Old 12-13-2013, 12:30 PM   #1
GetSydWys
GetSydWys is an unknown quantity at this point
Arrow TW- Hi Comp ka24de Sil80 built by groundperformance
changed my mind. shes staying with me
GetSydWys is offline   Reply With Quote
Old 12-13-2013, 12:52 PM   #2
gusisboosted
gusisboosted is an unknown quantity at this point
This is a very interesting build.
How much power does something like this put down?
I got a buddy i am getting into the car world, and would be good to get him in a N/A s13 with a bit more thump
petrolhead
gusisboosted is offline   Reply With Quote
Old 12-13-2013, 01:23 PM   #3
KendallH
KendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choices
Stock rebuilt KA, stock SOHC pistons, high compression, 370cc injectors, Cometic headgasket and boost? Sounds like you're building a bomb not an engine...
KendallH is offline   Reply With Quote
Old 12-13-2013, 02:07 PM   #4
GetSydWys
lol, make sure you do some more researching before you just talk outta your ass. it would be low boost around ~5-7psi when it is ka-t. the E85 is 104 octane which is guaranteed to NOT knock. thanks for the bump!
Old 12-13-2013, 02:11 PM   #5
GetSydWys
thanks brotha, at the moment hasn't been dyno'd but id guess right now around 165-170, this thing has instant torque and great response..if you get a tune to dial it in on N/A setup theres no doubt in my mind it would be in the low 190's...ka-t would be around 230-245.
Old 12-13-2013, 04:16 PM   #6
KendallH
Need to understand that higher compression and forced induction=much higher cylinder pressures. Stock puny KA rods won't enjoy that and neither will the stock pistons/ringlands. I understand the properties of E85, do you realize it takes approximately 30% more fuel to achieve a desired air/fuel ratio when compared to pump gas? Making your 370cc injectors effectively about 259cc.
I'm sure this motor runs great N/A and I wish you glws, but boost is not a good idea for that motor...
Old 12-13-2013, 05:34 PM   #7
rb27dets14
rb27dets14 has a little shameless behavior in the past
I'd boost it start at 12psi.....I didn't know there was such pussys in this world....stock Honda ITR motor is 11:1 or higher and they will make well into the 500s with just headstuds and last... Your gonna need bigger injectors,fuel pump and a clutch
Quote Originally Posted by andresr20
ffffffuuuuuuuuuuuuukkkkkkkkkk HONDAS
rb27dets14 is offline   Reply With Quote
Old 12-13-2013, 11:43 PM   #8
GetSydWys
haha word brotha. I forgot to mention it does have a 255 but im not looking for big numbers just something to have fun with and be reliable., either way its a solid setup as is..or ka-t. ill probably look into s15 injectors not a bad idea
Old 12-14-2013, 04:35 AM   #9
speedracer5
speedracer5's Avatar
Trader Rating: (24)
speedracer5 is on the path to ruinspeedracer5 is on the path to ruin
Feedback Score: 24 reviews
Will you sell without front end. Im more of a piggy front end lmk.
speedracer5 is offline   Reply With Quote
Old 12-15-2013, 12:00 AM   #10
GetSydWys
shoot me a offer, # listed above
Old 12-15-2013, 12:57 AM   #11
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
KA
I like how you did your math here. You calculated 30% of 370cc to come up with that 259cc like the KA actually comes with 370cc stock.. Just some correction stock KA are 270cc so to convert to E85 will be atleast %30 over stock so it would be additional 81cc on top of 270cc which would be what? 351cc if anything were a bit on the rich side. It's definitely not advisable for any high boost given the parts specs but should be able to handle just small amount to be fun..
Here's a vid of a similar spec running T3/T4, obviously larger injectors, maf it will hold on done right and properly tuned.
http://www.youtube.com/watch?v=1L6w1tCnS50
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
Old 12-15-2013, 01:09 AM   #12
GetSydWys
thanks boss, yea ima keep it so it gets the ka-t setup it deserves lol.
bam, e85, hatch, ka-t, silvia front
