Old 05-27-2013, 01:43 AM   #1
ShimiBoi
ShimiBoi's Avatar
ShimiBoi is an unknown quantity at this point
KA T25 on KA-T making noise and not reaching full boost! Help!
Hello all,
First off, thank you all for your help in advance. So I just turbo'd my KA with SR piping and a T25. I recently replaced the hose going to the wastegate from the intake piping (between the IC and TB) with a much longer hose that is about a foot longer to accommodate a MBC. However, I decided not to connect it but left the hose long. Now I have noticed that there is a weird noise coming from the turbo under boost and a whistle when slowing down in neutral, which never used to happen. Motor slightly bogs down then idles at 700rpm (normal was 900rpm). AFR is still mid 15s at idle. Boost gauge needle shakes between 6 - 7psi in 3rd gear at WOT. Turbo no good? Wastegate opening? Sorry for the long post. Please help.
ShimiBoi is offline   Reply With Quote
Old 05-27-2013, 09:12 AM   #2
cotbu
cotbu's Avatar
.................Lame
Old 05-27-2013, 03:27 PM   #3
ShimiBoi
ShimiBoi's Avatar
Anyone? Please help.
Old 05-27-2013, 03:29 PM   #4
ShimiBoi
ShimiBoi's Avatar
I meant I didn't use the MBC but the vacuum line is still connected to the WG. I'll check for oil in the pipes now.
Old 05-27-2013, 03:34 PM   #5
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Check for a boost leak?
Old 05-27-2013, 11:45 PM   #6
ShimiBoi
ShimiBoi's Avatar
Unhappy
Couldn't find any boost leaks. But I did notice that there is a loud rattling noise at 3000rpm in all gears. I'm fearing that the turbo is making the noise. But I'll look more into it tomorrow. Boosting seems to be fine. No metal know the intake piping before the IC. Not sure what is causing the rattle.
Old 05-27-2013, 11:50 PM   #7
Sileighty_85
Sileighty_85's Avatar
check for shaft play on the turbo.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-28-2013, 05:32 AM   #8
jr_ss
7psi is max psi on just wastegate spring pressure. Post a video of the rattle.
Old 05-28-2013, 08:36 AM   #9
ShimiBoi
ShimiBoi's Avatar
I know there was some shaft play when I installed it a few weeks ago, but not that bad. I hope it is just something rubbing other than the compressor wheel.
Old 05-30-2013, 12:07 PM   #10
ShimiBoi
ShimiBoi's Avatar
So it turned out to be the downpipe bolts backing out. Thanks everyone for the help.
Anyone know what a good base timing is on a ka-t running an Enthalpy tune is?
Old 06-01-2013, 10:45 PM   #11
Duncan Steele
Duncan Steele is an unknown quantity at this point
Should have just gone SR...
1f y0u c4n r34d th15, y0u r34lly n33d t0 g37 l41d.
Duncan Steele is offline   Reply With Quote
Old 06-02-2013, 08:55 AM   #12
Duncan Steele
Also did you upgrade the injectors? Adding boost is going to make the car run leaner, so your engine might blow cause it's running to lean.
Old 06-02-2013, 09:24 AM   #13
!Zar!
!Zar!'s Avatar
Sounds like you have a boost leak between the maf and the turbo.
Old 06-03-2013, 02:00 PM   #14
motteramm
motteramm's Avatar
motteramm is an unknown quantity at this point
Set your timing back to normal. The timing on any Rom tune (or any tuned ecu) is done in the ecu itself. You don't have to change timing at the distributor or anything.
"I have no cupholder"
motteramm is offline   Reply With Quote
boost, ka-t, s13, t25
