Old 10-24-2013, 08:17 AM   #1
Boostage
Boostage is making his/her stupidity well-knownBoostage is making his/her stupidity well-knownBoostage is making his/her stupidity well-knownBoostage is making his/her stupidity well-knownBoostage is making his/her stupidity well-known
S14 Fuel capacity question
I found out that the tank is 17.2 gallons, but when the needle reaches "e" how much fuel is left?
Boostage is offline   Reply With Quote
Old 10-24-2013, 08:18 AM   #2
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
17.2 minus how much you can pump in when gauge is at E.
OnTheChip is offline   Reply With Quote
Old 10-24-2013, 08:25 AM   #3
EatRice
EatRice's Avatar
EatRice is an unknown quantity at this point
bam * engineering wins again
EatRice is offline   Reply With Quote
Old 10-24-2013, 08:27 AM   #4
Boostage
I should have stated that the car doesnt run as yet. I need to know because I will be blending fuels and need to get the right ratio, the baseline will be whatever the amount of fuel is in the tank when the needle is at E. thats why I need to know.
Old 10-24-2013, 09:00 AM   #5
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
From what I've been able to figure out using my S14, when the tank reads 'E' there are about 1.5-2 Gallons of fuel left before the light comes on, and once the light is on, there are about 2 Gallons left in the system. (So E measures something around 3-4 gallons left)
It's worth noting that the S14 gauge is known to 'float' quite a bit once the gauge drops below 1/4 of a tank, so if what you're doing needs to be reasonably precise, you're better off draining the tank (not that hard) and filling it with a known mixture.
thefro526 is offline   Reply With Quote
Old 10-24-2013, 10:03 AM   #6
Boostage
Thank you!
