Old 02-10-2015, 04:13 PM   #1
Wicho310_
Wicho310_ is an unknown quantity at this point
s13 S13 bad fuel pump? need help...
So my '90 s13 has a ka24de swap and yesterday the car was driving fine and all of a sudden it's started to jitter a bit then it would just die unless i keep pumping the gas, now the only way the car starts or stays on is if i keep pumping the gas non stop what could it be? Fuel pump? I haven't don't much work to the car yet. People suggest clogged fuel filter, bad fuel pump, fuel pressure regulator, or AIC.
Wicho310_ is offline   Reply With Quote
Old 02-10-2015, 04:37 PM   #2
jedi03
If you suspect fuel disconnect a fuel line off the top of the filter an see if it sprays fuel...sounds more like cat or head gasket to me...check your oil and water too
Old 02-10-2015, 05:03 PM   #3
fatduece
fatduece is an unknown quantity at this point
Why would it be a cat? >_>"
fatduece is offline   Reply With Quote
Old 02-11-2015, 08:58 AM   #4
Kingtal0n
Kingtal0n's Avatar
It is likely a fuel issue. rent a (free) fuel pressure gauge from local autozone to verify if the pump/filter/regulator is at fault.
Otherwise, (next) unplug the maf sensor and diagnose the electronics involved with fueling the engine.
Also:
1. cat is mentioned because they tend to clog, and a clogged cat gives a symptom of an engine dying
2. It wouldnt be the IACV (idle control valve) because the throttle body (throttle valve, "gas pedal") overrides that
without seeing it, most likely it is your fuel pump ( the pump is probably ancient, failrly common failure), followed by a clogged filter(unlikely) or wiring related (maybe the maf ground came loose. Maybe the maf itself came loose and unmetered air is entering the engine). Inspect all tubes that lead from the maf to the engine before taking anything apart.
Old 02-11-2015, 08:46 PM   #5
Wicho310_
Yea I got the car to turn on and we disconnected the maf sensor and sure enough it stayed on but my rpms won't go past 2500, so I'm guessing my sensor most likely went bad right?
Old 02-12-2015, 07:08 AM   #6
TheRealSy90
TheRealSy90's Avatar
Check the rubber hose between the fuel pump and the pump hanger assembly, these rupture eventually especially with the age of the car. I thought I had a dead pump and it was just that small fuel hose that popped.
Such a good signature.
Old 02-12-2015, 07:09 AM   #7
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
Probably broke an oring on an injector. Mine was the same symptoms.
Originally Posted by Hoffman5982 View Post
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 02-12-2015, 10:15 AM   #8
Kingtal0n
Kingtal0n's Avatar
If you notice the engine will run fine with the maf disconnected, but not when it is connected, then your first priority is to boost leak check the plumbing. Look for any clamps missing and torn unions between the air filter and throttle body. If this system is pressure tight (boost leak checked) then you should try another maf sensor.
tinyurl.com/4l80er
Old 02-12-2015, 10:51 AM   #9
Driftwire
Driftwire's Avatar
Or if you have a tune on the ECU like a ROM tune the board might be loose. That happened to me twice and acts like I dont have any sensors hooked up and runs like dookey holes
240, fuel pump, s13
