Old 04-11-2015, 02:10 PM   #1
TollieLifted
TollieLifted's Avatar
TollieLifted is an unknown quantity at this point
Question Swapped Trans. Driveshaft Issue
So i swapped my s14 trans with an s13 trans and now it looks like the driveshaft doesn't want to seat square. As in, the trans is too long and driveshaft now doesnt fit. Not sure whats going on here..cant seem to locate an answer elsewhere.
According to the interwebz the only difference is the sensor and driveshaft should be fine.
TollieLifted is offline   Reply With Quote
Old 04-11-2015, 02:42 PM   #2
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
ABS or Non ABS?
Old 04-11-2015, 02:57 PM   #3
TollieLifted
Thing is, im using the same front and rear portion of the driveshaft that was in the car. So since its ABS, paired with the s13 trans, ill need a diff portion of the driveshaft?
Old 04-13-2015, 11:54 AM   #4
TollieLifted
bump.
Any ideas why the driveshaft wouldn't fit? ABS are supposed to be shorter, right? Guess I'll measure them to try and figure out what/where they are from.
Old 04-13-2015, 01:34 PM   #5
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
You are doing some thing wrong.
Take some pictures and post so we can get an idea to help you out
Dboyizmlg is offline   Reply With Quote
Old 04-13-2015, 04:38 PM   #6
TollieLifted
I'll snap some pics, and get some measurements(of the trans and driveshaft* for those who thought they would be funny). Everything seats flush, so no idea but pics may tell.
Old 04-14-2015, 06:21 PM   #7
TollieLifted
Ok, maybe images will help. (sorry for the tremendous image sizes)
Also, I noticed where the shifter should be seems a lot closer to the front...which doesnt make sense since d/s seems to not want to straighten out. Unless (this just occurred to me), I need to use a diff yoke? piece that slides into the tail end of the trans? Shit, idk..
This came in the tail end of the trans I swapped in:
You can see it mounts flush. Also, wtf is that gap in there?!
Old 04-14-2015, 10:34 PM   #8
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
The shaft with the 3 bolts (one that came in your new s13 trans) is for s13.
Mine has it also, on my s13. But my buddies s14 chassis do not have that 3/6 bolt shaft.
I think you need to source out the correct drive shaft to fix your issue.
I'm no expert, but from what I hear is that the USDM shaft, Jdm drive shafts, and abs shafts are some what different.
Maybe some body else can confirm
Old 04-15-2015, 10:23 AM   #9
TollieLifted
What if I was to get a non abs diff? Those a shorter, right, so that could solve the prob? Except I dont know the implications of a non abs diff as far as sensors and whatnot
Old 04-15-2015, 02:36 PM   #10
seagrasser
seagrasser is an unknown quantity at this point
Start at the beginning.
What car is this going into (S14 I assume)? Why did you swap the transmission? Car equipped with ABS? Was your car manual or auto before? Original diff?
All would help since there are differences from ABS to NonABS and Auto to manual and ABS diff to NonABS diff.
S14 RB25
seagrasser is offline   Reply With Quote
Old 04-15-2015, 02:39 PM   #11
TollieLifted
Car is s14 ABS. Trans was toast so I found an s13 trans to replace it. As far as I can tell the car wasnt ever Auto.
It does look the previous owner swapped in another an s14 trans in before cuz they wired it all jenky it seems, so duno if maybe they swapped d/s at that point? havent measured yet
Old 04-15-2015, 02:42 PM   #12
seagrasser
Here is something else that may help
Plain and simple, Stock Driveshafts are 2pc
S13:
Section 1: Coming From Trans (ABS makes no Diff. in Length here)
M/T = 395.0mm (15.55")
A/T = 432.0mm (17.01")
Section 2: Center Bearing/Mount to Diff
Non-ABS = 605.0mm (23.82")
ABS = 590.0mm (23.23")
S14:
M/T = 421.0mm (16.57")
A/T = 441.0mm (17.37")
Non-ABS = 650.0mm (25.59")
ABS = 636.0mm (25.04")
S14 RB25
Old 04-15-2015, 03:44 PM   #13
TollieLifted
I have come across that many times in my research, thank you. Only measurement will tell whats in there
Old 04-21-2015, 06:21 PM   #14
TollieLifted
This is from the mount that connects to the rear shaft....
Old 04-22-2015, 12:59 PM   #15
dsastr_clan
dsastr_clan is an unknown quantity at this point
i have used s13 trans on s14s, and s14 trans on s13s no problems.
dsastr_clan is offline   Reply With Quote
Old 04-22-2015, 01:22 PM   #16
TollieLifted
This is why I am confused. I'm going to just get a non abs differential since I dont need abs anyhow and that should solve the problem since its a shorter diff.
driveshaft, ka transmission, s13, s14, transmission
