Old 11-06-2014, 06:44 AM   #1
lunzee
lunzee is an unknown quantity at this point
Sr20det dumping oil out dipstick
Just a question, sr20det, blows out dipstick, oil everywhere, but zero oil in my catch can. No smoke, runs mint, think it's rings or pcv?
I would drive it like I stole it, but even then I would be more careful
lunzee is offline   Reply With Quote
Old 11-06-2014, 09:51 AM   #2
ultimateirving
ultimateirving's Avatar
Are you sure you have the catch can hooked up right? It sounds like you're pressurizing the crank case. Can you post a picture of your catch can hoses and pcv routing.
Z32 with lq4 swap
Old 11-06-2014, 10:00 AM   #3
lunzee
Yes I will post a picture tonight after work, I am unsure of the correct routing, it's my first sr and the previous owner has the car set up very badly, just starting to figure out all the issues, it only pushes the dipstick out at higher then stock boost levels.
Old 11-06-2014, 10:12 AM   #4
ultimateirving
Ok since your new to sr, stop boosting it for a couple days til we can help you go thru it and make sure you don't make anything worse.
How long have you had the car? What have you changed since you got it from the po
Z32 with lq4 swap
Old 11-06-2014, 10:26 AM   #5
lunzee
Haven't changed anything since I got it last night, car is a track missle so it's not being driven, car needs work, it's got a 20g on 12-14ish psi, no boost controller, no tune, single can mad, stock injectors, front mount. And a cheap catch can. I have no info and will have to take a closer look at it tonight. So I can figure out what I need to order to get it going in the right dorection
Old 11-06-2014, 10:28 AM   #6
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
You are probably over boosting.
Do you have boost gauge installed??
If you do check your gauge.
Manual boost controller of some sort?
Dboyizmlg is offline   Reply With Quote
Old 11-06-2014, 10:31 AM   #7
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dip stick popping out usually the cause is over boosting, causing too much pressure in the crankcase.
Check and confirm boost pressure. Most likely cause is a faulty turbo actuator.
Old 11-06-2014, 10:32 AM   #8
lunzee
No controller, ebay waste gate, boost is at 14 psi, no spikes or insane over boosting or anything
Old 11-06-2014, 10:44 AM   #9
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
12psi+ is too much for factory ecu and injectors with that size turbo.
If actuator rod is adjustable try setting it to lower boost, 7psi max!
Also how is the set up on your catch can?
Edit: external wastegate? Swap out to a softer spring for 7psi
Old 11-06-2014, 10:51 AM   #10
lunzee
I am aware that the stock ecm, injectors etc is not good for 14 psi. What I'm saying is the cheapo ebay turbo installed by the previous owner has a waste hate that is set at 14 psi so there is nothing I can do at the moment, I'm am not knowledgable enough to tell you know the pcv system and catch can are routed so I will post pictures after I get home from work.
Old 11-06-2014, 10:53 AM   #11
lunzee
I am also unaware of how to adjust the actuator rod. I really do not know a lot about this at all, that's why I'm asking for help, I misread your previous post
Old 11-06-2014, 10:54 AM   #12
lunzee
Internal wastegate, sorry for the confusion
Old 11-06-2014, 11:38 AM   #13
Tom N
Tom N is an unknown quantity at this point
It's popping due to high crank case pressure. 14psi on that turbo is not going to cause high enough crank case pressure unless your rings are bad and your getting a bunch of blow by.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 11-06-2014, 11:43 AM   #14
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Or what this guy said ^
Old 11-06-2014, 11:45 AM   #15
lunzee
So where should I start guys?
Old 11-06-2014, 11:59 AM   #16
Tom N
Would like to see how you have your crank case breather and pvc set up.
I would do a leak down test.
Old 11-06-2014, 12:06 PM   #17
lunzee
Okay I will post a picture of the pcv, and catch can and everything tonight, and as for a leak down test I have never done that, I only know how to do a basic compression test, is it something I can do with rented equipment or is it more involved?
Old 11-06-2014, 12:25 PM   #18
Tom N
I don't know if the auto parts stores loan leak down testers. You will have to check. You will need a air compressor. As long as you have that it's very easy to do.
Old 11-06-2014, 01:33 PM   #19
lunzee
I cannot seem to find a leakdown tester, will a standard compression tester do? Or will I need to buy one
Old 11-06-2014, 01:56 PM   #20
Tom N
You can start with doing a compression test. Put oil in any cylinders that are low then retest and see if compression comes up. If it does you need to do a leak down.
Old 11-06-2014, 03:18 PM   #21
ultimateirving
Get pics of the catch can system before worrying about compression test. Takes a lot less time for us to tell you it's hooked up backwards(which in 90% sure based on description)
Z32 with lq4 swap
Old 11-06-2014, 03:23 PM   #22
Tom N
I agree. Your rings would have to be really bad to be popping out the oil dipstick at such low boost pressure.
Old 11-06-2014, 03:55 PM   #23
lunzee
Still waiting to be out of work to get a pictures but it appears to run down the side of the valve cover towards the front of the car, then down to the catch can and the other side of the catch can goes to the intake
Old 11-06-2014, 08:04 PM   #24
lunzee
Old 11-06-2014, 08:08 PM   #25
Sileighty_85
Sileighty_85's Avatar
first off thats the wrong dipstick for that engine so you are probably over filling the engine oil.
Either that or you have really bad blow by from worn piston rings
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-06-2014, 08:10 PM   #26
lunzee
So that is one idea, getting closer I'll order a dipstick lol
Old 11-06-2014, 08:29 PM   #27
lunzee
I order and an overnighting a oem sr20det dipstick, anything else anyone else seeing ran incorrectly or anything please let me know
Old 11-06-2014, 08:37 PM   #28
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Take pictures of your engine bay
Old 11-06-2014, 08:41 PM   #29
lunzee
Here's another one
Old 11-06-2014, 08:49 PM   #30
ultimateirving
Catch can seems to be ok. Try testing out your pcv, it's the little fitting on the back passenger side of the valve cover. It should only blow one way
Z32 with lq4 swap
