02-16-2014, 09:38 PM | #1 |
5.0 Swap in S13
Hey guys im new to the fourm and new to the 240 world as well. I just got a s13 from a buddy with the sohc ka and im planning to do a ford 5.0 swap. I know it has been done before. What I want to know from the guys that have done the swap before is mainly what rear diff to use and what tricks you learned in the process of doing it to make it go as smoothly as possible. I want to have the swap done in the next 2 months or so in time for the Ocean City Cruise Week. I have a block and mounts that are coming out of a s13 already and a harness and already found a shop to make a driveshaft. I work at a shop that i have access to day and night so time shouldnt be a problem but its going to be on a college student budget.
02-16-2014, 09:52 PM | #2 |
Awesome swap, and good luck, i have a carbed oneI swapped in my truck and its fun.
http://www.facebook.com/BaddlineCust...lision?fref=ts |
02-16-2014, 10:36 PM | #3 |
Well people run the stock diff welded or clutch type and support crazy high numbers. I know a guy with a ls1 who has no issues with his kaaz. Either try to buy a used clutch type or weld it up.
02-16-2014, 10:46 PM | #5 |
As of now he is. If you want upgraded ones drive shaft shop has some. There's an axle thread that just started up that has more info than I know (as I'm still on stockers also)
02-16-2014, 11:54 PM | #9 |
How does the welded diff do on the road? I don't plan on this being much of a track car so it needs to have some streetability.
"If you're not first, you're last"- Ricky Bobby |
02-17-2014, 12:04 AM | #11 |
yet it had a welded diff lol.
Ive planned a ford modular engine swap, 4.6 more than likely, and was sooo close to start buying parts, but was able to talk myself out of it, too many projects already... Reason for picking this engine swap being how affordable it is and it's an ok motor. Good luck with your swap, 5.0's are good motors. |
02-17-2014, 12:07 AM | #13 | |
02-17-2014, 06:37 AM | #14 |
Does anyone have recommendations about fuel lines and pump? I plan on going turbo e85 in the future to i would like to have that set up. My boss was thinking AN fittings and bigger lines not sure what size yet but he was thinking we may have to drill out the holes in the sending unit and weld the fittings.
02-17-2014, 08:34 AM | #16 |
Yeah efi defiantly but not daily but not just a weekend car not too worried about fuel economy. Except long drives finding e85 will be a pain
02-17-2014, 08:52 AM | #18 |
Nope I'm a poor college kid. Junkyard build if you will lol maybe one day. I wanted to do a ls1 but my buddy already had the 5.0 block in a s13 with mounts and a harness that just needs bearings so that made up my mind
02-18-2014, 03:27 PM | #22 | |
And... My engine is wrapped up, chained to a longitudinal post where I keep many engines wrapped up. Its not installed in anything. Thus the for sale sticker. |
02-18-2014, 03:53 PM | #23 |
It's been done. It's a straight forward, well documented swap. However most come out like crap because the guys doing it are on a shoe string budget.
You'll also have to have extremely modest power goals. These engines like to come apart under high power applications (read 350whp) and the trans is fairly fragile. I've yet to see if anyone has ever completed a 351 swap, as the block is wider. But if you are handy, want a cheap project and a V8 gurggle, why not? Search the Googles. http://zilvia.net/f/showthread.php?t=417618 http://zilvia.net/f/showthread.php?t=485744 http://www.silviav8forums.com/forum/...776cde11d7f90d |
02-18-2014, 04:21 PM | #24 |
5.0 motors are big and difficult to fit but can be done and can make big power if built.
For the rear end, the axles are the weak part. Get either DSS level 5 ($1,000) or Mazworx axles ($1,800), which support 500+ rwhp. Neither are cheap, obviously. Rear ends in 240sx are stout, though a KAAZ 1.5 or Nismo LSD is suggested. Fuel system; depending on your power goals, dual Walbro 255lph pumps, a single Aeromotive 340lph are both solid, low maintenance options. Dual Bosch 044 pumps would be overkill and you would need a quality Aeromotive filer post-pump to remove any materials that come from the brushes in the pump. Aeromotive A1000 is overkill, requires a controller to be done right, is noisy and etc... Since my last car was a built, supercharged mustang cobra, I can vouch for the fact that they can make strong power.
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal |
02-18-2014, 05:20 PM | #25 | |
02-18-2014, 05:54 PM | #27 |
02-18-2014, 05:55 PM | #28 |
the T45, TKO500 and other Ford Mustang manual transmissions, before the T56 in the Cobra, Corvette and Viper, are rated at only 350rwhp and do break at that hp level. I know first hand.
The Ford 4.6 and 5.0 liter bottom ends, before 2003 would fragment pistons if pushed past 350rwhp. I can show you pictures from my 4.6 after this happened.
02-18-2014, 05:57 PM | #29 | |
Not sure if serious. The stock axels are fine. The trick is get some Autozne life time axels for $120 a pop... maybe even buy a spare set for track days. When they go bad... get new ones for free. |
02-18-2014, 06:00 PM | #30 | |
If you are looking to ditch a stock KA and have modest power goals, a Mustang swap will do you good. Weld the rear end, get some coil and go burn rubber with that awesome 302 sound. |
5.0 swap, help a kid out, s13 240sx |
