Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > Canada > Alberta
Old 04-28-2013, 11:32 PM   #1
tuner117
tuner117 is an unknown quantity at this point
KA24DE cooling issue help!!
Hey, so I was recently involved in a car accident and had to replace my front end (rad, bumper, both quarter panels) but in the crash it also blew apart the tiny electic fan In front of the belt driven fan. Is the electric fan essential for the cooling?
tuner117 is offline   Reply With Quote
Old 04-28-2013, 11:41 PM   #2
No 240.. No id
No 240.. No id's Avatar
No 240.. No id is on a distinguished road
The front electric fan is for the AC condenser. I think you have a heating issue because when you replaced the radiator you did not bled the air out. Try to bleed the air out.
You can sleep in your car, but you can't drive your house.
No 240.. No id is offline   Reply With Quote
Old 04-28-2013, 11:48 PM   #3
tuner117
I did bleed the air out five or six times will do more but any other ideas on what it could be?
Old 04-29-2013, 03:05 PM   #4
Sr20SilviaS13
Sr20SilviaS13's Avatar
Sr20SilviaS13 is an unknown quantity at this point
If you used the only clutch fan, which i doubt but worth asking, make sure the clutch is good.
Bleeding air out of a KA is pretty simple, how are you doing it?
grab the lower hose when you are at temp see if it is hot or cold. If cold your thermostat is not functioning. If hot you are all set.
I do motor swaps in exchange for lunch.
Sr20SilviaS13 is offline   Reply With Quote
Old 04-29-2013, 03:12 PM   #5
tuner117
The clutch is like brand new. Just opening the rad cap and letting the air out. And I will check if the thermostat is working or not. I can't think of anything else that could be really. Could there be a problem in the rad? Possibility. But idk of anything else.
Old 04-29-2013, 08:30 PM   #6
PandahZ650
PandahZ650 is an unknown quantity at this point
Send a message via AIM to PandahZ650
it's more likely the thermostat than a radiator, the thermostat controls the amount of coolant allowed to flow through your motor.
you also might want to try to use the bleeder screw by the upper radiator hose to bleed your system
PandahZ650 is offline   Reply With Quote
