Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Brakes
Old 03-17-2014, 09:36 AM   #1
maverickmotorsports
maverickmotorsports is an unknown quantity at this point
350Z/370Z/G35/G37 Dual Caliper Brackets!
NEW PRODUCT! USES OEM ROTORS AND CALIPERS!
This bracket allows you to use 2 pairs of OEM rear calipers for awesome stopping power. One pair of calipers gets plumbed up like normal and works off of the brake pedal. The other pair gets plumbed SEPARATELY to the hydraulic handbrake. No more weird pedal feel when pulling the e-brake and the footbrake! You now have a dedicated setup for the hydraulic handbrake.
Key features:
- Made in the USA by an Aerospace/Medical certified machine shop with ISO9001:2008 certs.
- 6061-T6 aluminum for strength and low weight used on brackets and spacers.
- Mil-Spec Hard Anodized finish on all aluminum parts.
- The brackets are CNC'd and not water jetted. CNC is much more precise and cleaner.
- FEA tested as well as real world tested on track.
What comes with the kit:
- One left bracket
- One right braket
- 4x caliper spacers
- 8x M12 Class 10.9 Bolts for hub.
- 8x M12 Class 10.9 Flange head bolts for calipers
Compatible with all 350z, G35, 370Z, G37 chassis. Also works on M45 and other Infinitis that have the same rear suspension.
**** Brackets are identical between Brembo and non-Brembo. The only difference are the supplied bolts ****
Need to know:- This will space your wheels out 8mm. It's like adding an 8mm spacer to the wheels. Please keep this in mind if you have flush fitting wheel already.
- You will need matching generations of caliper and rotors. Nissan changed the size of rear calipers and rotors after 2006. Make sure you use 03-05 parts or 06+. You CANNOT use 03 calipers on 06 rotors and vice versa.
- All years of Brembo and Akebono will match up.
- We recommend using a 3/4" bore hydraulic handbrake. 5/8" will work as well.
- Allows the proper use of a hydraulic handbrake. No more rigged inline setups that don't work when you need them to!
Order here:
http://www.maverick-motorsports.com/...aliper-bracket
Any questions feel free to call 623/565/8539 or email [email protected]
-George Marstanovic
Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more!
http://www.maverick-motorsports.com/collections/all
maverickmotorsports is offline   Reply With Quote
Old 03-17-2014, 10:30 AM   #2
Dustxking
Dustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of light
Great product! Have had mine for over 2 years and was one of my favorite buys for my car!
Dustxking is offline   Reply With Quote
Old 03-18-2014, 12:34 PM   #3
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
Can you make a set for s13 that utilizes stock calipers?
g2ic02 is offline   Reply With Quote
Old 03-18-2014, 12:58 PM   #4
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
No, you would have to cut out more in the knuckle and cannot use the stock calipers. If anything, could use the Q45 calipers but then would have to figure out which rotor to use with them, etc.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 03-19-2014, 12:20 PM   #5
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
will it work with the drum parking brake or do you HAVE to go hydraulic?
rebornS14 is offline   Reply With Quote
