Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 04-17-2013, 06:37 PM   #1
JBtuned
JBtuned's Avatar
JBtuned is an unknown quantity at this point
Thumbs up Nismotronic @ JBtuned.com
JBtuned is an Authorized Dealer/Installer/Tuner for Nismotronic Nemu
The Nismotronic RT stand alone engine management systems is a great solution for anyone running a sr20det or Ka24 setup that is tired of having inadequate tune-ability because Apexi afc’s just don’t cut it anymore. These systems solder into your factory OBD-1 Ecu and once installed, this hardware turns your obd-1 ECU into a standalone unit. No need to swap sensors, wiring, etc. and you didn’t have to waste your whole tax return on it like some systems.
This is the list of features taken directly off Nismotronics Website.
NEMU RT Board Features:
• Single USB connection for logging and Emulation (No need for a consult cable!)
• SUPER fast realtime emulation and logging (Uploads and Downloads)
• 4MB Onboard Logging capacity
• 4 Analog input channels for viewing any 0-5v sensor input (wideband, map sensor, iat, egt, oil pressure)
NismoTronic RT Software Features:
• RealTime Tuning and Logging via NEMU RT Boards
• Onboard Logging via NEMU RT Boards
• ADC Inputs for Wideband/IAT/ETC via NEMU RT Boards
• User Definable Live Gauges
• User Definable Live Graphing
• User Definable Monitor Table
• AFR Target Table (Target AFR)
• AFR Raw Table (Logged AFR)
• AFR Difference Table (Difference in Logged vs Target AFR in percentage)
• User Definable MAF curves! (Create your own custom MAF curve and save it into the MAF Data file to use on multiple tune files with just one click!)
• Intuitive GUI with visual graphig.
• Tons of quick keys for quickly editing table values.
• SLC Pure Plus Wideband Support
• Innovate Motorsports Wideband Support
• AEM UEGO Wideband Support
• PLX iMFD Wideband Support
• Zeitronix Wideband Support
• Program Auto Update Feature
• Import/Export Fuel and Ignition tables
• Interactive 2D Graphing
• RealTime Monitor Tables for each logging item
• Export Data Logs to CSV format for viewing in other programs (EXCEL, Virtual Dyno)
TunerCode V5N ECU Firmware:
• High RPM tuning limit (8012.5 rpm) removed.
• Choice of soft cut or hard cut rev limits.
• Launch Control.
• Overboost rev limiter.
• Soft cut Speed Limit (Can be disabled or set for valet mode)
• Spark cut limiting, in addition to fuel cut limiting.
• Set Launch uses throttle, tach, and gear shift to set launch rev limit
• Programmable Outputs (for VVL, NOx, Fans, etc.)
• Injector Size parameter.
• Uses only one fuel map.
• Uses only one timing map.
• Uses only one CLT enrichment table.
• Enable/Disable Knock Analysis
• Enable/Disable Closed Loop O2 Analysis
• Enable/Disable Long Term Fuel Trim (self-learn)
• Enable/Disable TPS fuel map load column contol
• Enable/Disable EGR
• Enable/Disable AIV
• Enable/Disable O2 Sensor Heater
• Enable/Disable A/C Compressor
• Programmable A/C Compressor control
• Programmable Radiator Fan control.
• Tuning Tables/Parameters for:
  • 1. Fuel/Timing Maps and Tables
  • 2. Knock Control
  • 3. Dwell
  • 4. Startup fuel/timing
  • 5. Accel Enrichment
  • 6. TPS Enrichment
  • 7. CLT Enrichment
  • 8. Decel Fuel Reduction
  • 9. Idle fuel/timing
  • 10. Fuel Cut control
Supported ECUs:
91-93 Nissan Sentra/SE-R/NX2000/Pulsar B13,N14,N15 SR20DE Manual
ECU Part Nos: 64Y00, 64Y01, 67Y00, 68C00, 1N960
91-93 Infiniti G20 P10 SR20DE Manual
ECU Part Nos: 62J00, 62J01, 77J00
91-93 Nissan 240sx S13 SR20DET Manual
ECU Part Nos: 50F00, 50F01, 50F05
91-94 Nissan 240sx S13 KA24DE Manual
ECU Part Nos: 53F00, 53F01
Nissan Pulsar RNN14 SR20DET
ECU Part Nos: 54C00, 54C60
SPL Parts | BC Racing | Nismotronic | AEM | Grip Royal | Comp Clutch
JBtuned is offline   Reply With Quote
Old 04-17-2013, 07:05 PM   #2
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
What kind of price tag comes along with this.
g2ic02 is offline   Reply With Quote
Old 04-17-2013, 07:09 PM   #3
JBtuned
JBtuned's Avatar
The whole setup, hardware, software and license is $550.
Old 04-17-2013, 07:43 PM   #4
mechavore884
mechavore884's Avatar
mechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymore
so uhhh do you guys have any plans to support 95 240 ECUs?
mechavore884 is offline   Reply With Quote
Old 04-17-2013, 07:56 PM   #5
JBtuned
JBtuned's Avatar
Well we currently run this setup on our 95 s14 KA24. We took a sr20 jumper harness and just re-pinned it and use that to drop down to our s13 ecu with the nismotronic in it.
Old 04-17-2013, 08:11 PM   #6
JBtuned
JBtuned's Avatar
The new update that is due to release in the next few months will also support coil on plug conversions, speed density, boost by gear, flex fuel sensor capability, and a whole long list of other features to ad to this already great setup. Updates are free. It really is a great ems solution.
Old 04-18-2013, 12:01 AM   #7
kojiki88
kojiki88's Avatar
kojiki88 is an unknown quantity at this point
I am currently running Nismotronic on my S13 SR20DET and I love it. It is very easy to use.
kojiki88 is offline   Reply With Quote
Old 04-18-2013, 12:02 AM   #8
jamg
so how do i get something like this?
Old 04-18-2013, 12:03 AM   #9
blackrms13
blackrms13's Avatar
Very interesting!
Would LOVE to see more reviews!
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 04-18-2013, 12:11 AM   #10
JBtuned
JBtuned's Avatar
If you order from our website JBtuned.com we can either mail you the nemu board and you can install it yourself, if you have the tools or you can mail your ecu to us and we will install it for you and mail it back. There is no charge for the install/ soldering work from us. We include it in the price. You would just have to cover shipping to us. The shipping you pay at checkout will cover it on the way back.
Old 04-18-2013, 12:53 AM   #11
iamtheyi
iamtheyi's Avatar
iamtheyi is an unknown quantity at this point
Subscribing in wait for the 95 ecu
iamtheyi is offline   Reply With Quote
Old 04-18-2013, 01:58 AM   #12
jamg
and i have to find a tuner who can tune this type?
Old 04-18-2013, 05:03 AM   #13
MrSanchez925
MrSanchez925 is an unknown quantity at this point
Will you guys be releasing a version that supports the z32?
MrSanchez925 is offline   Reply With Quote
Old 04-18-2013, 05:51 AM   #14
hotlavaflow
hotlavaflow's Avatar
hotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to behold
Send a message via Yahoo to hotlavaflow
I was looking to get a Nistune set-up in about a month or so, how does this compare?
hotlavaflow is offline   Reply With Quote
Old 04-18-2013, 08:37 AM   #15
JBtuned
JBtuned's Avatar
Yes but any experienced tuner should not have a problem picking up this software as it is extremely user friendly and also there are plenty of how to guides on nismotronics website And help me files are all loaded in the software about the ecu logic. If they ever have questions.
It is compable with all widebands and comes with black box called a breakout box. This allows you to supply input or feed power to sensors devices without cutting into your factory wiring.
Also Facebook.com has a Nismotronic active group of tuners and installers (this includes me) and the developers on there showing upcoming software releases, and help if ever needed. It is a very friendly helpful community.
Old 04-18-2013, 08:39 AM   #16
JBtuned
JBtuned's Avatar
I know they are working on a new release for the current supported motors for a lot of advanced upgrades. Then they plan to move on to all the 6 cyl engines RB z32 etc... Not sure how long that will be from now though.
Old 05-01-2013, 09:52 AM   #17
jholman05
jholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nice
Send a message via AIM to jholman05
I also have a Nismotronic ECU on my KA24DET, it's easy to make a csv log and load it straight into virtual dyno to create a dyno plot. I did this one with a GTi-R T28 and 12psi, red was stock S14 cams, blue was aftermarket 264 cams.
jholman05 is offline   Reply With Quote
Old 10-18-2013, 10:38 PM   #18
seagrasser
seagrasser is an unknown quantity at this point
Subscribed for 6 cylinder update
S14 RB25
seagrasser is offline   Reply With Quote
Old 05-27-2016, 12:02 AM   #19
sr20time
sr20time is an unknown quantity at this point
Very surprised this thread is not active
sr20time is offline   Reply With Quote
Old 02-11-2017, 07:09 AM   #20
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough
Feedback Score: 24 reviews
me too, plan on running nismotronics sa on my SR and want to run it as speed density and having trouble finding reliable info on it
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
Old 02-11-2017, 08:51 AM   #21
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
This is quite active: https://www.facebook.com/groups/145162022225980/
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 02-11-2017, 03:18 PM   #22
1988montecarloss
Trader Rating: (24)
Originally Posted by 5280VertDET View Post
You da real mvp
IG: @Haley72692
Old 05-29-2019, 07:48 AM   #23
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
bump, I have nismotronics anyone else?
supersayianjim is offline   Reply With Quote
engine management, nemu, nismotronic, standalone, tuning
