Old 11-02-2013, 04:27 AM   #1
ohhdude
ohhdude's Avatar
ohhdude is an unknown quantity at this point
Send a message via MSN to ohhdude
SR SR20DET crankshaft problem
Hi I have a blacktop sr20det engine and i need a crankshaft for it. I went to junkyard and found a sr20 engine. I bought the crankshaft. And the part number is on the crankhaft is 60j45, I know sr20 uses 60j00 and 60j10. Is anyone know that is this cranksaft usable or not?
I have never heard 60j45.
I have made a research about this cranksahft but found nothing.
Any ideas?
ohhdude is offline   Reply With Quote
Old 11-02-2013, 04:43 AM   #2
TheRealSy90
TheRealSy90's Avatar
60j45 is a fwd sr20de crankshaft of some sort. Fwd and rwd cranks are the same. I'm pretty sure the number itself is in reference to the oem bearing clearances.
Such a good signature.
Old 11-02-2013, 05:41 AM   #3
ohhdude
ohhdude's Avatar
Thank you..
So i have to buy another bearing set for this crankshaft. For which car should i have to buy?
Old 11-02-2013, 06:27 AM   #4
ohhdude
ohhdude's Avatar
I meant what type of beraing should i have to use for 60j45
Old 11-02-2013, 10:29 AM   #5
jr_ss
It's best to use OEM bearings as they have more sizes to better suit your desired tolerances. Have the machine shop measure what size bearings you need and go from there.
Old 11-02-2013, 04:47 PM   #6
TheRealSy90
You should be able to go to nissan with the part number from the crank and get whatever bearing sizes came on it originally.
Old 11-03-2013, 03:03 PM   #7
ohhdude
ohhdude's Avatar
Thanks a lot guys for your help. Tomorrow i will go to Nissan and ask for the bearings .
Now i have two options
1) micro polishing the 60j00 crankshaft and using acl 0.05 or 0.025 bearings
2) using 60j45 crankshaft ( never polished and original specs.) with oem bearings
Which option is the best and durable for track days?
Are the bearings for "60j45(fwd sr20de)" and "60j00/10 (rwd sr20det)" has the same strenght or not?
Sorry about my bad English
Old 11-04-2013, 08:55 AM   #8
ohhdude
ohhdude's Avatar
Today i went to Nissan to ask bearings for 60j45 and he couldnt find anything about it. He told me that "i need chasis number of the car which uses 60j45 then i will found bearings for it". I am so confused.
Old 11-04-2013, 09:52 AM   #9
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
should be nissan sentra i believe. 90's but im stupid so im probably wrong
Originally Posted by Hoffman5982 View Post
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 11-04-2013, 01:44 PM   #10
ohhdude
ohhdude's Avatar
lol, thanks
Old 11-05-2013, 11:05 AM   #11
ohhdude
ohhdude's Avatar
bump
any ideas?
Old 11-06-2013, 08:57 AM   #12
EccentricBro
EccentricBro is an unknown quantity at this point
98ish sentra se-r used the FWD sr20
EccentricBro is offline   Reply With Quote
Old 11-06-2013, 12:28 PM   #13
Gumbrick
Gumbrick is an unknown quantity at this point
Mics are the best way to do this although you can fetch similar results per fsm... You need to look for the numbers of journal and rod grades stamped on your crankshaft, and correlate them to the numbers stamped on your block. (numbers on block are for mains only, use rod numbers off crank. Rod races are identical for all 4,) This cross-reference/ decoding procedure is covered in the FSM. Following this method will result tight oem clearance. Go a grade or two lower if you want some added clearance.
Gumbrick is offline   Reply With Quote
Old 11-06-2013, 12:36 PM   #14
new2sr20
new2sr20 is an unknown quantity at this point
Nissan SR20DET Crankshaft Kit Crank s13 s14 S15 Silvia 180sx 200SX Bearings Rod | eBay
problem solved
new2sr20 is offline   Reply With Quote
60j45, crankshaft
