Old 10-19-2012, 11:10 AM   #1
Mannykiller
Mannykiller's Avatar
Mannykiller is an unknown quantity at this point
Thumbs up Mannykiller's Fd3s Drift build project: #Thisisthewolf
Whats up guys, well first off my name isn't manny. Its Aaron P..... mannykiller is just a name I came up for forums because I had a guy try to sell my motor out of the shop he owned. His name was manny...and was a little philipean guy that I would deck in the jaw if I ever saw him again. Either way I got my stuff back thanks to some guys ratting out his location and the location of my stuff. Onto the good stuff though. I bought a Fd almost 3 years ago and blew an oil control ring about a year into that. I've been building the car for almost 2 years now and it's getting close to being finished. I figured i'd share my build with you guys. I love drifting, and I love dricing on the steet. Yes I live in CA about 20 min from Willow Springs international raceway..so just drift and all the good stuff is very close to me. I also enjoy track days and time attack... I've geared this build towards being able to let me participate in all the fun stuff. So onto the good stuff. The pics...
Epic build opener
me ane my buddy Evan pulling the motor
before
Last edited by Mannykiller; 01-02-2016 at 09:43 PM.. Reason: Because no Trash Talk
Mannykiller is offline   Reply With Quote
Old 10-21-2012, 07:10 PM   #2
Mannykiller
Well I guess I should list the things i've done to the car thus far..
Engine:
13B-Rew
Built and Large Street ported by Howard Coleman
Dynamic balanced Rotating assembly by Atkins Rotary W/ low mileage rotors
NRS 1pc 3mm Ceramic Apex Seals
Power FC
Rywire Mil-Spec Engine Harness W/Cannon Plug at Fire wall
Oil Metering Pump Delete
Exedy Twin disc cerametallic clutch
One off Virtual Works Upper Intake Manifold
Excessive Manufacturing Lower intake manifold
Full Function Engineering Primary/Secondary Fuel Rails
-6AN Push Lock hose and fittings
Edelbrock 74MM Throttle Body
I.D. 850 Primary, I.D. 2200 cc injectors
2X Bosch 044 Fuel Pumps
CJ-Motorsports Dual pump Hanger
Aeromotive Fuel Filter W/shut off valve
Dual 25 Row Mocal Oil Coolers w/braided Line
Custom Power steering Relocation
Custom Coolant filler neck
Custom Divided Turbo Manifold with Dual gate ports
2X Synapse 50mm Waste-gates
2X CX racing Intercoolers...one used as I/C the other was converted into a dual Pass Radiator.
Tial BOV
GTX3582R turbo
Custom charge tubing
Custom 4" DP & Exhaust
Powered by Max Dual EGT kit with 2x EGT displays
Suspension/drive-line
Stance XR coilovers custom valved W/swift Springs 8/10
Full Super-Pro Bushing kit installed
New rear Wheel bearings
All new Pillow Ball Bushings
ARP extended Wheel Studs
Turbo 2 Clutch Type LSD unit
OEM FD trans
PBM Angle Kit W/rack spacers
Sake Bomb Garage S/S braided brake lines
Rebuild OEM calipers
ABS Delete Kit
Memory Fab s68 Carbon Seat
OMP Corsica 330
and more but honestly i'm kinda sick of trying to remember what's been done or bought..
May or may not be forgetting something...anyways onto the pics!
Sand Blasted all my suspension
painted suspension arms & sub frame
Old 10-21-2012, 07:15 PM   #3
Mannykiller
Painted suspension
Bearings out
New bearings in
Pushing super pro bushings in..getting them out was a pain in the ass
ARP wheel studs
steering rack paint and heat barrier
sold my old wheels
Stance Coilovers came in
insalled suspension components
Old 10-21-2012, 07:16 PM   #4
drscooper
drscooper is an unknown quantity at this point
dam i like! i love FD builds deff in for updates! keep it coming!:0
and love the gold man!! looks good!
drscooper is offline   Reply With Quote
Old 10-21-2012, 07:23 PM   #5
Mannykiller
Cleaned and sprayed 3m undercoating for wheel wheels
R40's came in
Balanced rotating assembly
fresh 3mm Rotors
Heat barrier trans tunnel
Diff Install and Shim/ setting backlash
more thermo-tec heat barrier...came out nice..
adios seam sealer
fuel filter w/shut off
before
after
Gold heat barrier
welded Power Plant Frame
Old 10-21-2012, 07:27 PM   #6
Mannykiller
Painted and set up my AEM water methanol injection
my buddy li Kuhn drew a little inspiration on my white board haha
Diff install
Fuel filter relocation
not bad..huh!
life and times haha
Old 10-21-2012, 07:28 PM   #7
Slims
Slims's Avatar
Slims is an unknown quantity at this point
wish i had an FD, ill be watching this one! looking good so far.
Slims is offline   Reply With Quote
Old 10-21-2012, 07:37 PM   #8
Mannykiller
Alternator case sand blast, and paint
end links too..
3M dinoc carbon overlay...no its not real carbon
before
after
wastegates 50mm synapse gates
motor assembly
a little stitch welding
origin 50mm over fenders
got my motor back from Howard coleman too!! brap dreams.....=-)
Old 10-21-2012, 08:02 PM   #9
Mannykiller
Motor install
prelim mock up
Time to head to the fab shop.......as much as I wish I could do everything... sometimes you just cant haha.
more ry-wire goodness and Power Fc
TUrbo mock up
cleaning up the V-band flange...
fuel stuff
cut wheel wells for over fenders
fuel pressure reg mount
bjdoing is thing too..
touge factory pullies
Old 10-21-2012, 08:24 PM   #10
Mannykiller
Fuel hanger complete!
had to re-locate the power steering pump because it was hitting the throttle body..came out pretty nice though
ported my LIM
Before
after
cut some sheet metal because Ihad to cut out the inside of the fenders. didn't want to have to worry aboutnot being able to lower my car at all..or clearance issues
ran fuel lines and set up lim with injectors for mocking purposes
bad ass parts picture
Old 10-21-2012, 08:36 PM   #11
Mannykiller
First set of rears came in
Rota GTR-D 18x12 in flat black.. most likely will be painted or pc'd...not sure what color though
Mick frial at THunder on the Lot 2012....I thank this guy for most of my inspiration, hope to participate next year!
for the heck of it...245 45 on a 12.....and no I won't be running these tires
Manifold tube came in
Parts shop max dual egt kit
Custim seat brackets...nice and low and as far back as possible for my monkey arms and legs
test fit
Turbo mani mock up
radiator design
Front wheels came in
P45r2 18x10
Final seat position
Radiator being finished
Old 10-21-2012, 08:46 PM   #12
Mannykiller
Radiator mount
got some more rears Advan TCIII's =-) 18x11 +15
baught a new daily.. 2012 prius...yea yea yea...hate all you want.. but i truly feel like it's the best investment i've ever made haha. all I need is some 15x7 RPF1's now...lemme know if anyone comes across some and wants to sell em..!! averaging 517-520 miles per tank..(9.7ish) gallons. Beat that!
Made a custom Coolant filler neck
Shineauto Feed fenders..+20mm
OMP corsica came in.... 330mm =-) love this wheel!
Radiator Mount
-16AN fittings for coolant
Old 10-21-2012, 09:38 PM   #13
Mannykiller
Radiator mount
Radiator Mount
Old 10-21-2012, 09:49 PM   #14
Mannykiller
My heat exchanger design
Cradle for Radiator. This will support the whole radiator with 1/8" rubber on the bottom and more rubber mounts on top. Don't want it to be too solid.. cracks and stress isn't ever good.
Manifold runner all welded up
Garrette GTX3582R with 3"to4" V-band... damn adapter was expensive.. 70 bucks!!
4" downpipe
Intercooler end tanks
Intercooler almost done
IC mounts
Johnny boy doing his thing
BOV charge tube
Very nice.. raditator cradle came out good
Old 10-21-2012, 10:18 PM   #15
Mannykiller
Mock..YEAAA.....ING.......YEAAA....BIRD... jk..but seriously name that movie..
Looking good..and coming along
Making sure we have clearance for the turbo mani..
Looks good so were go for tacking
90% finished manifold
mmmmhmmm
Downpipe mock up..it's a squeeze..
Tack tack tack... fender wells for over fenders
Silocone sealer to keep the shiiii out
Turbo Charge side of IC welded
Made some Screamer pipes for my wastegates, still need to cut them and pretty them up but they're going to the atmoshpere
Cut a plate for my cannon plug for the Engine wiring harness.
just need to tack it onto the firewall
brought my old exhaust and oil coolers to make sure they fit... but decided that i'm trashing the whole exhaust.. and going with a new system. 4" all the way to try to get everything we can out of the gtx35r. If any of you guys are familiar with HP turbo ratings..For rotary.. you take whatever the turbo is rated for and you divide it by 1.3 "13b-rew" displacement. So almost maxing out this turbo is my goal. I'd like to get the broadest power-band possible. WHP under the curve! My power goal is 450-480WHP. I'm also trying to make the most power at as low a PSI as possible. Efficiency wise..it'll just be better if we can make 450WHP at say 20PSI compared to 25PSI. Less stress=better reliability.
anyways..back to pics..
Oil coolers. 25Row Mocal's
Line routing.. surprisingly everything is going to fit without modification.. THANK GOD!
And finally mounted
SO this is where I currently am in regards to progress with the build. Hopefully I'll have some more updates soon.
Just ordered my Radiator -16AN fittings today so they should be in from summit this week. Other than that.. just tidying up some loose ends.
Old 10-21-2012, 10:21 PM   #16
xpertsnowcarver
xpertsnowcarver's Avatar
Trader Rating: (44)
xpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud of
Feedback Score: 44 reviews
Nice, been watching your build since you started it on RX-7 club. Great attention to detail. Keep up the good work.
My YouTube Channel
xpertsnowcarver is offline   Reply With Quote
Old 10-21-2012, 10:31 PM   #17
Krusty_s13
Krusty_s13's Avatar
Krusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud of
keep up the good work.
Krusty_s13 is offline   Reply With Quote
Old 10-21-2012, 10:36 PM   #18
Mannykiller
Hey thanks man! I've learned a ton from 7club...but they seem to be a little close minded.
I got a few more pics of this past weekend and Allstar bash. Just for kicks..becuase everyone loves pics..
Me and my best buddies
facebook profile pic..haha
some All Star Bash footage
Mick
randomness
Old 10-21-2012, 10:40 PM   #19
Lil_D
Lil_D is an unknown quantity at this point
this build is awesome it makes me want a fd even more now
@lild415
Lil_D is offline   Reply With Quote
Old 10-21-2012, 11:23 PM   #20
sex14
sex14 is an unknown quantity at this point
btw the guy that sold/stole your motor, did his last name happen to be pacquiao? anyways nice build.
sex14 is offline   Reply With Quote
Old 10-21-2012, 11:35 PM   #21
Mannykiller
nahh....haha. He almost sold the motor to someone else. I caught his ass and busted him. It was with an entirely different chassis anyways...some 8-9 years ago. I'd still deck his ass in the jaw though... that guys a low life.
Old 10-22-2012, 07:46 AM   #22
project-D180
project-D180's Avatar
project-D180 is an unknown quantity at this point
this build is the illest i've seen in a while
project-D180 is offline   Reply With Quote
Old 10-22-2012, 07:51 AM   #23
Z33dori
Z33dori's Avatar
this build is phenomenal
Old 10-22-2012, 09:22 AM   #24
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
love the fab work, esp the intake manifold. keep it up!
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 10-22-2012, 11:20 AM   #25
Backintoans13
Backintoans13's Avatar
Backintoans13 is an unknown quantity at this point
Love FD's, with the exception of the wheels (To much dish for my style) this build is dope
Backintoans13 is offline   Reply With Quote
Old 10-22-2012, 01:49 PM   #26
Royal_T
Royal_T's Avatar
Royal_T is an unknown quantity at this point
Love this build,, Can't wait to see the finish car..
http://zilvia.net/advertise.html
Royal_T is offline   Reply With Quote
Old 10-22-2012, 02:56 PM   #27
KendallH
KendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choices
Been watching your build on 7club. Very nice work, keep it up!
KendallH is offline   Reply With Quote
Old 10-22-2012, 03:00 PM   #28
scottie
scottie's Avatar
scottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nice
I miss my 93' R1 Black FD so much. I commend your decision to keep the rotary. Can you tell me more about the motor? Which seals did you go with? Street Port? Bridge Port?
scottie is offline   Reply With Quote
Old 10-22-2012, 06:24 PM   #29
drscooper
god man this is sweet!
Old 10-22-2012, 07:02 PM   #30
Mannykiller
Hey thanks!
The motor was built by Howard Coleman (Coleman precision rotaries). Its a large street port that is supposed to make 500whp at 20-22lbs. I'll be keeping it a little lower than thatfor reliability. But the seals are NRS ceramic apex seals, 1 piece, 3mm..they were really expensive :-\ but they should take care of business.
adaptronic
