Old 08-07-2014, 02:22 AM   #1
Bay_area831
Bay_area831 is an unknown quantity at this point
SR Hairline camshaft fracture. Quick question
I tried searching.
My stock intake cam has a crack at the dowel pin. I have another stock cam to replace it with. Can I simply swap it over without line bore, messing with cam caps, messing with shims. Simply just put it in??
Bay_area831 is offline   Reply With Quote
Old 08-07-2014, 05:04 AM   #2
jr_ss
As long as the journals of the cam look good, I don't see why not.
Old 08-07-2014, 05:14 AM   #3
theboy
theboy is an unknown quantity at this point
Its simple, go buy yourself some feeler gauges. Check every valve and shim to the cam shaft in the head now. Replace said camshaft with cam shaft#2. Recheck valves and shims. If theres a difference then youll be re-shimming the head. At least this way youll get a baseline of what you had and what you have now.
You wont need to align hone for the new cams.
theboy is offline   Reply With Quote
Old 08-07-2014, 04:35 PM   #4
quickdiversion
quickdiversion is an unknown quantity at this point
I would defiantly say do this if you had solid lifters.
As long as your stock hydraulic lifters are good the difference should be so minimal they will compensate for the difference
quickdiversion is offline   Reply With Quote
Old 08-07-2014, 04:49 PM   #5
Bay_area831
Yes they are stock lifters. I figured as much but thank you for the reply. I will feelers gauge just for the hell of it.
Old 08-09-2014, 07:48 PM   #6
yetijeff
yetijeff's Avatar
yetijeff is an unknown quantity at this point
Dual cams are solid stock, singles are hydraulic stock. Use the feeler gauges
yetijeff is offline   Reply With Quote
Old 08-09-2014, 10:50 PM   #7
Bay_area831
Dual cams are hydraulic stock. All sr20dets are hydraulic. Stock. Your be tripping ha
Old 08-10-2014, 07:22 AM   #8
jr_ss
Perhaps you're tripping, because you're wrong. GTI-Rs are solid lifter SR20DET's...
240sx, cam, camshaft, s13, sr20det
