Old 01-16-2014, 12:00 AM   #1
SethG12
SethG12 is an unknown quantity at this point
Installed different stock camshafts on RB25 now wont turn.
I broke some valves in cylinder 2 on my s1 rb25det s13. So I decided to buy a complete cylinder head and swap my old camshafts into it. I took the good ones out of the head with bad valves, then took the cams out of the head I just bought and put the good ones in.. I completed both intake and exhaust and got cam gears put back on and they won't turn.. At all. It seemed like I put them in correct but I am asking for advice on if there is any certain way they have to go in or anything. I did slowly work the cam holders (whatever they're called) into place but I'm stumped.
SethG12 is offline   Reply With Quote
Old 01-17-2014, 07:29 PM   #2
rotation3x
rotation3x's Avatar
rotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choices
Send a message via AIM to rotation3x
did you torque them to fsm specs?
rotation3x is offline   Reply With Quote
Old 01-17-2014, 07:52 PM   #3
G-E@Z31P
G-E@Z31P is an unknown quantity at this point
If you over-torque the head, the head warps, the camshaft binds... maybe you got the Nm mixed up with ft-lbs
G-E@Z31P is offline   Reply With Quote
Old 01-20-2014, 02:55 PM   #4
Darius
Darius is on the path to ruinDarius is on the path to ruinDarius is on the path to ruin
Are your pistons at TDC? If so, you could have mashed the valves into the pistons when you installed the new cams. The reason I mention this is because I broke my #6 exhaust valve this way. Always install cams with the pistons slightly lowered into the bores. Then, rotate them to the rear timing cover marks and then turn the crank a few degrees to TDC to match.
Darius is offline   Reply With Quote
Old 01-20-2014, 04:42 PM   #5
Sileighty_85
Sileighty_85's Avatar
Make sure CAM Caps are installed correctly, It is possible to install them backwards causing them to bind the CAM Shaft
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
camshaft, rb25det
