05-09-2014, 10:13 AM | #1 |
Miller's 1989 S13 Build Thread
Build Thread Convert 1989 S13 Hatch Automatic to S14 sr20det Manual (duh) Upgrades S14 sr20det Blacktop 100,000 miles STI yellow top 550cc injectors No maf, converted to speed density with AEM EMS tuned by world class tuner Scott Seigel. AEM 30-4100 UEGO Thick, no name turbo manifold Stock s14 sr turbo Megan racing turbo elbow Megan racing down pipe ISIS black turbo lines* Mishimoto big radiator with waterless engine coolant (EVANS) Evans waterless coolant, they advertise you never have to change it for a life time CX Racing intercooler kit black piping with front mount Oversized Greddy BOV with flange HKS oil cap Custom intake, Countersteer Motoring made for turbo inlet painted wrinkle black, Aluminum No name test pipe SPEC clutch stage 2 with new throw out bearing and pilot bearing New 5 speed trans, last one was whining* Blue blood racing*gear*oil in trans 75w90 C's short shifter Subaru Star Burst Blue Engine bay Tucked brake lines Apexi Noir Cat back exhaust Circuit Sports Aluminum Steering Bushing Custom made battery tray Mini battery Z1 Steel 1-Piece Drive Shaft S14 VLSD Agency Power clutch line Tomei Shift Knob BC Racing BR Type Coilovers Cosmis MR-II, 17×9 +10mm 5×114.3 ISIS Front Tension Rods ISIS Rear Upper Control Arms ISIS Rear Traction Links ISIS Rear Toe Links ISIS 5 Lug conversion Yokohama S-Drive 235/40/17 Muteki SR48 Black Open End Lug Nuts 12x1.25 S14 Drivers seat Painted Trim and Wipers Flat Black Rolled Fenders Soon to come New seats Type X Spoiler Window Tint Z32 Brake Conversion Stainless Steel Brake Lines Maintenance OEM valve cover gasket OEM water pump OEM rear main seal Turbo gaskets OEM Nissan engine and trans mounts All Gates drive belts Motul 8100 engine oil OEM oil filter New Windshield Clutch master cylinder Dual cam power steering lines with high pressure hose Brake Master Cylinder Rotors/Pads Past, Problems/Issues * = Fixed *Heavy rust ALL around battery tray *Light rust and peeling paint on driver shock tower from leaking brake master cylinder *All front subframe nuts missing *Some hardware for front sway bar and tension arm brackets missing *One nut for brake pedal mount missing *Driver side inner wheel well under coating it peeling up and possibly rusting from *Leaking brake master *Random wood nail holding pin for brake pedal *The fuse box under the driver side dash is melted in a small spot and a replacement *Fuse holder has been installed by someone before us *Couple interior clips and bolts missing where I was working *One bolt missing from driver side front seat *Missing passenger side front fender liner *Brake booster was missing 1 of 4 nuts when removed, also had wood nail holding fork *Pin instead of oem clip. *Had to unscrew booster push rod in order to remove from car. *Driver seat hinge broken *Driver window won’t go up *Driver seat belt broken and mold Holes from spoiler Rack and Pinon boots broken Countersteermotoring Dylan Crumley from Countersteermotoring in GA did the work on this 240sx. He does an amazing job with these cars. He is a pro when it comes to working on cars and I’m really amazed at how hard he works to make a project perfect. 1238857_428806520555401_571721703_n.jpg 1969176_428806377222082_176516332_n.jpg 1796411_428806543888732_1710757766_n.jpg 10006587_428806553888731_603088246_n.jpg 1982250_428806657222054_467671374_n.jpg 1800492_429449497157770_675314426_n.jpg 1898253_429449503824436_701349692_n.jpg 1911641_429449570491096_135411488_n.jpg 1958375_429449643824422_1388745416_n.jpg 1898135_429449700491083_223341175_n.jpg 1907952_431855486917171_358068784_n.jpg 5504_431855520250501_197760006_n.jpg 1506749_431855616917158_1847031283_n.jpg 64874_431855576917162_1979807220_n.jpg 10151772_431855630250490_1302412567_n.jpg 1240053_431855710250482_948709199_n.jpg 1012913_431855870250466_687324308_n.jpg 1477384_431855676917152_431179128_n.jpg 1911865_431855846917135_1562725498_n.jpg 10007011_431855783583808_1831577347_n.jpg 10151912_434133203356066_532728108_n.jpg 10153881_434133246689395_881294404_n.jpg 10168060_434133283356058_389213271_n.jpg 1536723_434133263356060_1923153801_n.jpg 10006917_434133306689389_1398079414_n.jpg 1907981_434133330022720_1361128245_n.jpg 1977319_434133546689365_2060368564_n.jpg 1525306_434133363356050_1868556792_n.jpg 1382273_434133493356037_451812687_n.jpg 10170711_434133720022681_1961248680_n.jpg 1662526_10152332986882246_292820521_n-1.jpg 10349145_445789058857147_7994703504948266856_n.jpg 1017044_445789085523811_1962798618687468849_n.jpg 10245404_445789158857137_1579331468535530205_n.jpg 10339631_445789175523802_5689898909686072361_n.jpg 1619432_445789105523809_3144784106014202809_n.jpg 10320504_445789318857121_8508046933794978131_n.jpg 10171686_445789238857129_2209961956402957334_n.jpg 10302100_445789288857124_6713917496629367493_n.jpg 10169322_445789245523795_2368643181108156042_n.jpg |
05-12-2014, 11:11 AM | #5 |
Im in North Atl.
-IG- @SR_Hatch |
05-12-2014, 11:12 AM | #6 |
Thanks man, yeah Dylans a great guy.
-IG- @SR_Hatch |
build thread, countersteermotoring, s13, s13hatch, sr20det |
