Old 10-30-2014, 06:28 PM   #1
drifterchick187
drifterchick187's Avatar
drifterchick187 is an unknown quantity at this point
SR Help! My 240 wont start :(
Hi guys, I have an S13 with an SR and a Power FC and it won't start at all. I am wondering if you can offer some advice on where to start to diagnose what is wrong with my car
I have verified the fuel pump is kicking on and my power FC is turning on but still no go when i turn the key.
Any clues as to what I can check next? I have a DMM so I can check connections just not sure what I'm looking for exactly.
drifterchick187 is offline   Reply With Quote
Old 10-30-2014, 06:33 PM   #2
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Did it start before you installed the power fc? But do the basics like hook up a fuel pressure gauge inline after the fuel filter and before the fuel rail and make sure your getting the 43psi i beleive and then hook up one of the spark plug testers to make sure it's getting spark..also a compression test.one of those is off and you can continue the diag
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 10-30-2014, 06:36 PM   #3
drifterchick187
yes it was running great, it had a fresh tune and was dialed in. Then one day I turned the key and all the magic disappeared from our relationship ok I'll check Fuel pressure and spark and get back to you. Thanks for your help!
Old 10-30-2014, 06:46 PM   #4
drifterchick187
ok I dont have a fuel pressure gauge but I pulled out a spark plug and grounded it while it was hooked to the Coil pack and there was no spark at all when I turned the key over.
Old 10-30-2014, 07:09 PM   #5
angel mkiv
angel mkiv's Avatar
When you say turn the key over you mean during cranking right? But double check the coilpack harness ground wire/ignitor chip plugged in and all connectors are tight.. Then test to see if the coils are getting power and work your way back
Old 10-30-2014, 07:20 PM   #6
drifterchick187
yeah i mean cranking, is this a good example of what I need to check? I want to make sure I'm checking the right wire.
240sx, powerfc, problems, sr20
