z front upper control arms - Perfect Condition - $50 350z Eibach Sway Bars front and rear - Perfect Condition - $250 350z Door Panels - Perfect Condition - $100 Any questions, please feel free to ask!
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 07-21-2015 at 05:59 PM.. |
07-22-2015, 01:51 AM | #11 |
Banned from the Marketplace
^^right. Man imarvin240 you always have the coolest stuff for sale... Any chance you'd be willing to work on the price of that SR PS bracket? Thanks!
