Old 12-27-2012, 07:12 PM   #1
Nitro240
Nitro240 is an unknown quantity at this point
1990 240SX SE Hatch w/ KA24DE and Extras | $2500
Copied from my CL ad:
1990 240sx SE
~174k miles (actual miles lower since speedometer reads 20mph higher)
Hatchback
'91dual cam ka24de swapped in with 80k miles
Short throw shifter
248/248 cam swap
CAI
Catless exhaust
S14 seats (mint)
Welded diff
strut braces front and rear
lower front subframe brace
Rear subframe mounts
MDU coilovers
dual Head Unit with Ipod Integration, AUX input. Stock speakers don't do it justice!
Drift button on ebrake..
Issues with car:
Has a miss in #3, poor sparkplug wire to blame. I didn't have time to fix it but its only $40 for a set of wires. Has new NGK plugs.
Broke OD/Reverse shift fork, so I would bought another trans to swap in out of a 91 with 70k miles. Again, didn't have time to swap the trans so you get the new spare trans ($200).
Open to offers. Car can be loaded onto trailer even with miss but I wouldn't drive it more than that before new wires are installed.
Car has small dings but not bad for a 23 year old car. The only rust is on driver side rocker panel.
Engine has a slight oil leak, primarily from sitting (probably the cause of the miss). I never had a chance to put a serious amount of miles on it.
Also comes with another set of stock alloy wheels and a mix-match set of OE and steelies with junk tires on them. Stock shifter, stock cams, a stock 232 cam to swap in the exhaust side for a bit more low end and midrange torque, and a stock S13 passenger side seat.
Price is 2500 OBO.
If you have any questions about it feel free to ask me. It was a drift toy for a while, then I picked it up, drove it on the street for a while, then lost interest in the project.
It ran a best of 15.3 at 80 something mph at 2850lbs with me in it, with the Michelin hyrdoedge tires on the back. 800 treadware FTL... Great dorifto tires, though.
Alright, any takers?
Nitro240 is offline   Reply With Quote
Old 12-27-2012, 07:26 PM   #2
DoobieS13
DoobieS13's Avatar
DoobieS13 is an unknown quantity at this point
Better pics of the rust? I, like many others, have our boners go into limp mode when we here rust...
Doobie
DoobieS13 is offline   Reply With Quote
Old 12-27-2012, 08:25 PM   #3
Nitro240
Good question, see attached:
Old 12-27-2012, 08:28 PM   #4
DoobieS13
DoobieS13's Avatar
msglength
Doobie
Old 12-27-2012, 08:42 PM   #5
Nitro240
Sorry, hit submit too quickly.
Old 12-28-2012, 01:37 PM   #6
Nitro240
What do you think Doobie?
Old 01-01-2013, 08:39 PM   #7
Nitro240
New Years BUMP! Looking to move this beat to a new home!
Old 01-01-2013, 08:45 PM   #8
ronny.jpn
ronny.jpn's Avatar
ronny.jpn is an unknown quantity at this point
You said the miss was due to the sparkplug wires, but then you said the leaking oil was probably a cause of the miss... which one because that could make a huge difference.
ronny.jpn is offline   Reply With Quote
Old 01-01-2013, 09:12 PM   #9
Nitro240
It has an oil leak that I believe to be caused by sitting, just like the miss as it sat for a few month then I fired it up and voila there's a miss. I replaced a dead injector, fixed the miss, it sat again, miss came back in a different cylinder, replaced plugs, it went away, sat, now miss is back. I haven't done any more diagnostics.
240sx, fastback, hatchback, ohio
