05-19-2014, 08:03 AM | #1 |
Trader Rating: (18)
Feedback Score: 18 reviews
NEW and USED Parts For Sale***********AEM-WedsSport-Wilwood-HKS-RacePak-TONS MORE!!!
Okay, So I have been building my SR22VE-T for the past few years and counting , with the help of Touge Factory. These are all the parts that so far are not going on the car and/or didn't end up being needed for the build. A lot are new and some are used. I will add to the pictures/parts as I get time to take some pictures and list more. IF IT'S NOT LISTED, I'M NOT SELLING IT! I will except money...no trades. Prices are firm unless otherwise stated!
1 Gallon AEM Methanol Injection Tank and AEM Filter - BRAND NEW IN BOX! -Tank - $50 - Filter - $20 WedsSport SA-55M 18x9 + 20 and 18x10 +18 (5x114.3) with Center Caps - BRAND NEW IN BOX! - $1,700 Hydraulic E-Brake with Wilwood Master - BRAND NEW IN BOX! $150 HKS EVC VI Boost Controller - BRAND NEW IN BOX! - $500 (Retail: ~$700) Tarox B27-6 piston E-Brake Caliper for 24mm rotors (will need custom mounting bracket) - BRAND NEW IN BOX! - $250 RacePak Vnet EFI Interface Module for AEM - This allows you to hook up an AEM ecu to a RacePak cluster - BRAND NEW IN BOX! - $300 (Retail: ~$375) Votion Liquid to Air Intercooler Kit (Custom order...not sold as a kit) - Capable of supporting up to 1000+hp - BRAND NEW IN BOX! - Kit includes: 26X7X3.5 Heat Exchanger, Fill Cap, Ice Box, Bosch pump, Dual 7" fans, 15X6.5X6 Long Flow Intercooler - $700 (RETAIL = $850+) SR Timing Chain Tensioner - ~3k miles - Perfect Shape - $50 ISIS Oil Pan - Mounted Only/Never Used - $100 SR20 Extended Oil Pickup - NEVER USED! - $45 SR20 Oil Pump Gear and Rear Pump Cover - Never Used! - $50 Cam Angle Sensor Gasket and O-ring - Perfect Shape - $5 Intake and Exhaust Cam Gear Bolts - PERFECT SHAPE! - $3 each SR20 Head Bolts - Used - $15 KU Engineering Style S13 Intake Manifold - Never Used (just sitting around for about 3yrs, but the last owner drilled injector port 1 larger to put larger injectors in but then sold it to me...costs about 60 to do it to the other 3 or 40 to correct port 1) - $100 SR20 Upper Oil Pan -1 SR20 Oil Pump - SOLD! SR20 Oil Screens - 2 sets SR20 Rear Crank Case Cover - 4 SR20 Oil Block Galley w/ Sensor - 1 SR Main Cap Girdle - PERFECT SHAPE - $15 each SR Coolant Tubes - $20 SR Short Coolant Tubes - $5 SR Temp. Sensor Housing - $10 SR Thermostat Housing - $10 SR Coolant Inlet - $10 SR Coolant Complete Setup w/ Sensors - $45 OEM SR20VE P11 Valvetrain (IN+EX Valves, Springs, Cams, Gears) - 15,000 Miles - PERFECT! - Valves - SOLD! Springs - $25 Retainers - $15 Camshafts - $50 Gears - SOLD! SR20DET AAC Valve - PERFECT SHAPE - $30 S14 SR Valve Cover w/ Coil Pack Cover - Perfect Shape - $160 stock KA24de airbox intake system and Filter is still clean (came from a 98' kouki) - PERFECT SHAPE - $50 S13 Non-ABS Driveshaft - Pick up only - Used - $90 S13 SR Transmision - Pick up only - Roughly 30k miles - PERFECT SHAPE - $125 S13 SR Bell Housing - No cracks - $40 SR20 Timing Chain guide - Perfect Shape - $10 S13 SR Valve Cover Baffeling - Great Shape - $10 SR20 Coilpack Gaskets - NEW - $2 each S13 SR20 Intake Gasket - PERFECT SHAPE - $5 S13 SR20 Valve Cover Gasket - Perfect Shape - $15 Injector Gasket O-rings - Perfect Shape - $2 each SR20 Rear Main Seal - New In Box - $18 (8) SR20 Hydraulic Lifters - Perfect Shape - $5 each Megan Racing SR T3/T4 Exhaust Manifold - NEVER USED - $90 SR OEM Exhaust Manifold - Perfect Shape - $40 SR20det Exhaust Gaskets (t3, T4, Exhaust mani) - Perfect Shape - $15 Crank Pulley Bolts (2) -Perfect Shape -$3 Transmission Mount Brackets - Perfect Shape - $10 each Alternator Brackets - Perfect Shape - $15 each Knock Sensor (4)...one doesn't have a sub-harness - Perfect Shape -$20 each (15 for the one without the sub-harness) Godspeed Arm - $10 S13 Rear Links - $10 each S13 Front Lower Control Arm - $25 (2) o2 Sensor Simulator - one was touched with dirty hands, then I put on gloves - NEW IN BOX - $30 (each)
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 05-24-2014 at 06:09 PM.. |
05-19-2014, 08:04 AM | #2 |
Trader Rating: (18)
\/ \/ \/ 350Z PARTS \/ \/ \/
350z OEM Hatch w/ Glass - Perfect Shape - $250 350z OEM Hood and Doors - Perfect Shape - $200 (HOOD) - $200 (DOORS) 350z Core Support - Perfect Shape - $150 350z OEM Fenders - Perfect Shape - $150 350z Door Panels - Great Shape! - $100 350z Eibach Sway Bars (front and Rear) - Great Shape! - $250 350z Dust Shields - Great Shape - $30 350z Axles - Perfect Shape (using Driveshaft Shope Stage 5 Axles Now) - $150 350z OEM CD009 Transmission Gears (I switched to OS Giken Gears) - Perfect Shape -15k Miles - $300 350z Master 1 1/16th - Perfect Shape - $50 350z Brake Booster - Perfect Shape - $75 350z Arms - Perfect Shape - $50 350z 03' tinted tail lights - Great shape - $75 350z 04' Head Lights - Great Shape - $75 These are all the make an offer items...i dont want or need them so just make an offer...pictures of these upon request. \/ \/ \/ 2005 WRX (less then 20k miles on items)\/ \/ \/ OEM Air Box Setup OEM Downpipe OEM Uppipe OEM Turbo Heat shield \/ \/ \/ Auto 200SX SER Engine Part Out \/ \/ \/ Head (currently has valves, springs, retainers, and keepers but can remove if buy requests) Rocker arms Oil tubes in SR head Intake and Exhaust cam gears Valve Cover EGR valve (in WORKING order) distributer (in WORKING order) Headers Injectors w/ Fuel rail Intake Manifold (perfect Condition w/ all connectors and hoses) (3) Pistons (3) Rods Water Pump Water Pump pulley oil filter block crank pulley Coolant tubes Coolant outlet Lower Oil Pan Oil Pan baffling Timing chain tensioner Flex Plate Auto trans gasket Alternator bracket intake bracket power steering bracket ac bracket Auto 200sx Engine Harness (completely uncut) injector harness tps (throttle position sensor) Thank You For Looking!
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 05-24-2014 at 06:04 PM.. |
05-19-2014, 07:25 PM | #4 |
How much for the clutch fork and release bearing shipped to 43025? I need this by this weekend if at all possible
72 240z, l28, Its a classic 90 240sx, ka24et Get this finished |
06-18-2014, 06:34 PM | #8 | |
Sent from my SM-N900V using Tapatalk |
06-19-2014, 09:51 AM | #9 |
What's your location? I'm in central PA by state college. I'm interested in the Hydro brake, oil pan, extended oil pickup, and the trans crossmember. Could you please PM me a price picked up and shipped to 17845 thank you.
10-26-2014, 05:59 PM | #13 |
Hi.
Do you still have the Tarox B27 calipers? I Guess it is two, and not only one caliper. Am I correct? Is this the price for two calipers? Is it radial or lug mount? Regards, ghia69 |
01-20-2015, 11:07 PM | #20 |
Hey you happen to have a s13 sr20 or ka24de transmission front cover plate? The part that the throw out bearing slides on? Also the throw out bearing sleeve?
Instagram username:angelmkiv |
